IPB
foo_input_vio2sf
jass0
post Oct 14 2013, 16:29
Post #1
Group: Members
Hello!
First of all, I was very pleasantly surprised to see that kode54 had picked up this plugin and developed it further. Thank you very much kode54! cool.gif
However... After the upgrade from 0.22 (?) to 0.24.2, almost every song plays incorrectly. sad.gif
Take for example the Phoenix Wright Ace Attorney soundtrack:
2SF here:
http://www.zophar.net/music/2sf/phoenix-wr...e-attorney.html
This is how it should sound:
http://www.youtube.com/playlist?list=PL4B22D54E54AC7CB9
I am sorry I cannot be of any more help than telling that it sounds wrong sad.gif
Go to the top of the page
+Quote Post
kode54
post Oct 16 2013, 18:09
Post #2
Group: Admin
Yes, because I broke the PSG mode when adding Lanczos resampling. This is fixed now.
+Quote Post
jass0
post Oct 17 2013, 07:48
Post #3
Group: Members
+Quote Post
Anakunda
post Oct 17 2013, 20:25
Post #4
Group: Members
Bug report, this component makes fb2k crushing in conjunction with existing Game Emu Player decoder.
+Quote Post
jass0
post Oct 18 2013, 08:09
Post #5
Group: Members
QUOTE (Anakunda @ Oct 17 2013, 22:25) *
I have both foo_gep (1.169) and foo_input_vio2sf (0.24.4) installed and I have no problems. blink.gif
This post has been edited by jass0: Oct 18 2013, 08:09
+Quote Post
Anakunda
post Oct 18 2013, 10:03
Post #6
Group: Members
QUOTE (jass0 @ Oct 18 2013, 09:09) *
Sounds interesting. If I have both installed foobar crushes on startup. If I uninstall either of them foobar runs normally.
+Quote Post
kode54
post Oct 18 2013, 16:30
Post #7
Group: Admin
I see no crash logs submitted by you.
+Quote Post
Anakunda
post Oct 18 2013, 17:24
Post #8
Group: Members
That's right, I forget wink.gif Send it now
Hmm..it writes...Problem caused by: iTunes libraries
This post has been edited by Anakunda: Oct 18 2013, 17:24
+Quote Post
kode54
post Oct 18 2013, 22:25
Post #9
Group: Admin
Try eliminating foo_input_caf, as it doesn't even appear to be working properly. (Error notice loading some CoreAudioToolbox thing)
And then there's this whole mess of crap that the troubleshooter says you should either remove or update.
+Quote Post
Missingno_force
post Mar 31 2014, 17:49
Post #10
Group: Members
Hi kode, I wanted to know if you could add cosine interpolation to the list of algorithms, as the lanczos one makes drum samples like snares, cymbals and hihats sound pretty dull (and somehow, the complete package sounds a bit dull all in all) and desmume says that cosine offers the best sound quality.
+Quote Post
kode54
post Apr 1 2014, 02:55
Post #11
Group: Admin
Cosine is bullshit, just a failed attempt at cubic spline interpolation. Where cubic spline interpolation draws a sinusoidal line which passes through each sample point, cosine interpolation simply draws a full cosine sweep between each sample point, without accurately reproducing the original waveform.
Cubic spline interpolation is probably what you want, even if it is less mathematically accurate for up and downsampling. Sinc interpolation is the most mathematically accurate I can feasibly use, but it does have a tendency to muffle samples if they are played back at low rates.
I will rework the interpolation options of both the NCSF and 2SF players later. Then you can have your cubic spline interpolation. Or band limited stepping, if you prefer that delicious sound of zero order hold, like the original hardware.
I've also had a request for unclipped floating point output. You know, so those 2SF files which contain songs that clip horribly on the actual hardware don't clip horribly like on the actual hardware.
EDIT: Bam, you get zero order hold, blep synthesis, linear interpolation, cubic interpolation, and sinc interpolation. Except for the PSG mode, that's always blep synthesis. Default is cubic, because that's the least likely to cause noticeable problems with low quality percussion samples, like some games are known to use.
+Quote Post
Missingno_force
post Apr 1 2014, 14:57
Post #12
Group: Members
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 25th July 2014 - 22:33
