Topic: Setup a custom column with two parent dirs and filename? (Read 622 times) previous topic - next topic
As far as I know I can setup/define my own custom columns.
How can I setup a column which contains the filename and exactly the two parent dir name?
Example the song with the absolute path
D:\aaaa\bbbb\cccc\dddd\mysong123.mp3
should contain in the custom column the text value
How can I define the corresponding pattern?
Peter
You should use the $directory_path function.
Either something like:
$directory(%path%,3)\$directory(%path%,2)\$directory(%path%)
or if the first part of the whole path is always the same you can work it out with other string functions, something like
$right($directory_path(%path%),$len('D:\aaaa\bbbb\'))
I'm late
