23 Pages V  « < 3 4 5 6 7 > »
.Ogg Vorbis aotuv, Question for Aoyumi
clobon
post Apr 6 2008, 03:56
Post #101
thank you and keep up the good work^^
HF, Clobon
LigH
post Apr 6 2008, 06:54
Post #102
QUOTE (Aoyumi @ Apr 5 2008, 23:57) *
I understand the cause of the problem. But, I don't find an efficient solution for the moment. sad.gif
Probably the basic solution is not possible in "Advanced Encoder Options".
In that case there is only one solution... "More bitrate". Alright then - Prodigy deserves it!
http://forum.gleitz.info - das deutsche doom9/Gleitz-Forum
bukem
post Apr 6 2008, 21:39
Post #103
@john33 & lvgcl:
Guys, should we let know foobar2000 developers about that bug or you just have done it already?
bukem
post Apr 6 2008, 21:51
Post #104
And as somebody Spikey already asked - does anyone knows if BlackSword is working on optimized version of Aoyumi 5.5. Do we have his e-mail or anybody can let him now about new version?
This post has been edited by bukem: Apr 6 2008, 21:54
alter4
post Apr 8 2008, 09:10
Post #105
The problem detected by LigH is audible up to q6.
100% Killer sample!
This post has been edited by alter4: Apr 8 2008, 09:11
LigH
post Apr 8 2008, 10:07
Post #106
QUOTE (alter4 @ Apr 8 2008, 09:10) *
100% Killer sample!
blink.gif In that case: laugh.gif Rooobeeertooo!!! (Amorim)
He may love that for a possibly fresh ABX test with current encoders, if he does them still.
alter4
post Apr 10 2008, 07:58
Post #107
I tested beta 5.5 on some similar electronic samples. I couldn't reproduce described above problem. It seems as this isn't a production problem.
This post has been edited by alter4: Apr 10 2008, 07:59
vinnie97
post Apr 14 2008, 08:23
Post #108
Thanks! Most excellent. I think doing another multiformat 64 kbps is overkill but what about 80 kbps? wink.gif I know there was something in the works from Sebastien but hadn't heard about it in a while (also out of the loop recently).
The Sheep of DEA...
post Apr 16 2008, 17:16
Post #109
Aoyumi, if you figure out how to fix such a problem, would you release a post-beta5.5 with the fix (or a b5.51 fix as in b4.51)? Thanks for your efforts. smile.gif
Copy Restriction, Annulment, & Protection = C.R.A.P. -Supacon
Aoyumi
post Apr 18 2008, 14:52
Post #110
QUOTE (The Sheep of DEATH @ Apr 17 2008, 01:16) *
I will announce it in one way or another if I found a better method.
madoka@ex-sounds
post Jul 2 2008, 05:12
Post #111
uri: http://www.geocities.jp/aoyoume/aotuv/test.html
<name>madoka</name>
<uri>http://codecs.ex-sounds.net/</uri>
lex_nasa
post Jul 7 2008, 10:13
Post #112
QUOTE (madoka@ex-sounds @ Jul 1 2008, 20:12) *
Can anyone help out with the correct Foobar converter parameters for the windows binary? I've tried a number of different combinations with no success (my existing oggenc parameters don't work).
Correction, worked it out (can't get pipes to work though):
-q7 %s %d
This post has been edited by lex_nasa: Jul 7 2008, 10:19
Aoyumi
post Jul 8 2008, 14:35
Post #113
QUOTE (lex_nasa @ Jul 7 2008, 18:13) *
-q7 %s %d
Please try the following custom parameters.
-q7 - %d
Look at a manual bundled with the reference binary of "aoTuV beta 5.5" about "venc.exe". smile.gif
lex_nasa
post Jul 8 2008, 17:32
Post #114
QUOTE (Aoyumi @ Jul 8 2008, 05:35) *
-q7 %s %d
-q7 - %d
Yes I did try that first and it didn't work. I'm using Foobar2000 v0.9.5.4 beta 3:
Source: "C:\Documents and Settings\user\Desktop\shirk_itchytime_sample.mp3"
An error occured while writing to file (The encoder has terminated prematurely with code 1; please re-check parameters) : "C:\Documents and Settings\user\Desktop\00 - shirk_itchytime_sample.ogg"
Additional information:
Encoder stream format: 44100Hz / 2ch / 32bps
Command line: "C:\Program Files\foobar2000 new\venc.exe" -q7 - "00 - shirk_itchytime_sample.ogg"
Working folder: C:\Documents and Settings\user\Desktop\
Conversion failed: The encoder has terminated prematurely with code 1; please re-check parameters
1 out of 1 tracks converted with major problems.
Aoyumi
post Jul 9 2008, 14:55
Post #115
QUOTE (lex_nasa @ Jul 9 2008, 01:32) *
There must be the bit depth in 16bit. Your setting becomes 32bit.
lex_nasa
post Jul 9 2008, 17:33
Post #116
Yes, I tried that:
Source: "C:\Documents and Settings\user\Desktop\14 - Piva di Bedonia e di Scurano.m4a"
An error occured while writing to file (The encoder has terminated prematurely with code 0; please re-check parameters) : "C:\Documents and Settings\user\Desktop\14 - Piva di Bedonia e di Scurano.ogg"
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "C:\Program Files\foobar2000 new\venc.exe" -q5 - "14 - Piva di Bedonia e di Scurano.ogg"
Conversion failed: The encoder has terminated prematurely with code 0; please re-check parameters
Anyway Aoyumi, it is not a big problem, the new encoder works very well, and John33 or someone else can compile your source code. Thank you for all your excellent work!
Aoyumi
post Jul 10 2008, 13:01
Post #117
QUOTE (lex_nasa @ Jul 10 2008, 01:33) *
Yes, I tried that:
I discovered a small mistake in a pipe input processing part. And it is fixed now.
Please try a new version.
lex_nasa
post Jul 10 2008, 17:20
Post #118
Aoyumi... I have tested it and it works perfectly now... thank you!
JasonQ
post Jul 14 2008, 01:20
Post #119
Hey, thanks for continuing to work on Vorbis.
Does anyone know if there is any chance of the "Lancer" guys compiling a new version using the latest AOTUV release?
- Jason
LigH
post Jul 14 2008, 04:28
Post #120
lex_nasa
post Jul 14 2008, 13:09
Post #121
QUOTE (JasonQ @ Jul 13 2008, 16:20) *
I emailed them in English a month or so ago, but no reply... they probably didn't know who I was or what I was saying!
JasonQ
post Jul 15 2008, 06:02
Post #122
QUOTE (lex_nasa @ Jul 14 2008, 07:09) *
Ha!! Well maybe someone on this forum who speaks Japanese can give it a shot. In my humble opinion (and this probably goes against one of the forum rules) the combination of AOTUV quality and Lancer speed is the best lossy compression codec on the planet.
- Jason
This post has been edited by JasonQ: Jul 15 2008, 06:03
john33
post Jul 15 2008, 06:53
Post #123
xcLame and OggDropXPd Developer
Considering the amount of work involved in the Lancer builds, I imagine Blacksword is waiting for libvorbis 1.2.1 to be fully released before doing anything, as am I. wink.gif
John
JasonQ
post Jul 15 2008, 07:08
Post #124
QUOTE (john33 @ Jul 15 2008, 00:53) *
"Considering the amount of work involved in the Lancer builds, I imagine Blacksword is waiting for libvorbis 1.2.1 to be fully released before doing anything, as am I."
Well if that is the case I guess I'll just have to wait. You are another one here who does great work -- thank you.
- Jason
GrooveEcho
post Jul 22 2008, 17:48
Post #125
Is there a version of the aoTuV beta5.5 encoder that works with Windows 98SE?
RSS Lo-Fi Version Time is now: 27th January 2015 - 23:28
