IPB
how can i use the faad2 to decode the HE-AAC audio stream?
iohazard02001
post Mar 19 2008, 08:24
Post #1
Group: Members
I have used the faad2 to decode successfully the aac audio stream of DVB-H,
but now i have some problem to decode the HE-AAC audio stream.
I can't use the same way which to decode the aac to decode the HE-AAC.
In my opinion, the open source "faad2" need to determine the type of audio stream.
I think the faad2 default audio type is AAC - LC,
because in the main.c has this code "int object_type = LC;"
I modify this code -> "int object_type = HE_AAC;"
but it is still not work ....
how can i solve this problem?
Thanks for the help!
Go to the top of the page
+Quote Post
tebasuna51
post Mar 20 2008, 17:26
Post #2
Group: Members
QUOTE (iohazard02001 @ Mar 19 2008, 08:24) *
Without problem with:
"FAAD 2 for Win32
2004-07-09
FAAD2 is an AAC/MP4 command line audio decoder for Win32. It supports several profiles (LC, LTP, Main, LD, HE, HEv2...), and can playback AAC/MP4 streams."
The type HE is automatically detected.
+Quote Post
menno
post Mar 20 2008, 17:30
Post #3
Nero MPEG4 developer
Group: Developer (Donating)
Is it a raw stream? Or LATM? LATM will not work, because faad2 doesn't parse that. In case of a raw stream you have to set the samplerate on the command line, for HE AAC this will be half of the output samplerate.
+Quote Post
iohazard02001
post Mar 23 2008, 11:35
Post #4
Group: Members
QUOTE (tebasuna51 @ Mar 21 2008, 00:26) *
"FAAD 2 for Win32
2004-07-09
thanks for your reply
but it is look like a .exe file not a source code,
and don't have any document that tell me how to use this....
can you give me more guidance?
thanks for help
+Quote Post
iohazard02001
post Mar 23 2008, 11:51
Post #5
Group: Members
QUOTE (menno @ Mar 21 2008, 00:30) *
because this code will determine the header type of audio stream
if my acc stream case, the code know the stream is raw
but in the he-aac case, faad2 don't know what the audio stream header type is.
faad2 will show the message: "Error initializing decoder library."
i doubt that maybe have other header encapsulate the raw data of he-aac,
i will survey the LATM
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 27th November 2014 - 09:14
