IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Ratings(column) for cue sheet?
VixD
post Apr 18 2014, 17:14
Post #1
Group: Members
I want to know if I can add stars to a column next to a song with cue sheet. The thing is, I use a single flac to linsten to various songs within it. So i use the cue sheet to split the songs in foobar. But i can't use ratings for those separated songs that are in fact one single flac.
I do it with mp3 files but i can't do it with cue. I use this command for custom column: $ifgreater($meta(rating),3,$pad($repeat(★,$div($meta(rating),20)),3,☆),$ifgreater($meta(rating),0,$pad($repeat(★,$meta(rating)),0,☆),$repeat(☆,0)))
It helps me to organize which songs are better to listen to, and i find it annoying that i can't do it witch cue files.
Go to the top of the page
+Quote Post
BenB
post Apr 18 2014, 17:35
Post #2
Group: Members
Playback Statistics component or the m-TAGS component. The former stores ratings in a database and the latter stores ratings (along with all the other metadata) in a text file. You'll need to especially read the discussion and documentation for m-TAGS to fully understand how it works and what it allows you to do.
+Quote Post
VixD
post Apr 18 2014, 18:54
Post #3
Group: Members
QUOTE (BenB @ Apr 18 2014, 13:35) *
Wow, thank you! That helped a lot!
Didn't expect such a good solution.
This post has been edited by VixD: Apr 18 2014, 19:01
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th August 2014 - 14:55
