6 Pages V  < 1 2 3 4 5 > »
foo_utils, plugin discussion
q-stankovic
post Nov 10 2006, 17:15
Post #51
Using foo_utils very often in different scenarios i remarked that there are two features i miss:
1. edit->crop in playlist,edit other->crop in specified playlist (and play).
2. an option to set if using one of all that edit and edit other commands which start playback (f.e. add to specified playlist and play -> ... or whatever else) that the playback begins after the currently playing track finishes
This post has been edited by q-stankovic: Nov 10 2006, 17:16
q-stankovic
post Nov 12 2006, 21:53
Post #52
I thought that it was a bug in ColumnsUi and so i bothered musicmusic. I used for a long time the option "Activate target playlist" checked. But since foo 0.94 i decided to uncheck the option and the result is that if i use f.e. add to playlist and play -> (playlistname) the selected is sended to specified playlist but played in active playlist. As i can remember in earlier versions of foobar the selected track was played in specified playlist. Or am I wrong?
This post has been edited by q-stankovic: Nov 12 2006, 21:53
foosion
post Nov 12 2006, 22:33
Post #53
Group: FB2K Moderator (Donating)
When using that command, foo_utils starts playback of the first transferred track in th target playlist by simulating a doubleclick on it through the proper API. Apparently there is a bug in foobar2000 itself, that is triggered when this is performed on a playlist that is not the active one. I'll point Peter to it.
q-stankovic
post Nov 29 2006, 19:36
Post #54
QUOTE (foosion @ Nov 12 2006, 22:33) *
I hoped so much that this "bug" would dissappear in the new release so that i could realize my desired configuration but... crying.gif
ladiko
post Jan 19 2007, 13:50
Post #55
are there a function like %playlist_total_time% and %playlist_total_filesize% in text tools now?
This post has been edited by ladiko: Jan 19 2007, 13:51
foosion
post Jan 19 2007, 15:00
Post #56
QUOTE (ladiko @ Jan 19 2007, 13:50) *
No, there aren't. In case it isn't obvious, foo_utils hasn't been changed in quite some time now.
ladiko
post Jan 19 2007, 15:15
Post #57
and the development is stopped?
"mature" means you think it has all functions it should have?
This post has been edited by ladiko: Jan 19 2007, 15:17
foosion
post Jan 19 2007, 15:49
Post #58
I give a component the label "mature" if I think it has enough functionality to be useful in the context I made it for and if it has a certain degree of stability, which means it has had enough testing to find and remove most bugs and that there will likely be no incompatible changes (menu commands, configuration format, etc.), at least not without a clear upgrade path. A beta version of a mature version may suffer from reduced stability.
Development of foo_utils is on hold until I find a convincing reason to work on it.
ladiko
post Jan 19 2007, 20:09
Post #59
i would like to have %total_playlist_time% and %total_playlist_size% - isn't it a convincing reason to work on it tongue.gif
ok i have to live without - you can not have all for free =)
norz
post Mar 4 2007, 15:22
Post #60
Have you tried using %cwb_playinglist_duration% or %cwb_selection_duration% from foo_cwb_hooks?
Problemkerze
post Jul 19 2007, 20:30
Post #61
This will sound strange but setting a keyboard shortcut as a global hotkey wont work with foo_utils-commands
and much more strange: While running foobar with foo_utils-plugin the network-connection will slow down heavily. After closing foobar and/or uninstalling foo_utils the network speed returns to its old level.
This problem is repeatable on my system.
I'm using
-foobar 0.9.4.2 (later 0.9.4.3 with the same problems)
-Windows XP Home (all updates installed)
-Intel Centrino: Pentium M 1,6 GHz, Intel PRO/Wireless 2200BG Network Controller)
Any idea?
foosion
post Jul 19 2007, 20:59
Post #62
QUOTE (Problemkerze @ Jul 19 2007, 21:30) *
What variation of the context menu command do you use for that hotkey: [context], [context / now playing] or [context / playlist]? Global hotkeys have no default context, so you cannot use the first one.
Strange indeed, as foo_utils does not contain network related functionality. Moreover, it is inactive until you invoke one of its menu commands. So no, I have no idea on that one.
Problemkerze
post Jul 21 2007, 07:47
Post #63
thanks foosion - works now with context / now playing smile.gif
After installing new drivers for my network card the connection problem is also gone.
All I have to say now is:
Great great great plugin!
q-stankovic
post Sep 19 2007, 13:17
Post #64
Not a feature request but more a suggestion for next version:
Instead of "Edit" and "Edit other" as main menus i think it would be easier for new users to have following three menus: "Active Playlist", "Specified Playlist", "Clipboard".
foosion
post Oct 20 2007, 17:53
Post #65
foo_utils 0.6.2 beta 1
Requires foobar2000 0.9.5 and Windows XP.
Changes:
  • Clipboard related commands and the "Play" context menu command have been removed since they are part of foobar2000 0.9.5 itself.
  • Some minor fixes here and there.
  • Added advanced sorting dialog:
    Use "Edit/Sort/Sort by fields..." to open the window. Note that it is modeless, which means you can click on and use other parts of foobar2000 while it is open. For example, you can change the playlist. It will always sort the playlist that is active when you press the Sort button. Another version of this window is available from "Edit/Selection/Sort/Sort by fields..." or from the Sort submenu of the playlist context menu which only sorts the playlist selection.
    I almost forgot to mention this: The plugin takes the displayed fields from a setting on the Advanced preferences page. The settings is located in Tools > Playlist Tools. The syntax is the same as for the standard fields in the foobar2000 properties dialog, though the interpretation is a bit different. The fields are always evaluated using title formatting, so "Play Count=PLAY_COUNT" will work even with the official play count plugin and no tag synchronization (i.e. when the PLAY_COUNT field is not actually written to the file, but only provided through title formatting).
Download
Note: 0.6.0 and 0.6.1 were only released to participants of the closed foobar2000 0.9.5 alpha test.
This post has been edited by foosion: Oct 20 2007, 18:10
radio_cascara
post Oct 23 2007, 19:45
Post #66
cool, hope to see some stuff like read-only incorporated into foobar.
Borisz
post Oct 30 2007, 23:13
Post #67
Is it normal that, using the latest beta (0.6.2 b3) in the latest foobar version (9.5 beta 2), there are no cut/copy/paste commands assignable as keyboard shortcuts?
I can only find copy command, but not cut nor paste. Cut/Copy/Paste is integrated into the Default User Interface in 9.5 b2, which I imagine may have been a reason behind removing the command, but because of this I cannot use them under Columns UI. I was forced to revert to the older foo_utils version.
(see also http://www.hydrogenaudio.org/forums/index....p;#entry526657)
http://evilboris.sonic-cult.net/346/
Sega Saturn, Shiro!
foosion
post Oct 30 2007, 23:31
Post #68
That is perfectly normal, see my last post before yours.
tberman333
post Nov 13 2007, 16:55
Post #69
It seems that the "Highlight in Playlist" function is not part for foo_utils in the latest version. Is there a reason for this? Is there another way to do the same thing in the new Foobar beta that I am missing?
Forget it... I found it. Sorry for the inaccurate post.
This post has been edited by tberman333: Nov 13 2007, 18:01
GO WHALE!!!
[url="http://www.toddberman.com"]My Website[/url]
foosion
post Nov 13 2007, 18:10
Post #70
"Edit/Highlight in Playlist" is definitely part of foo_utils 0.6.2 beta 3. However it is not available for the playlist context menu. If it is not visible in the context menu at all you may need to add it in the context menu editor.
q-stankovic
post Nov 14 2007, 14:50
Post #71
QUOTE (foosion @ Nov 13 2007, 18:10) *
Just out of curiosity: Does it make sense to have "Remove from playlist" available in playlist context menu although foobar core already offers "remove"?
This post has been edited by q-stankovic: Nov 14 2007, 14:51
Vomitus
post Dec 20 2007, 17:09
Post #72
So, we have a "readonly playlist" feature - this is good!
But is there any variable that represents current playlist state? (e.g. %is_locked%).
I actually haven't found such or similar. Please, show me the name of this variable or add it to next version if it doesn't exist.
I am gonna use this variable in ColumnUI's playlist switcher and may be in PanelsUI in future(if I handle to manage that last one:))
And... thanks for good plugin!
foosion
post Dec 20 2007, 17:34
Post #73
It is technically not possible to add such a title formatting field in foo_utils. However, the Columns UI playlist switcher already has such functionality built in. Please see its documentation.
Kiteroa
post Dec 20 2007, 21:42
Post #74
Thanks for the update with the sorting functionality.
Just a thought: it would be useful if the sort window remembered the selected fields and options between invocations!
tb2496
post Jan 27 2008, 15:03
Post #75
hi, looks like when using "edit\insert into current playlist" with latest 0.6.2 beta 3 the tracks are not sorted properly. I tried changing "sort incoming files by" under general which didnt do anything when using "edit\insert into current playlist"
RSS Lo-Fi Version Time is now: 31st August 2015 - 21:30
