IPB
Audio-CD burning software supporting setting of pre-emphasis flag
Sebastian Mares
post Jan 14 2007, 00:36
Post #1
Group: Members
Does anyone know a program other than EAC that can write an audio CD with the pre-emphasis flag set?
Thanks in advance.
http://listening-tests.hydrogenaudio.org/sebastian/
Go to the top of the page
+Quote Post
Egor
post Jan 14 2007, 15:07
Post #2
Group: Members
Goldenhawk's CDRWin does support writing of all the FLAGS. Besides, it is free to try and the only limitation (burning at the lowest possible speed only) would cause a better quality of a burned Audio CD smile.gif .
+Quote Post
Alex B
post Jan 14 2007, 16:16
Post #3
Group: Members
I was about to post the same answer (CDRWIN).
I did some tests with Alcohol 120%, but I couldn't make it to write the FLAGS PRE info to a CD-RW disc.
By the way, why do you ask? Doesn't burning with EAC work for you?
http://listening-tests.freetzi.com
+Quote Post
naturfreak
post Jan 15 2007, 00:05
Post #4
Group: Members
Feurio! supports the pre-emphasis flag.
This post has been edited by naturfreak: Jan 15 2007, 00:05
+Quote Post
francesco
post Oct 3 2008, 06:55
Post #5
Group: Members
does nero 7 copy too?
i mean can nero write an audio CD with the pre-emphasis flag set?
if yes which version
This post has been edited by francesco: Oct 3 2008, 17:39
+Quote Post
francesco
post Oct 5 2008, 11:30
Post #6
Group: Members
QUOTE (Egor @ Jan 14 2007, 08:07) *
it's true that burn a cd at low speed gives a better quality?
+Quote Post
zombiewerewolf
post Oct 5 2008, 11:37
Post #7
Group: Members
rdgrimes at cdfreaks tested high speed vs low speed burning (in 2003).
His conclusion was "the slow burn produces higher error rates, but not enough to create any reading problems (no C2). But it certainly points to the conclusion that slower is not better. The error rate at 4x is about 3x higher than at 40x."
http://club.cdfreaks.com/f33/high-speed-vs...-burning-69698/
+Quote Post
Soap
post Oct 5 2008, 13:20
Post #8
Group: Members
QUOTE (francesco @ Oct 5 2008, 06:30) *
Varies from drive to drive and sometimes from firmware revision to firmware revision.
That being said there is no reason to believe there is even a rule-of-thumb that slow=better.
Creature of habit.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 20th September 2014 - 07:09
