3 Pages V  < 1 2 3
Opus 1.1, Almost But Not Quite Officially Released Yet
nu774
post Jul 1 2014, 12:19
Post #51
QUOTE (lvqcl @ Jul 1 2014, 19:22) *
Found a way to fix this problem: in function seek_forward (in audio_in.c) comment out fseek():
static int seek_forward(FILE *in, unsigned int length)
    //if(fseek(in, length, SEEK_CUR))
        /* Failed. Do it the hard way. */
        unsigned char buf[1024];
        unsigned int seek_needed = length;
added: currently opusenc uses fseek() to skip over "LIST" chunk, and this somehow prevents further reading/seeking
Doesn't it look familiar? IIRC, I saw similar code in flac frontend in the past.
fseek() on a non-seekable file is guaranteed to fail on Posix, but not on Windows. Therefore, "try to seek first and read when fail" doesn't work...
lvqcl
post Jul 1 2014, 13:01
Post #52
So another solution is to use #ifdef?
#if !defined _WIN32
#endif
john33
post Jul 1 2014, 18:22
Post #53
xcLame and OggDropXPd Developer
QUOTE (lvqcl @ Jul 1 2014, 13:01) *
#if !defined _WIN32
#endif
I have uploaded a build of opustools with this mod in place. If someone would kindly confirm this works OK, I'll complete other relevant recompiles and upload.
It's available here: http://www.rarewares.org/files/opus/opus-t...win32_SSE-1.zip
John
CoRoNe
post Jul 1 2014, 22:42
Post #54
This one works, john33.
ffmpeg.exe -hide_banner -i input.avs -c:a copy -f wav - | qaac.exe --silent -D - -o - | opusenc.exe --bitrate 64 - output.opus
ffmpeg.exe -hide_banner -i input.avs -c:a copy -f wav - | opusenc.exe --bitrate 64 - output.opus
Now both produce the same output. Thank you, lvqcl and john33!
Upon having loaded the AviSynth audiostream ffmpeg does still notify me though with: "[wav @ 02f8d700] Using AVStream.codec.time_base as a timebase hint to the muxer is deprecated. Set AVStream.time_base instead." Does anyone know by chance if this is important/bad?
Btw john33, I see you grabbed opus-tools 0.1.8 for this fix, but 0.1.9 is out already.
DC-Bass Source Mod: http://reino.degeelebosch.nl
john33
post Jul 1 2014, 23:44
Post #55
QUOTE (CoRoNe @ Jul 1 2014, 22:42) *
Thanks for the feedback, and the 'heads up'. I'll sort new compiles out tomorrow.
John
john33
post Jul 2 2014, 19:18
Post #56
QUOTE (john33 @ Jul 1 2014, 23:44) *
Opus-tools updated on Rarewares to 0.1.9, including the bug fix. I'll get to the oggenc2 compiles later. wink.gif
John
eahm
post Jul 2 2014, 19:44
Post #57
QUOTE (john33 @ Jul 2 2014, 11:18) *
What's new on this one? Same fix?
CoRoNe
post Jul 2 2014, 19:57
Post #58
opusenc.exe -V
opusenc opus-tools  (using libopus 1.1.x-git)
Copyright (C) 2008-2013 Xiph.Org Foundation
Could you please recompile and enter the opus-tools version, because opusinfo.exe, but especially MediaInfo reads those entries.
"libopus 1.1.x-git" means compiled from latest git at that moment I guess?
P.s. http://www.rarewares.org/opus.php --> you seem to forgot a "<" in front of "/span>".
john33
post Jul 2 2014, 22:05
Post #59
QUOTE (eahm @ Jul 2 2014, 19:44) *
Yep.
John
john33
post Jul 2 2014, 22:09
Post #60
QUOTE (CoRoNe @ Jul 2 2014, 19:57) *
opusenc.exe -V
Recompiled, as requested. Sorry, I thought I'd taken care of that! Yes, latest git.
opus.php fixed as well, thanks again!
John
CoRoNe
post Jul 2 2014, 22:24
Post #61
Appreciated, thanks!
I was wondering btw...will this fix only be in your binaries, or also in futures releases on http://opus-codec.org?
john33
post Jul 2 2014, 22:26
Post #62
QUOTE (CoRoNe @ Jul 2 2014, 22:24) *
Only in mine until jmvalin, or another official maintainer, makes the change.
John
nu774
post Jul 3 2014, 10:06
Post #63
You can steel fskip_ahead() from FLAC frontend:
https://git.xiph.org/?p=flac.git;a=commitdi...6a8645e83be9768
LAME has similar function named fskip() in get_audio.c, in which only S_ISFIFO is treated as a non-seekable candidate.
Completely killing fseek() on win32 is usually fine since what is skipped is usually tiny.
However, AIFF can have COMM(=header) after ssnd(=PCM data), in which case HUGE amount of block has to be skipped by fread() before reading COMM.
john33
post Jul 3 2014, 11:50
Post #64
QUOTE (nu774 @ Jul 3 2014, 10:06) *
Code 'stolen' from FLAC fronted! wink.gif Could someone kindly check that I've amended this in a way that it performs correctly? TIA.
It's here: http://www.rarewares.org/files/opus/opus-t...win32_SSE-1.zip
John
CoRoNe
post Jul 3 2014, 18:17
Post #65
Piping 32bit float AviSynth audio from ffmpeg to opusenc works for me. Thanks.
john33
post Jul 3 2014, 18:19
Post #66
QUOTE (CoRoNe @ Jul 3 2014, 18:17) *
Excellent. smile.gif Thanks for letting me know. I'll proliferate new compiles that use this code.
John
eahm
post Jul 3 2014, 19:57
Post #67
john33, thanks for the new builds again.
Is SSE2 optimised instead of SSE on Opus 64bit a typo?
This post has been edited by eahm: Jul 3 2014, 19:59
john33
post Jul 4 2014, 15:25
Post #68
QUOTE (eahm @ Jul 3 2014, 19:57) *
No, it's not a typo, I just selected the SSE2 compiler option on all the Opus x64 component builds.
John
zima
post Jul 5 2014, 23:03
Post #69
eahm, all x64 CPUs must support SSE2, so there's no harm....
http://last.fm/user/zima
SokilOff
post Jul 5 2014, 23:44
Post #70
QUOTE (zima @ Jul 5 2014, 16:03) *
True.
Even the very first 64-bit Athlons (ClawHammer and Newcastle from september 2003) already had SSE2 support. So there's no 64-bit desktop CPU from Intel or AMD without SSE2.
2 john33: thanks for releasing new opus builds. Btw do you still plan to create opusdropXP one day ?
bat_guano
post Jul 16 2014, 01:38
Post #71
Hi
It's been fixed ---> fixed
CoRoNe
post Jul 18 2014, 11:34
Post #72
Confirmed, thank you.
oto_shan
post Jul 31 2014, 19:18
Post #73
Why file converted 2 times with same encoder options (--bitrate 128) with last official codec opus-tools 0.1.9 they have different structure/checksum?
This post has been edited by oto_shan: Jul 31 2014, 19:43
Anakunda
post Jul 31 2014, 19:54
Post #74
QUOTE (oto_shan @ Jul 31 2014, 20:18) *
Timestamp? Unique conversion id?
lvqcl
post Jul 31 2014, 20:08
Post #75
Diagnostic options:
--serial n         Forces a specific stream serial number
3 Pages V  < 1 2 3
RSS Lo-Fi Version Time is now: 26th October 2014 - 02:52
