IPB
Using SoX to de-emphasize CDs
d_headshot
post Jan 19 2012, 06:00
Post #1
Group: Members
I have a CD that has pre-emphasis applied, and I found a guide how to solve it: http://blowfish.be/eac/Rip/rip12-preemph.html but I'm getting errors when trying to run SoX. It says "sox" is not a recognizable internal or external command.
Go to the top of the page
+Quote Post
Glenn Gundlach
post Jan 19 2012, 06:31
Post #2
Group: Members
QUOTE (d_headshot @ Jan 18 2012, 21:00) *
Go check this out.
http://sox.sourceforge.net/
G
+Quote Post
mudlord
post Jan 19 2012, 08:35
Post #3
Group: Developer (Donating)
OR http://www.foobar2000.org/components/view/foo_dsp_effect
uses same algorithm as SoX
+Quote Post
slks
post Jan 20 2012, 15:03
Post #4
Group: Members
Basic question - when trying to run SOX from the command line, you are in the proper directory, right? Unless the .exe is in your Windows directory, Windows won't find it unless you are currently navigated to the directory where sox.exe is located. You'll have to tell the command line to:
CODE
cd C:\example\directory\qweriopiodk
first.
Where "cd" means "change directory", followed by the full path to wherever you have SOX.
Alternatively, the aforementioned foobar2000 plugin component might do the trick, if you are more comfortable with a graphical interface.
http://www.last.fm/user/sls/
+Quote Post
derty2
post Jan 20 2012, 16:21
Post #5
Group: Members
Does this plugin by mudlord (foo_dsp_effect) just kick in by itself when playing an (emphasized) audio CD in foobar2000?
I have the plugin installed, and I navigated to ("fb2k->Preferences->Playback->DSP Manager") and I don't see an Available DSP with a related name.
So, what is the available DSP for de-emphasizing an audio CD? Is this only for playback, or can it it be chained into ripping tasks?
+Quote Post
tpijag
post Jan 20 2012, 16:29
Post #6
Group: Members
Load IR filter>config
QUOTE
Added new IIR filter DSP to house the various IIR-related filter effects.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 2nd September 2014 - 18:16
