Topic: feature request for title formating.... (Read 2010 times) previous topic - next topic
my playlist just like this:
001|--Album Artists-------------------------------------|01:track1------------------------------------------- length
002|      --Album--                                                       |02:track2                                                 length
003|                                                               |03:track3                                                             length
004|                                                               |04:track4                                                             length
005|                                                               |05:track5                                                             length
because i use $cut(--%album artists%--$repeat(-,80),80) to show the first track of the album,but the font width of char "-" don't have the same width with other letters,so the playlist always doesn't arranged in an order ....
so i request an feature of out put relative position and locate some string in specicy relative position,this feature will ease title formating code editing,and useful....
just like this:
001|--Album Artists--------------------------------|01:track1-----------------------------------------------  length
Try using tabs ($char(9)) instead.
So your string would be something like:
%tracknumber%|$if($strccmp(%tracknumber%,1),--%album% %artist%$repeat(-,200),$if($strcmp(%tracknumber%,2),  --%album%--,))$char(9)|%tracknumber%:track%tracknumber%$if($strcmp(%tracknumber%,1),$repeat(-,200),)$char(9) %length%
plus some more stuff in there, but you get the point.  The tabs will give you 3 evenly spaced colums (use more tabs in a ratio if you want to change the releative size of the columns) and anything that is longer then the column size will just get cut off (that's why I put 200 '-''s in).
thanks 4 ur help,problem solved......
