Topic: 0.7 RC 10 Bug (Read 4001 times) previous topic - next topic
0.7 RC 10 Bug
I apologize in advance if this has been posted before, but I searched and found nothing.
For all the RC builds that I've tried, I cannot use the Add Directory function to load .mpc files.  Any non-mpc files in the directory will be added to the playlist, but the .mpc files refuse to come up.  I can go and manually add them through Add Files and selecting them all at once, and they play fine after that.  Album list works fine.
This is the Normal build, with the only non-default setting being adding kernel streaming.
If I need to list any more info, I'll be glad to.
0.7 RC 10 Bug
I play with MPC files all the time. Nothing wrong with them.
Maybe you set up anything on Preferences-Core-Adding new files...?
0.7 RC 10 Bug
It has .mpc files in the "Restrict incoming files to..." , plus I already said that I can add them singularly, so that wouldn't be it.
0.7 RC 10 Bug
shouldn't it be *.mpc ?
0.7 RC 10 Bug
I do have it as *.mpc, and again, I don't have that set up wrong because I can add them individually but not as a whole directory.
0.7 RC 10 Bug
Sorry, can't reproduce.
0.7 RC 10 Bug
Adding files individually bypasses restriction masks; so it looks like you do have it set up wrong (I tried with "*.MPC" restriction, still can't reproduce).
0.7 RC 10 Bug
My "Restrict incoming files by..." is
*.mp3; *.mpc; *.mid; *.midi; *.flac; *.ape; *.wav; *.s3m; *.ogg; *.xm
.(copied and pasted)
This was the same as it was when I was using .667, but when I upgraded to .7 I began having this problem.
I just tried it, and when I just use * for the restriction, it works.  But I don't see any error with the way I have it above.
0.7 RC 10 Bug
Remove spaces after each semicolon ?
I don't see why you would want to allow MIDI files, they're not supported at the moment and probably won't be anytime soon.
0.7 RC 10 Bug
Ahh, removing the spaces worked.  Thanks for helping me zZzZzZz.
Also I didn't realize there was no midi support, heh.  I guess that would explain why I've never played a midi file.
