IPB
Need advice: Listening and recording music with PC
Orome
post Jan 20 2010, 10:53
Post #1
Group: Members
Hi there
What i want to do:
I want to be able to listen to music in good quality (i don't need top stuff because a) I can't afford it and b) probably couldn't hear the difference anyways)
I want to record music in decent but not necessarily awesome quality.
What i have thus far:
My computer with a realtek mainboard.
Logitec z-2300 speakers (needs analog input)
A Tascam US-144 Interface
A Shure SM-57 with a XLR male/female and a XLR to 3.5mm jack cable
My main problem is that i can't use my Interface with my new computer because there's no driver for my new OS (windows 7 64bit) and i can't get it to work properly with other drivers (for example i tried the 64bit driver for vista).
Now I'm thinking about getting a PCI-(E) soundcard but I'm not sure how good the recordingquality will be. (As said above, I don't need premium qualitiy, but it should be decent)
So basically my questions are: Can you tell me which soundcard would work fine for me? Or would you advice me something else?
I hope I didn't forget something important.
Greetings
Go to the top of the page
+Quote Post
AndyH-ha
post Jan 20 2010, 11:50
Post #2
Group: Members
The quality of the soundcard is down near the bottom of the list of things that will effect the quality of your recordings. Your recording environment and recording techniques will make far larger differences. There is a great deal of information available free on the web and there are some decent beginner's books. General audio recording and processing know-how should be your first priority.
+Quote Post
Orome
post Jan 20 2010, 19:40
Post #3
Group: Members
Thanks for your feedback.
So you'd say, when I'm buying a soundcard (which I'll do anyways because I don't want to listen to music with my onboardcard), I only need to watch out for the outputquality so to speak? Even if I'm going to record through the very same card?
+Quote Post
DVDdoug
post Jan 20 2010, 22:57
Post #4
Group: Members
I can't recommend any specific equipment...
QUOTE
Actually, you'd be better-off with a similar device that has a proper balanced low-impedance mic input. I like this kind of solution (an external USB or Firewire "box"). Stand-alone digital recorders are another solution that I like...
I wouldn't use a regular soundcard with a pro microphone (like your SM-57)... Regular soundcards have high-impedance unbalanced inputs, and they generally have cheap mic preamps. (You can get pro soundcards with low-impedance mic inputs.)
An alternative would be to get a small mixer (with a mic input) and connect the line-out to the line-in on your soundcard. (As a rule, soundcard line-inputs are better than their mic inputs.)
Or, a few companies make a "USB microphone adapter" like this. (But, I'd only recommend this thing for special situations... And of course, you could run-into the same situation in the future with no available driver... sad.gif )
QUOTE
I'd be more concerned with input/recording quality. As far as output, if you don't hear any noise from the onboard sound, you are unlikely to hear any difference with an upgrade.
QUOTE
If you're recording live music (with a mic), a 2nd mic for stereo recording might be a good investment. wink.gif
This post has been edited by DVDdoug: Jan 20 2010, 23:02
+Quote Post
Arnold B. Kruege...
post Jan 21 2010, 03:36
Post #5
Group: Members
QUOTE (Orome @ Jan 20 2010, 04:53) *
Hi there
What i want to do:
The deal with Tascam's non-support of the US-144 and Windows 7 is a bummer. :-(
However, the US 144 has been around for a long time, and you can't expect much in the way of support for discontinued hardware. Have you checked the driver situation lately, as I read conflicting things on the web.
I recently got at deal on a Presonus FW 1394 which has regular mic inputs even with phantop power, as well as RCA jacks for line level inputs and outputs for about $100 at Musican's Friend.
+Quote Post
Orome
post Jan 22 2010, 10:29
Post #6
Group: Members
Thanks for all your help.
Concerning the US-144 driver: I'm regularly checking for a 64bit windows 7 driver, since I'm still hoping to be able to use it again someday, but no luck thus far. Tascam once made an announcement that they'll make one but thats months back already.
+Quote Post
MikeFord
post Jul 30 2010, 18:17
Post #7
Group: Members
QUOTE (Orome @ Jan 22 2010, 02:29) *
I've been thinking about a 122, so I checked just now and a driver for both the 122 and 144 is out for both 32 and 64 bit Win7.
http://www.tascam.com/details;9,15,70,19.html
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th November 2014 - 03:57
