IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Removing leading zeros from %tracknumber%
xordae
post Apr 17 2012, 15:05
Post #1
Group: Members
Can foobar2000 display the %tracknumber% variable in the playlist truthfully, i.e. without adding a zero for all numbers below 10? I would like to be able to sort it so I can determine which albums have not been formatted using 'Auto track number'.
Alternatively, is there a way to have Masstagger set up to truncate the leading zeros from %tracknumber%?
Since I keep multiple discs per folder, just doing an 'Auto track number' on the entire library will unfortunately screw it up.
Go to the top of the page
+Quote Post
Dario
post Apr 17 2012, 15:09
Post #2
Group: Members
$num(%tracknumber%,1) will do that for you.
No idea about MassTagger, as I've never used it.
+Quote Post
CoRoNe
post Apr 19 2012, 20:16
Post #3
Group: Members
%subsong% instead of %tracknumber%?
DC-Bass Source Mod: http://reino.degeelebosch.nl
+Quote Post
db1989
post Apr 19 2012, 20:29
Post #4
Group: Super Moderator
Edit: What I previously said here was really wrong, so ignore me. Dario was right! Unless I’m mistaken, CoRoNe’s suggestion of subsong isn’t relevant.
This post has been edited by db1989: Apr 19 2012, 21:49
+Quote Post
kode54
post Apr 19 2012, 23:51
Post #5
Group: Admin
$meta(tracknumber) should also work.
+Quote Post
nevets1219
post Apr 19 2012, 23:56
Post #6
Group: Members
For MassTagger ("Manage Scripts"), you can use "Format values from other fields" and set "Destination Field Name" to TRACKNUMBER and the pattern to "$num(%tracknumber%,1)" as previously suggested. I tested this on one particular album and it seems to work.
EDIT: You could select everything in your playlist but I'd perform some backup and/or tests to be sure the results are what you want.
EDIT: It seems to set songs without track number to track number zero. Be aware!
This post has been edited by nevets1219: Apr 20 2012, 00:00
+Quote Post
db1989
post Apr 20 2012, 09:04
Post #7
QUOTE (nevets1219 @ Apr 19 2012, 23:56) *
So use this:
CODE
[$num(%tracknumber%,1)]
The square brackets will have the expression return absolutely nothing (not a zero) if the field does not exist.
I just noticed: Technically, for fields whose literal value doesn’t have a leading zero, here you’d be adding one via %tracknumber% and then immediately removing using $num … but although this is redundant, the syntax is simple, and an expression that doesn’t do this is about five times longer—so never mind. tongue.gif
+Quote Post
nevets1219
post Apr 20 2012, 17:23
Post #8
Group: Members
I'm curious about the expression that doesn't do this, is it just an $if() expression or something fancier?
+Quote Post
db1989
post Apr 20 2012, 18:11
Post #9
Actually, this entire thread somewhat requires clarification over whether the OP’s fields literally contain leading zeroes, or whether the problem is simply due to the (documented) behaviour of %tracknumber% padding to two digits when necessary.
In the latter case, this can be averted just by using $meta(tracknumber) to show the literal value, without any processing.
In the former case, we have the suggestions above, or the purist’s way:
CODE
[$num($meta(tracknumber),1)]
This is what you asked about, nevets1219; the reason I previously thought it might’ve been complicated was because I was uncertain whether square brackets supported $meta fields—which would have necessitated an $if, a $meta_test, and such—but then I verified via Wine that they do. As I said, it hardly matters, but this should provide the pleasant placebo of knowing that no zeroes will be added only to be taken away. tongue.gif (And now, before I ramble any more, I’m taking myself away…)
This post has been edited by db1989: Apr 20 2012, 18:13
+Quote Post
nevets1219
post Apr 20 2012, 18:30
Post #10
Group: Members
Is there some standard or at least encouraged standard for tracknumbers (e.g. leading zero or not)? I took a look here but couldn't find anything. I recently went through a semi-manual process of removing leading zeros but I stopped midway because it was very tedious (select an entire album, "Run Last Script") - but with the method discussed here, I could do everything in one sweep. Just not sure if it is worth the effort.
+Quote Post
krafty
post Sep 3 2014, 02:10
Post #11
Group: Members
Sorry to resurrect this thead. I am looking into doing the opposite: insert the leading zero on metadata. EAC creates it with leading zeros, so I want to keep them.
How to achieve this?
+Quote Post
A_Man_Eating_Duc...
post Sep 3 2014, 03:38
Post #12
Group: Members
CODE
[$num($meta(tracknumber),2)]
+Quote Post
d125q
post Sep 3 2014, 17:19
Post #13
Group: Members
Does anybody know what is the difference between %track number% (*not* %tracknumber%; see the link) and $meta(tracknumber)?
+Quote Post
Daeron
post Sep 3 2014, 17:46
Post #14
Group: Members
QUOTE (d125q @ Sep 3 2014, 10:19) *
There shouldn't be any. They do the same thing, which is returning the value of the TRACKNUMBER field without further modifications.
This post has been edited by Daeron: Sep 3 2014, 17:47
+Quote Post
BenB
post Sep 3 2014, 17:56
Post #15
Group: Members
Wouldn't $meta(tracknumber) bypass the foobar database and return the value as it is stored in the file whereas %tracknumber% and %track number% both access the value stored in the foobar database?
I don't know if the database stores single-digit values with or without leading zeroes, adding or removing them or what.
This post has been edited by BenB: Sep 3 2014, 17:58
+Quote Post
Daeron
post Sep 3 2014, 18:23
Post #16
Group: Members
The short test I did was:
Track number in properties: 1
%track number%: 1
$meta(tracknumber): 1
%tracknumber%: 01
Track number in properties: 01
%track number%: 01
$meta(tracknumber): 01
%tracknumber%: 01
Track number in properties: 1/5
%track number%: 1/5
$meta(tracknumber): 1/5
%tracknumber%: 1/5
By nature $meta(tag) should make a difference in most cases, as it ignores remappings but TRACKNUMBER has none. Perhaps if you installed one of the custom database components which would take over the field.
+Quote Post
foosion
post Sep 3 2014, 19:10
Post #17
Group: FB2K Moderator (Donating)
QUOTE (BenB @ Sep 3 2014, 17:56) *
The built-in functions and fields never access audio files directly. They only access the information which foobar2000 has already retrieved and cached.
foobar2000 stores all fields as they are decoded by the associated input plugin. For most formats the value is returned as it is stored in the file.
QUOTE (Daeron @ Sep 3 2014, 18:23) *
%tracknumber% only checks the TRACKNUMBER tag but it does format the value. This is what is written in the title formatting help which you can access in foobar2000 from the Help menu:
QUOTE
Two-digit index of specified track within the album. Available only when “tracknumber” field is present in track’s metadata.
http://foosion.foobar2000.org/ - my components for foobar2000
+Quote Post
Daeron
post Sep 3 2014, 20:24
Post #18
Group: Members
QUOTE (foosion @ Sep 3 2014, 12:10) *
%tracknumber% only checks the TRACKNUMBER tag but it does format the value. This is what is written in the title formatting help which you can access in foobar2000 from the Help menu.
I was referring to %track number%, not %tracknumber%, as per d125q's post. So no formatting applied.
+Quote Post
BenB
post Sep 3 2014, 20:46
Post #19
Group: Members
QUOTE (foosion @ Sep 3 2014, 13:10) *
Oh... so in a case where foo_playcount is installed, $meta(rating) returns the value stored by the foobar database and %rating% returns the value stored by the foo_playcount database?
Apparently, I got the impression that $meta(rating) retrieved the value from the file and assumed $meta() bypassed both databases. I don't remember why or how I got that impression.
I tested after posting and found this to be the case. %tracknumber% simply adds leading zeroes when none are present.
Thanks for your help.
p.s. - sorry for wasting your time, Daeron.
This post has been edited by BenB: Sep 3 2014, 20:47
+Quote Post
krafty
post Sep 4 2014, 03:31
Post #20
Group: Members
Man Eating Duck, thanks. That worked!
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 31st January 2015 - 20:24
