Topic: Unresolved External Symbols (Read 3715 times) previous topic - next topic
Hello,
I am new to foobar2000, and I am trying to write a simple plugin for myself. Right now I just have stub code to see if I can build it and run foobar2000 with it. However, when I build it I get linker errors. The errors are:
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]unresolved external symbol "char const * __cdecl core_api::get_my_file_name(void)" (?get_my_file_name@core_api@@YAPBDXZ)
unresolved external symbol "public: static struct _GUID const componentversion::class_guid" (?class_guid@componentversion@@2U_GUID@@B)
unresolved external symbol "public: static class service_factory_base * service_factory_base::__internal__list" (?__internal__list@service_factory_base@@2PAV1@A)[/size]
By process of elimination I found that these are coming from the DECLARE_COMPONENT_VERSION macro. I examined both foo_sample and foo_tutorial1 plus all of the online documentation that I could find, but I can't find out what I am missing. I am linking against libraries: pfc, foobar2000_SDK, foobar2000_component_client, and shared.
I am using Microsoft Visual Studio 2010 Express. Any ideas? Thanks...
My simple stub code is:
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]#include "stdafx.h"  // just has: #include "..\SDK\foobar2000.h"
"Playlist Item Filter",
"1.0",
"Sorts the incoming playlist items by track number."
class playlist_incoming_item_filter_custom : public playlist_incoming_item_filter
  public:
bool filter_items(metadb_handle_list_cref in, metadb_handle_list_ref out)
        console::print("My filter_items function here...");
        t_size count = in.get_count();
        out.remove_all();
        if (count > 0)
            out.add_items(in);
        return (count > 0) ? true : false;
};[/size]
The first missing symbol belongs to foobar2000_component_client, the other two belong to foobar2000_SDK. So, you're obviously not linking against these librariers. You should check your project settings.
Oops! Apparently I didn't look close enough at foo_tutorial1 to see how I set up the additional link libs and lib paths. Egg on face and sorry...
Thank you very much...
