IPB
Spectrograph Seekbar?
Innomen
post Apr 24 2013, 03:16
Post #1
Group: Members
If this is a search-fu fail on my part, my apologies.
Like the Waveform seekbar (which is awesome btw) located here: http://www.hydrogenaudio.org/forums/index....showtopic=77490
Has anyone made such a thing?
(Like in Audition, or the spectrograph visualization.)
Go to the top of the page
+Quote Post
Aldem
post Apr 24 2013, 03:50
Post #2
Group: Members
I don't think there's one, but you might want to check into the visualizations, maybe there's somthing close to it.
http://wiki.hydrogenaudio.org/index.php?ti...s#Visualisation
+Quote Post
EpicForever
post Apr 24 2013, 17:43
Post #3
Group: Members
Interesting idea...
You can try request it in waveform seekbar thread, maybe Zao will try to make it...
This post has been edited by EpicForever: Apr 24 2013, 17:44
+Quote Post
kode54
post Apr 24 2013, 17:53
Post #4
Group: Admin
The thing is, storing spectrograph data for an entire track has significantly higher overhead than storing 4096 points worth of high/low/rms data. It would be doable, but expect your waveform cache database size to skyrocket by comparison to whatever it is now.
+Quote Post
marc2003
post Apr 24 2013, 20:00
Post #5
Group: Members
a quick and dirty something i made with WSH panel mod:
it doesn't require any user interaction - it uses SOX to create the image. WSH panel mod then displays the image and does the seekbar stuff. i just need to do a bit more testing before i upload it.
+Quote Post
EpicForever
post Apr 24 2013, 20:25
Post #6
Group: Members
Fcuk !! WSH panel mod is amazing thing... But I will not try it. Never. If I do then probably I'll spend rest of my life on fine tuning my ideal layout or set of layouts for different purposes... DUI forever - just for my good health. Anyway - I must say that miss this kind of colour gradation in original foobar spectrogram... Something similar was available in old foobar 0.8.3 with option of counterclockwise HSV colour mixing...
+Quote Post
marc2003
post Apr 24 2013, 20:59
Post #7
Group: Members
i've already run into a brick wall as i can't get it working with mp3 files. i think getting it to work with anything other than what SOX handles natively is going to be a world of pain for me. tongue.gif
+Quote Post
lvqcl
post Apr 24 2013, 22:26
Post #8
Group: Developer
AFAIK SoX uses libmad.dll to decode MP3 files.
+Quote Post
Dario
post Apr 24 2013, 22:56
Post #9
Group: Members
QUOTE (marc2003 @ Apr 24 2013, 21:59) *
I use SoX in conjunction with foo_run to create spectrograms of files I want to check and am currently facing a similar problem. 99% of my library consists of TAK files, and I can pipe data from Takc to SoX just fine, but couldn't do it with any lossy decoder. Hoping to get somewhat of a universal foo_run option, I also tried FFmpeg... to no avail.
This post has been edited by Dario: Apr 24 2013, 22:56
+Quote Post
marc2003
post Apr 24 2013, 23:37
Post #10
Group: Members
i can't be bothered with it. i couldn't find any version of libmad that would work. then i tried ffmpeg and i thought i had that working but the images created look nothing like the originals when using SOX natively so i give up.
+Quote Post
romor
post Apr 25 2013, 01:53
Post #11
Group: Members
Marc, for libmad take a pick: https://www.google.com/search?q=libmad+filetype:dll
I believe you all got 8 sec spectrogram when piping data. If that's the case, then you need to use `-d` switch and tell SoX the length of the track. Here is template for example for M4A:
CODE
neroaacdec -if <input-file> -of - | sox -t raw -e signed -b 16 -c 2 -r 44100 - -n channels 1 spectrogram -d <track-length> -w k -z <dB-range> -y <y-range> -x <x-range> -r
or in action:
CODE
neroaacdec -if track01.m4a -of - | sox -t raw -e signed -b 16 -c 2 -r 44100 - -n channels 1 spectrogram -d 3:58 -w k -z 140 -y 257 -x 800 -r
Decoding M4A with chapters:
CODE
neroaacdec -if <input-file> -of - -chapter <sub>
where <sub> is foobar %subsong% plus 1
Similarly for other decoders.
scripts: http://goo.gl/M1qVLQ
+Quote Post
marc2003
post Apr 25 2013, 02:30
Post #12
Group: Members
a huge thanks for that. the length thing was indeed my issue.
images created by piping in flacs with ffmpeg match what SOX made when handling them natively. i'd hope decoding all other ffmpeg supported codecs will be ok now as well.
+Quote Post
marc2003
post Apr 25 2013, 09:45
Post #13
Group: Members
i've put up what i have here:
http://www.hydrogenaudio.org/forums/index....st&p=832277
the main setup instructions for WSH panel mod and importing the script are in the readme, additional instructions for setting up ffmpeg and sox are in the script file.
lastly there are a few limitations outlined in that forum post. i can totally understand people not wanting to use it and waiting for a proper component developer to make something more complete instead. tongue.gif
@Dario, you can use -f sox - to pipe out from ffmpeg. then simply use -p as the input for sox. my full command looks like this:
CODE
var cmd = "cmd /c \"\"" + ffmpeg_exe + "\" -i \"" + filename + "\" -f sox - | \"" + sox_exe + "\" -p -n channels 1 spectrogram -d " + length + " -Y 130 -r -o \"" + png_filename + "\"\"";
This post has been edited by marc2003: Apr 25 2013, 10:08
+Quote Post
Innomen
post Apr 25 2013, 11:12
Post #14
Group: Members
QUOTE (EpicForever @ Apr 24 2013, 11:43) *
Interesting idea...
Done. Thanks smile.gif One can hope smile.gif I'm surprised really it didn't already exist at least in idea form, somewhere on this forum.
QUOTE (kode54 @ Apr 24 2013, 11:53) *
Why does it have to store it? PCs are only getting faster and code only gets better (in theory anyway) why not just generate it on the fly? If the delay is noticeable then it would seem it could load the next song in advance. But I'm no coder, I'm speaking from a logic/procedure/approach perspective only. But even if it did have to store it, that's no great worry for me. Free space just get's cheaper and cheaper as well. smile.gif
QUOTE (marc2003 @ Apr 24 2013, 14:00) *
That is pretty much exactly what I had in mind. WTG!
QUOTE (marc2003 @ Apr 25 2013, 03:45) *
I have no idea what "SoX/WSH panel mod" is but I'll do the relevant reading/installing/googling/tweaking. Thanks much!
Edit: "waiting for a proper component developer to make something more complete instead"
From the download and a quick read of the install pdf it seems completion, but rather modularity. As is true with most foobar users I suspect, I already have my own array of tweaks and and customizations applied.
Your edit seems to in effect be its own player, at least judging from the install instructions. So yes I'll be waiting until wider spread interest (if ever) inspires the creation of a more modular and de-personalized solution comes along. Still, great work and thank you for if nothing else providing a better image of exactly what is sought smile.gif
This post has been edited by Innomen: Apr 25 2013, 11:24
+Quote Post
marc2003
post Apr 25 2013, 11:25
Post #15
Group: Members
well you shouldn't have to google anything. full instructions/links are included. it's a little more effort than installing a normal component but shouldn't take more than a few minutes.
edit: i'm not sure i understand your edit. the spectrogram is only the bottom panel of my screenshot. you can place it in any layout like you would with foo_wave_seekbar.
This post has been edited by marc2003: Apr 25 2013, 11:34
+Quote Post
Zao
post Apr 25 2013, 11:57
Post #16
Group: Members (Donating)
Seekbars, everywhere!
The core problems would be storage (for persistent storage, many hundred times larger wavecache.db), analysis time (FFTs ain't cheap, compared to min/max/accum+sqrt), and UI complexity (my nemesis).
My current seekbar code is rather painfully hardcoded against arbitrary streams of data, as long as they're N-channel chunks of exactly 2048 data points.
Database storage might actually become smaller if compression can leverage the increased amount of data, but I wouldn't have my hopes up for that.
+Quote Post
Brazil2
post Apr 30 2013, 09:04
Post #17
Group: Members
QUOTE (marc2003 @ Apr 25 2013, 00:37) *
The one from the DVDplayer folder of XBMC 9.11 works with SoX. You can extract it with 7zip.
And this one works too.
+Quote Post
marc2003
post Apr 30 2013, 10:49
Post #18
Group: Members
thanks but you must have missed my subsequent posts where i have ffmpeg working. it's much easier using that because it supports mp3 and most other codecs. the one downside is the 22MB of disk space it takes up but i'll have to live with that. tongue.gif
+Quote Post
LifeH2O
post Jul 13 2014, 00:43
Post #19
Group: Members
Is there a way to set the scale to logarithmic? Linear hides so much information and log view is easier to understand. I have tried parameters, they only scale the linear up and down but do not make it log.
QUOTE (romor @ Apr 25 2013, 05:53) *
CODE
or in action:
CODE
CODE
This post has been edited by LifeH2O: Jul 13 2014, 00:44
+Quote Post
marc2003
post Jul 13 2014, 06:31
Post #20
Group: Members
i had a quick google and this seems to be relevant... http://sox.10957.n7.nabble.com/Spectrogram...ale-td1876.html
+Quote Post
LifeH2O
post Jul 14 2014, 02:28
Post #21
Group: Members
Someone patched SoX to support log scale, to me it is scaled image only, not the actual logrithmic graph. You can see the blocks at the bottom
http://sourceforge.net/p/sox/feature-requests/176/
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 2nd August 2014 - 06:02
