My first listening test.
2005-11-22 22:28:14
Being unable to game for a while, i needed another way to spend the evening indoors, which brought me to something i've been meaning to do for a while: explore my hearing. I've been using Vorbis q2 on my portable for years now and never had a problem with it (except a decoder using tremor in low accuracy mode), but as i don't listen to the originals all that much, and certainly not the original and ogg right after another, i had no idea if the ogg's and originals were actually the same to my ears. I wasn't expecting to hear differences except on problem samples however. I started out with surfing to ff123.net, i had read about the various common artifacts, but apart from quantitisation noise (i think) in certain mp3 sources (mostly web radio and older mp3's), i never heard much that i could clearly identify and name. ff123's artifact training page proved a wonderful resource, some of the very obvious artifacts seemed subtle to me (blackbird and dr4), where others in the obvious category were clear as daylight to my ears (wait, daughter). I decided to ABX rather than ABC/HR because i wasn't sure i would even be able to hear differences, let alone rate them reliably, it's best to start simple. I chose to test Vorbis q2 because i use this setting for my portable, and also because i hoped 96kbps would be a nice balance between popularity, quality and the ease with which artifacts can be spotted with my beginner ears, judging from the various other tests on this forum. Aotuv b4.51 was chosen because it's the latest and designed to bring improvements below q3, and preliminary testing indicates that it does. I like being on the cutting edge, so it's currently my Vorbis of choice. Too lazy to make samples out of my own collection, and for easier comparing by others, i chose ten samples from rarewares, and castanets.wav, for my first ever test, the list is as follows:Sample name Bitrate castanets 113 kbps 41_30sec 110 kbps Bachpsichord 113 kbps female_speech 81 kbps ItCouldBeSweet 84 kbps kraftwerk 108 kbps Layla 116 kbps Mama 110 kbps mybloodrusts 89 kbps NewYorkCity 99 kbps Waiting 100 kbps Average bitrate reported by foobar (castanets excluded): 102kbps (6.25% over nominal). Actually, with castanets included it's the same 102kbps. Most of these samples are music i own, music i like or similar to music i own. NewYorkCity is really the only one i'd never voluntarily listen to, but i put up with it in the name of science. My setup is a SB Live!, using the kX drivers, i listen to my music on the rear speaker output, which is connected to a Sony STR-AV200E tuner/amplifier. During testing i plugged my Sony MDR-EX71SL headphones into the amp and turned off the speakers. I think the headphone output is just wired to the amplifier through a resistor. I used foobar's ABX plugin for the testing, the dsp plugins i used were the advanced limiter and PPHS resampler, to 48000Hz, set to Ultra mode for the occasion. I realise this is far from ideal, but it's all i have. The results:castanets: 16/16. Easy. The preecho sounds like more like the jingle from a tambourine than a puff of air.41_30sec: I would swear i heard differences, but time and time again i couldn't ABX them succesfully. The Placebo effect really is a powerful one.Bachpsichord: Transparent.female_speech: Transparent, but i didn't spend as much time trying to find differences as with the above two.ItCouldBeSweet: 16/16. Preecho, especially the first clack.kraftwerk: 37/54. Smearing of transients, seem to have less fidelity. This one's on the very edge of my hearing.Layla: 14/16. Should be 15/16, i clicked the wrong one once. The applause at the start gives it away (slight warbling), i thought i heard a loss of coarseness on the snaredrum too, but i didn't ABX the sample without the applause to verify.Mama: 15/18. Loss of stereo on the big cymbal crash 16 seconds into the sample.mybloodrusts: 16/16. The guitar amplifier's overdrive in the first few seconds is a bit less pronounced, the effect seems the opposite of the dr4 artifact on ff123's training page.NewYorkCity: 14/16. Loss of [..] sharpness in the pronounciation of "friend", somewhat similar to mybloodrusts, but more subtle.Waiting: 14/16. Couldnt find a difference at first, then suddenly it struck me. There is a warbling in the air of the singer's voice, most clear in the first few seconds. If i would do it again it'd be 16/16. I don't understand what could cause this warbling, there's no highly irregular noise like the applause in Layla, and the bitrate isn't especially low. The results surprised me, although none of the artifacts heard really annoyed me, i found more differences than i expected. If i had to give ratings, i'd say most would be 4, with perhaps 3 for castanets, Layla and Waiting. But i really think i need more experience before i can accurately quanitfy the severity. Sometimes ogg even appeared to sound better! I'm definitely going to keep using q2 for my portable, although if i had more space, i would probably go higher. I'm a pragmatic purist. I just read another thread explaining that when not having the results hidden, you shouldn't continue abx'ing untill you get the desired confidence level (in my case 0,5% or better). With Mama i was distracted once, and i'm confident i would have no trouble reaching it in 16 tries if i did it again, kraftwerk is another matter. Then again, with such a high number of tries, what is the chance i would achieve this without actually hearing a difference? It seems solid enough to me, but i don't have a degree in statistics. If someone could shed some light on this, or if you have other feedback for me, please do tell! To give this test more than just personal value, and with the confidence that i can actually hear differences in most samples at q2, i've decided to repeat this with aotuv b4, and when both aren't transparent, try to ABX them against eachother, and attempt to describe the differences heard. I feel that although this has been done already, it wasn't backed up by cold hard ABX figures as thoroughly as i would've liked. EDIT: This means i'll probably expand this post with a followup later. Last of all, a Big Thanks to ff123 for his wonderful page with resources related to testing, Rjamorim of Rarewares fame for providing the samples and his public testing efforts, Guruboolez for inspiring me with his outstanding work, HydrogenAudio for getting me in to all this in the first place, and Xiph in general and Aoyumi in particular for creating and improving the format that, in my opinion, deserves to rule the world.
