Topic: faad2 hlp.. (Read 2905 times) previous topic - next topic
faad2 hlp..
yup...
can someone plz. give me the full help documenation on faad...
like switches etc..
my help box.. dont show...
bwt.. why is that.. i can use faad2 to decode mp4 in
speeks multifrontend.. but not in ivan/mennos fr.??
faad2 hlp..
Options:
-h    Shows this help screen.
-o X  Set output filename.
-f X  Set output format. Valid values for X are:
        1:  Microsoft WAV format (default).
        2:  RAW PCM data.
-b X  Set output sample format. Valid values for X are:
        1:  16 bit PCM data (default).
        2:  24 bit PCM data.
        3:  32 bit PCM data.
        4:  32 bit floating point data.
        5:  16 bit PCM data (dithered).
        6:  16 bit PCM data (dithered with LIGHT noise shaping).
        7:  16 bit PCM data (dithered with MEDIUM noise shaping).
        8:  16 bit PCM data (dithered with HEAVY noise shaping).
-s X  Force the samplerate to X (for RAW files).
-l X  Set object type. Supported object types:
        0:  Main object type.
        1:  LC (Low Complexity) object type.
        3:  LTP (Long Term Prediction) object type.
        23: LD (Low Delay) object type.
-w    Write output to stdio instead of a file.
Example:
      faad infile.aac
      faad infile.mp4
      faad -o outfile.wav infile.aac
      faad -w infile.aac > outfile.wav
faad2 hlp..
yup...
TnX. menno.
about my second question.. what`s happening..
here is another one:
is the faad decoder.. "compitable" with those encodings.. done
in nero..
faad2 hlp..
Maybe that frontend only allows .aac files and not .mp4? Then it should be updated.
in nero..
Yes, it should be
Menno
faad2 hlp..
yup...
one more..:
would the default -b1.. be used
both inn raw-aac and mp4.. as standard output..
