Topic: Playlist tab hopper. (Read 1762 times) previous topic - next topic
Can anyone make a feature that would change playlist tabs after the last song on a list is done, instead of restarting on the first song in that same tab?
Ex: Tab 1 finishing playing it's last song, so foobar starts playing the first song in tab 2.
Also, it would be cool if while making this, you could set the priority of the tabs so instead of going directly to the next playlist tab, it would go to the playlist tab with the highest priority that hasn't been played yet. Priority would be set numerically by a value of 1-10. Just a thought.
This has been discussed previously (ie just after tabbing was introduced) and the general point made against this is that you can achieve the same end using the Add Playlist option...
I often play games that consume the entire screen, so the add playlist option is out. Besides, it would be alot easier for orginizational purposes to have more than one tab instead of a ginormous single tab, at least in my opinion.
[Edit: Also, the priority number could be set on the fly to allow for current mood to effect what you want to listen to]
