IPB
Playcount Questions
Dark_wizzie
post Sep 17 2014, 18:17
Post #1
Group: Members
I'm using the Foobar playcount plugin that tracks the amount of times I have played a track. I have two questions:
1. Is there a way to directly and manually edit the value?
2. Every time the playcount updates (after listening to the track for 60 seconds), the track list jumps back to the top. Is there any way to prevent this?
Go to the top of the page
+Quote Post
BenB
post Sep 18 2014, 04:40
Post #2
Group: Members
1.
Assuming you're referring to the Playback Statistics component (AKA foo_playcount),
Directly? No. The component has its own database in which it stores the info.
Manually? Yes. You can export the info to the files' tags, edit those values, then import the edited info back into the database (personally, if I were to ever do this, I would remove those tags from the files afterward to remove any chance of accidentally importing outdated info at a later date).
2.
Isn't the obvious answer to remove sorting by play count in the autoplaylist?
Or you could send the items to a standard playlist and listen from it instead.
This post has been edited by BenB: Sep 18 2014, 04:42
+Quote Post
Dark_wizzie
post Sep 18 2014, 07:21
Post #3
Group: Members
QUOTE (BenB @ Sep 17 2014, 20:40) *
2.
It jumps back to the top even when I am sorting the tracks by name, date modified, etc.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 2nd October 2014 - 06:17
