Topic: foo_uie_trackinfo (Read 814568 times) previous topic - next topic
foo_uie_trackinfo
Reply #75
Profiles with playback positions don't report the time unless I double click on the track in the playlist, track advance doesn't update at all.
I'm not sure what you mean by "profiles with playback positions" here. What formatting fields are you trying to use, specifically? None of the %_time_*% fields will work unless you are in now playing mode, or have selected the currently playing track in follow cursor mode.
I understand the need for it to be posible to see the selected track info as well as the currently playing info... possibly could there be a set of tags for currently selected and then currently playing? you could then have 2 instances of track info running with info panels set up for each task? yes? no?
I added the %_trackinfo_dropped%, %_trackinfo_followcursor% and %_trackinfo_nowplaying% tagz for that purpose - so you can use a different formatting for each mode that the panel supports. They're intended to be used like this:
$if(%_trackinfo_nowplaying%,
// we are in playing mode
// formatting string for now playing mode goes here
$if(%_trackinfo_followcursor%,
// formatting for follow cursor mode goes here
$if(%_trackinfo_dropped%,
// formatting code for dropped files goes here
As for multiple instances, when that's done, you will be able to set up each panel independently. Plus a default configuration to fall back on I guess.
foo_uie_trackinfo
Reply #76
Updated for the new ui extension api.
No other new changes/bugfixes for now (yes, I am slack ).
foo_uie_trackinfo
Reply #77
[a href="index.php?act=findpost&pid=256539"][{POST_SNAPBACK}][/a]
is there anyway you could provide us with a link to the older version for beta 3? I'm sticking with beta 3 until the album art panel is updated. thanks.
foo_uie_trackinfo
Reply #78
[a href="index.php?act=findpost&pid=256637"][{POST_SNAPBACK}][/a]
You don't have it already? I'll upload it as soon as I can get to my other computer.
foo_uie_trackinfo
Reply #79
You can grab the old version from here.
foo_uie_trackinfo
Reply #80
[a href="index.php?act=findpost&pid=256701"][{POST_SNAPBACK}][/a]
thanks a lot. I tried the plugin a few days ado, decided its not really something I want (added too much clutter), then deleted it. Yesterday after discovering the panel tabs plugin, I thought I'd give this one another whirl... But I wasn't willing to give up album art so I couldn't upgrade my columns_ui.
foo_uie_trackinfo
Reply #81
phi: great job on the plugin
in fact i'm loving all your plugins
got a question about this one tho
right now i have $if(%_trackinfo_nowplaying%,
setup
but when i move my cursor to another song
it changes to that song
is there a way to make the info stay on the current playing song?
if not, then this is a formal request 8)
foo_uie_trackinfo
Reply #82
[a href="index.php?act=findpost&pid=256733"][{POST_SNAPBACK}][/a]
Ah, I see. No problem.
setup
[a href="index.php?act=findpost&pid=256735"][{POST_SNAPBACK}][/a]
Thanks. Are you sure you're in now playing mode? Double-clicking (or middle-clicking) the panel switches between follow-cursor and now-playing modes.
foo_uie_trackinfo
Reply #83
some suggestion
Can latest version support "$transition" command?
foo_uie_trackinfo
Reply #84
hey when trackinfo is consuming a lot of CPU.
when it is active, that is....
Maybe a memory leak....
amazing plugin.... what i was waiting for since i started using foobar....
foo_uie_trackinfo
Reply #85
[a href="index.php?act=findpost&pid=256770"][{POST_SNAPBACK}][/a]
Are you using word wrap? (for ex. comments, etc...) It happeneed to me, I had to don't display those tags.
foo_uie_trackinfo
Reply #86
when it is active, that is....[a href="index.php?act=findpost&pid=256770"][{POST_SNAPBACK}][/a]
Have you tried turning off "Update every second"? I'm not sure how much effect it has, but at least I don't need that frequent updating myself, so I keep it off.
foo_uie_trackinfo
Reply #87
[a href="index.php?act=findpost&pid=256777"][{POST_SNAPBACK}][/a]
About this one, it's not working for me in stuff like %rating%, where if I change the rating when the song is playing (and being displayed in the panel) it's not changed in the panel, even if I have the update every second enabled. Other stuff (like time, etc...) is working and updated.
About CPU usage "Update every second"? it's not consuming so much here.
foo_uie_trackinfo
Reply #88
progressbar need it
if close it, progressbar won't work.
and play time will be stopped.
foo_uie_trackinfo
Reply #89
some suggestion
[a href="index.php?act=findpost&pid=256751"][{POST_SNAPBACK}][/a]
I may have done something to break it. I'll have a look.
Yeah, thats just due to my inefficient coding. For now all I can suggest is limit the length of each line of info.
[a href="index.php?act=findpost&pid=256796"][{POST_SNAPBACK}][/a]
I forgot to hook up some callbacks that update the panel when a song is edited. Fixed for the next release (whenever I get around to finishing it).
foo_uie_trackinfo
Reply #90
True,
Had word wrap on, update every second on, and i've configured trackinfo to show
the lyrics... and all of my songs are tabbed with lyrics!!!!!!!!!!
But one concern... the previous versionwas fine... something with this one...
well, thanks....
foo_uie_trackinfo
Reply #91
  Phi's right.... ! I came to a very fast conclusion... The slow down happened only to a bunch of mp3's where i have accidently tagged the band's bio as a comment!    any way, I'm back to happy... well eagerly waiting for the next release
foo_uie_trackinfo
Reply #92
setup
[a href="index.php?act=findpost&pid=256743"][{POST_SNAPBACK}][/a]
thanks that worked
lol didn't know i could double click the panel
foo_uie_trackinfo
Reply #93
I'm wonder why it doesn't have scrollbar?
some words will be cut half
foo_uie_trackinfo
Reply #94
foo_uie_trackinfo
Reply #95
If I don't have a mouse-wheel how could I scroll it
foo_uie_trackinfo
Reply #96
[a href="index.php?act=findpost&pid=257113"][{POST_SNAPBACK}][/a]
Maybe clicking once on the panel and up/down keys woudl work, dunno
foo_uie_trackinfo
Reply #97
[a href="index.php?act=findpost&pid=257125"][{POST_SNAPBACK}][/a]
Nah, it's mousewheel only until I get around to adding a scroll bar.
foo_uie_trackinfo
Reply #98
press up/down keys will change the playlist selection
foo_uie_trackinfo
Reply #99
Maybe add enable/disable vertical scroll bar is good
Perhaps some friends don't need it, but some need
