Topic: foo_run (Read 599267 times) previous topic - next topic
foo_run 0.3.7
Reply #75
Many thanks for your work!
I also would like to see the possibility to put the foo_run entires to top level of the context menu. You don't have to put them there as default.
foo_run 0.3.7
Reply #76
How to do Copy Path command ?
foo_run 0.3.7
Reply #77
Is it possible to use relative paths instead of absolute, e.g:
Current:
C:\Program Files\Foobar2000\Addons\Alarm foobar.exe
Wanted:
foo_run 0.3.7
Reply #78
Current:
Wanted:
Well, problem solved. I forgott the quotation marks.
foo_run 0.3.7
Reply #79
does someone know how to configure foo_run to send files via skype (2.5)?
Edit: got it
C:\Programme\Skype\Phone\Skype.exe /sendto:  "%path%"
foo_run 0.3.7
Reply #80
Thanks Infernus ! And is the way to send at once to active skype chat member now listening song with hotkey's ?
foo_run 0.3.7
Reply #81
when you make a global hotkey for this "run service" in combination with "cursor follows playback" mode you should be able to send your now listening song to skype members. A new popup-message from skype appears, there you can select your friends.
foo_run 0.3.7
Reply #82
Just bind the hotkey to the "[context / now playing]" version of the command, then it will always be applied to the currently playing track,
foo_run 0.3.7
Reply #83
But I want to send files direct to active skype chat member(s), without File Send PopUp ...
foo_run 0.3.7
Reply #84
this plugin rocks. many thanks to florian.
Here's my Humble contribution:
Wikipedia Artist
http://en.wikipedia.org/wiki/$replace($caps(%artist%),' ',_)
Wikipedia Album
http://en.wikipedia.org/wiki/$replace($caps(%album%),' ',_)
Mr Questionman (This is just synthetic's script made to work with the default installation directory)
"c:\Program Files\Mr QuestionMan\Mr QuestionMan.exe" "$substr(%_path%,0,$strrchr(%_path%,'\'))
could anyone please share the script for Cover Art Downloader?
foo_run 0.3.7
Reply #85
Wikipedia Artist
Wikipedia Album
for me it's (Single Track):
"C:\Programme\foobar2000\albumart\albumart.exe" "%artist%" "%album%" "$replace(%_path%,%_filename_ext%,)%artist% - %title%.jpg"
and (Complete Album):
"C:\Programme\foobar2000\albumart\albumart.exe" "%artist%" "%album%" "$replace(%_path%,%_filename_ext%,)%album%.jpg"
Not very far fetched, indeed.
"If there 's no soul in the computer's music, it's because nobody put it there." - Björk.
foo_run 0.3.7
Reply #86
@moonwhaler
Using your full album script. works like a charm.
thanks
foo_run 0.3.7
Reply #87
Is there currently a problem with linking a button to a run service?  I am new to this plugin so I may be missing something I dunno.
Goal: Create a button that re-launches mini-lyrics.
I used the following code to setup a run service:
C:\Program Files\Minilyrics\MLStart.exe
I customized the button to load the appropriate "Run service/".
If I right click on a track and choose run> minilyrics everything runs as expected so I dont think I have the run service code wrong (though I did try
it enclosed in both single and double quotes). However, whenever I click on my button nothing happens.
EDIT: I created another service with the source of http://www.shoutcast.com/ but again the right-click menu works but any buttons linked to the service do nothing.
foo_run 0.3.7
Reply #88
Here a little workaround for people who want to tag mp3 files with ID3 v2.3:
You can use a runservice for an external Masstagger:
MP3BookHelper
also great to generate automatically m3u-playlists, sfv-files, nfo-files, move/nename files,.............
open selected file
C:\Programme\MP3BookHelper\MP3BookHelper.exe "%path%"
open all files from folder
C:\Programme\MP3BookHelper\MP3BookHelper.exe "$substr(%_path%,0,$strrchr(%_path%,'\'))"
foo_run 0.3.7
Reply #89
Can someone explain me (or link me to a page) that explains HOW to use that plugin?
http://eolindel.free.fr/foobar0.9/albumart.shtml
I'm trying to use this tutorial to have albu art display in my player but I am stuck at the part where I need to use foo_run.
The "search cover" thing just won't appear in the services list. I try to add one and then edit label name and path but when I click on save all it doesn't save it...
edit: crap, I just figured out how to use the modify button... sorry for being such a newb!
foo_run 0.3.7
Reply #90
But if that were possible, it would be equally so easy for a virus to utitlise the function!
Does anybody know of either
a)similar functionality to Skype with gaim,
b)an FTP client that could send the whole directory to a predefined server?
foo_run 0.3.7
Reply #91
* Feature request
If its possible, a enable/disable box for services ? and a way to manually sort services too ? thanks for your tim e and keep up the great work.
You're talking to my guy all wrong... It's the wrong tone. Say it again, and i'll stab you in the face with a soldering iron!
foo_run 0.3.7
Reply #93
two questions or better a wishlist
I) is it possible to access the foobar converter as runservie incl. set settings for that via code?
II) "batch"-mode possible`?
The idea was to do something like that with one click:
IF(subsong > 0 THAN Convert to MP3/128kb + send temporary file via skype ELSE send selected file)
foo_run 0.3.7
Reply #94
Awhile back in post #88 I indicated a problem with linking a button to a runservice. Well I discovered the solution and thought I'd share:
When linking a button to a runservice, the default "Item Group" is set to None. You need to set it to Now playing item in order for the button to work. You can also use Current playlist selection but that will only work if an item is selected in your playlist (no item selected, button doesnt work).
The button will work if you select Now playing item wether a song is playing or not, so you should choose this option.
Edit: As of foobar 0.9.3, foobar will crash hard if you click on a button linked to a runservice with an Item Group of "Now playing item" and there is no item playing. You may want to consider linking the button to "Current playlist selection" instead. If you do, the button will not work if no item is selected but atleast foobar wont crash. An Item Group of "None" still makes the button non-functional.
foo_run 0.3.7
Reply #95
First of all. Great plugin. Thanks.
Second.....
Can someone give me a string that searches google image for %artist% and %album% ?
I've been trying for 20 minutes.
foobar2000 + EAC + Burrrn = Happiness
foo_run 0.3.7
Reply #96
You'll probably need to modify this to handle any special characters, but this should get you started:
http:$char(47)$char(47)google.com$char(47)musicsearch?q=$replace(%artist%$if2( %album%,), ,+)
EDIT: Sorry, the above code is for Google Music, you asked for Google Images try this:
http:$char(47)$char(47)images.google.com$char(47)images?q=$replace(%artist%$if2( %album%,), ,$char(37)20)
foo_run 0.3.7
Reply #97
Thanks. This works.
foo_run 0.3.7
Reply #98
a few web services i use in opera search:
discogs Artist  Album
http://www.discogs.com/search?type=all&q=$replace(%artist%, ,+)&btn=Search
http://www.discogs.com/search?type=releases&q=$replace(%album%, ,+)&btn=Search
musicbrainz Artist  Album
http://musicbrainz.org/search/textsearch.html?query=$replace(%artist%, ,+)&type=artist&an=1&as=1&aa=1&limit=100&handlearguments=1
http://musicbrainz.org/search/textsearch.html?query=$replace(%album%, ,+)&type=release&an=1&as=1&limit=100&handlearguments=1
kompaktkiste Artist
http://www.google.com/search?as_q=$replace(%artist%, ,+)&as_sitesearch=www.kompaktkiste.de&safe=off&num=100
sternsmusic Artist
http://www.sternsmusic.com/search_results.php?search=Artist&prmm=$replace(%artist%, ,+)&dvd=on&music=on&video=on&book=checkbox
imdb Album
http://www.imdb.com/find?q=$replace(%album%, ,+)
foo_run 0.3.7
Reply #99
Is any command to add songs directly to nero from foobar2000 ?  If I want burn mp3 cd, it's take from me a lot of time ...
