IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Fading doesn't seem to work
romor
post Apr 26 2014, 09:21
Post #1
Group: Members
I would assume this should work on primary driver.
Just in case I also disabled any DSP, but can't hear nor see any fading in any case (automatic track change, manual track change, seek...)
What could be the problem?
This post has been edited by romor: Apr 26 2014, 09:23
scripts: http://goo.gl/M1qVLQ
Go to the top of the page
+Quote Post
Case
post Apr 26 2014, 09:51
Post #2
Group: Developer (Donating)
Note that foobar2000 doesn't strip silence away from your files. Typical tracks for example fade to silence and often have a longish silent ending. With such a track there's nothing to work with.
Your screenshot looks like there's no fades at all though. Just abrupt ending. Is it a bad rip where for example EAC's offset corrections are used incorrectly making it eat parts of the files away?
You could still get audible fades if you increase your buffer length and make fades longer. Or use a DSP that removes silence from the tracks. You could also try it with some albums that play back gaplessly to hear the effect with your current settings.
+Quote Post
romor
post Apr 26 2014, 10:12
Post #3
Group: Members
QUOTE (Case @ Apr 26 2014, 09:51) *
Yes, no fades at all.
I don't think it's a bad rip problem. I tried various file formats, but it's like this feature simply isn't working here.
I increased buffer length, but still the same.
The silence in the screenshot is tiny, which I'm not much concerned about. I choose it as example as it was easier to spot no fade.
Assuming this feature works as expected elsewhere, let me note that this is on-board audio on P35 platinum MB, with default Windows hdaudio driver.
If there are other information I should provide, let me know.
+Quote Post
lvqcl
post Apr 26 2014, 10:41
Post #4
Group: Developer
AFAIK fading is performed by the OS, so it's not possible to see its effect on spectrogram.
Also I can hear the effect of fading: two tracks overlap, the first starts to fade out, the second starts to fade in (Win7 SP1, X-Fi Gamer).
This post has been edited by lvqcl: Apr 26 2014, 10:43
+Quote Post
romor
post Apr 26 2014, 11:36
Post #5
Group: Members
Sorry, I deleted nonsense message
It's like lvqcl wrote - "fading is performed by the OS, so it's not possible to see its effect on spectrogram"
Fading now works fine.
I installed Realtek driver, and restarted two times. That's all I know.
This post has been edited by romor: Apr 26 2014, 12:31
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th August 2014 - 08:40
