Topic: Is LAME threadsafe? (Read 5553 times) previous topic - next topic
Is LAME threadsafe?
HI ALL
          1. ANY ONE CAN TELL ME THAT LAME IS THREAD SAFE OR NOT?????????????????
          2. I AM USING LAME 3.97 IN RED HAT.
              SO I AM ENCODING RAW SAMPLES AND CREATE MP3 FILES
              I AM USING sample Rate=16khz bit Rate =32kbps
              (also the RAW samples are acquired from DAQ card at a SampleRate=32000)
              but the quality I recieved is not too good and also the volume is too low than orignal voice.
              SO WHAT CAN BE DONE TO IMPROVE THE THINGS.
                    I WILL WAITING FOR UR RESPONSE. THANKS
Is LAME threadsafe?
Thread title amended and topic moved.
I'm tempted to remove the shouting as well, but frankly can't be bothered.
Please re-read the TOS.
I'm on a horse.
Is LAME threadsafe?
NO WE CANNOT TELL YOU BECAUSE YOU ARE STILL NOT LOUD ENOUGH AND DID NOT POST THE QUESTION IN ENOUGH THREADS WITH A DEMANDING ENOUGH TONE YET!!!
Is LAME threadsafe?
I think this thread is kinda bump:
[a href='index.php?showtopic=53053']Lame 3.97 is thread safe or not?[/a]
Is LAME threadsafe?
Thanks for the info Egor.  Other thread deleted.
I'm on a horse.
Is LAME threadsafe?
here is properly "cased"
Hi all
1. Any one can tell me that lame is thread safe or not?????????????????
2. I am using lame 3.97 in red hat.
So i am encoding raw samples and create mp3 files
I am using sample rate=16khz bit rate =32kbps
So what can be done to improve the things.
I will waiting for ur response. Thanks.
Is LAME threadsafe?
How is that related to multithreading?
Also I have a dumb question, did you try to encode without threads? Did it work better?
Is LAME threadsafe?
Although quite obvious 32kps is quite low and not really suited to lame encoding try raising the bitrate or use another codec. There are some topics in the Mp3 tech forum about speech encoding at low bitrates for audio books that experiment with a few settings to improve quality. Try search for those.
Is LAME threadsafe?
YES LAME IS THREAD SAFE IN FACT IS IT VERY THREAD SAFE. THANKS
err... i'm not using windows any more ;)
Is LAME threadsafe?
IT IS VERY VERY SAFE
IN FACT IT IS NOT JUST THREAD SAFE IT IS ROPE SAFE
THANK YOU
Is LAME threadsafe?
IS IT WOOD SAFE
I NEED TO KNOW I USE WOOD FOR MY OPERATION
Is LAME threadsafe?
I can't imagine the quality will be good if you're encoding a 32kHz sampled piece for 16 kHz.
