Topic: is a good idea resample before burning? (Read 5376 times) previous topic - next topic
Hi
i use foobar v1.1.17  to play music and i love this componet foo_dsp_resampler.dll normal version 0.8.1
i set up foobar output 32bit and resampler @ 96000 quality best , passband 95 ,disabled allow aliasing , phase response 50
and i really love the output
i use a densen amp and seneizer
now my super noob question
is a good idea  convert from mp3 320kb to wav and use the resampler to have a better audio in the burned cd?
thanks
Absolutely not! This would result in being resampled twice, unnecssarily.
The output of the mp3 decoder is already 44.1 kHz (I am assuming that the source material was redbook CD). All it needs is a little dither (and even that is not really necessary), and it is ready to burn.
No. You won't gain anything.
Error 404; signature server not available.
Be careful not to claim that this improves the sound. You would then be required to submit DBT as proof.
Actually, he did not say it improved, just that he really loves the output. Be careful so not to make members worried. What he said would be to throw a TOS #8 at someone for just saying they "like vinyl". Maybe he likes artifacts from resampling. Regards.
What artifacts?
may i ask which dither setting?
in foobar for example i have never , lossy source only , alway
thanks
thanks
i said that foobar with that settings sounds really better for me
in short i would love to have the same output on my cd
by the way there are several cd recorded at 24bit
francesco, just burn the MP3s as-is; the answer to your question is no, you can't improve their quality through resampling. Even with foo_dsp_resampler, you are essentially doing a neutral transformation, leaving the waveform shape, and thus the sound, exactly the same, but changing the scale and type of numbers used to represent it, as well as massively bloating the quantity of data. Any audible improvement you perceive has to either be the placebo effect, or the result of some unrelated issue (bad resampling happening in your soundcard when you feed it 44.1 KHz, maybe). Besides, if you were to try to feed a bloated, weirdly scaled WAV to your burning software (if the software accepts it at all), the audio is just going to be downsampled back to 16-bit integer, 44100 KHz by the software, because that's all that is allowed on an audio CD.
thanks mjb2006
even my english  sucks (  ) i got the answer
