Topic: foo_input_tak (Read 251431 times) previous topic - next topic
0 Members and 16 Guests are viewing this topic.
foo_input_tak
TAK decoder plugin for foobar2000 0.9.4 and newer.
Supports playback and tagging. No special support for recovery of damaged TAK files. Version 0.2 uses functions from the foobar2000 SDK to access APEv2 tags instead of the functions provided by the TAK SDK.
The component can be downloaded from my components page.
foo_input_tak
can I be the first to say thank you? I guess so. Thank you!
foo_input_tak
Thank you, it works!
"don't gimme no lip" - pearl jam
foo_input_tak
You are my hero! Thank you
foo_input_tak
Thank you so much.
foo_input_tak
*pumps fist*
Thank you foosion.  I've been looking forward to this.
foo_input_tak
Probably my first post here:
THANK YOU!!!!!!!!!
foo_input_tak
Nice one foosion, thanks! B)
Allegari nihil et allegatum non probare, paria sunt.
foo_input_tak
Something strange is happening ;.tak-plugin works with my foobar only after I reinstall foobar.I can't shut foobar down,
'cause after startin' it,it say's Module "foo_input_tak.dll" has been removed since last run.Would you like to keep its settings?
and after that
Failed to load DLL: foo_input_tak.dll
And I can't simply add plugin,'cause Failed to load DLL: foo_input_tak.dll
Reason:
But after reinstall works fine ...
till  the next shutdown foobar.
Maybe I'm stupid or messing something up ...,
mea culpa,but it's really weird.
foo_input_tak
I don't really understand about the reinstall bit, but do you have tak_deco_lib.dll in your foobar folder?
I don't now, I'm finding it difficult to understand your post.
What version of foobar are you running?
I'm on a horse.
foo_input_tak
@Skorzeney
Stupid question but, are you using foobar 0.9?
foo_input_tak
When I transcode to tak in foobar converter the tagging progress takes a long time (about 30 seconds) is this normal, the plug-ins fault or is it just my commandline (-e -pH %s %d)?
I just like listening to music
foo_input_tak
Are you sure it's not the WAVE to TAK conversion that's taking the time?
IIRC when using a temporary WAVE the progress bar depicts the decoding to WAVE, and not the encoding, which is undertaken with a full progress bar.
I'm on a horse.
foo_input_tak
It's probably because TAK needs a completely decoded file (%s) to start enconding, as opposed to encoders that accept pipe (-) and start encoding as soon as the file starts being decoded.
EDIT: Synthetic Soul got it before me
foo_input_tak
Oh, I thought the wav conversation was included in the progress bar, but that explains everything. Thanks for quick response.
foo_input_tak
Foobar crashes when tagging large number of files (I've experienced this error two times now. First time was when i was Replay Gaining  a whole bunch of TAK files- Foobar crashed while updating tags. The more recent was when i was adding a comment value to ~2000 tak files).
Here's the Crash Log:
Illegal operation:
Code: 0EEDFADEh, flags: 00000001h, address: 7C812A5Bh
Call path:
threaded_process thread
Code bytes (7C812A5Bh):
7C812A1Bh:  8B 45 0C 56 8B 75 14 83 E0 01 85 F6 89 45 B4 C7
7C812A2Bh:  45 BC 09 2A 81 7C 0F 84 99 00 00 00 8B 4D 10 83
7C812A3Bh:  F9 0F 0F 87 4D 1D 03 00 85 C9 89 4D C0 74 07 57
7C812A4Bh:  8D 7D C4 F3 A5 5F 8D 45 B0 50 FF 15 08 15 80 7C
7C812A5Bh:  5E C9 C2 10 00 85 FF 0F 8E 36 93 FF FF 8B 55 FC
7C812A6Bh:  89 55 0C 0F B7 16 8B 7D F8 8A 14 3A 88 11 8B 78
7C812A7Bh:  0C 0F B6 D2 66 8B 14 57 66 3B 16 0F 85 A3 89 03
7C812A8Bh:  00 8B 50 08 66 8B 5A 04 38 19 0F 84 A1 89 03 00
Stack (0790FB90h):
0790FB70h:  0012F438 7E4237BC 00000000 0000000C
0790FB80h:  00000000 003C4CC0 00000000 0012F464
0790FB90h:  013D2700 0EEDFADE 00000001 00000000
0790FBA0h:  7C812A5B 00000007 013D2700 01400470
0790FBB0h:  013D2700 013D2700 01512468 0790FC70
0790FBC0h:  0790FC18 00013CE8 00000000 014BC000
0790FBD0h:  00004000 014BC000 00170474 013D1E0E
0790FBE0h:  4BC00001 0790FC70 013D2700 0EEDFADE
0790FBF0h:  00000001 00000007 0790FBFC 013D2700
0790FC00h:  01400470 013D2700 013D2700 01512468
0790FC10h:  0790FC70 0790FC18 00000002 013D27A0
0790FC20h:  014666B0 0000000B 013D2700 01466798
0790FC30h:  013D330D 00000001 013D36CD 013D3346
0790FC40h:  013D3353 013F19FB 01427E58 01427E58
0790FC50h:  013D3353 013F21E4 20FE0001 013F2BED
0790FC60h:  01512418 015123C0 013D3353 013F346B
0790FC70h:  0790FCE0 01394BC4 01427E58 FF6DE52A
0790FC80h:  00000000 015123B8 0000022E 0790FCA8
0790FC90h:  013A4E58 FFFFFFFF 01394B16 015123C0
0790FCA0h:  FF6DE50E 015123B8 0790FCD4 013A4F48
Registers:
EAX: 0790FB94, EBX: 013D2700, ECX: 00000000, EDX: 013D2700
ESI: 0790FC18, EDI: 01512468, EBP: 0790FBE4, ESP: 0790FB90
Crash location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RaiseException" (+00000052h)
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
LVPrcInj                        loaded at 003E0000h - 003F7000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
RocketDock                      loaded at 00550000h - 00562000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
foo_ac3                          loaded at 00580000h - 005AF000h
foo_audioscrobbler              loaded at 00AF0000h - 00B27000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 00B70000h - 00BA0000h
foo_benchmark                    loaded at 00BB0000h - 00BD8000h
foo_bitcompare                  loaded at 00C00000h - 00C27000h
foo_cdda                        loaded at 00C50000h - 00C86000h
foo_common                      loaded at 00CB0000h - 00CE3000h
foo_converter                    loaded at 00D10000h - 00D79000h
foo_cwb_hooks                    loaded at 00DA0000h - 00DD5000h
foo_dbsearch                    loaded at 00E00000h - 00E70000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_discogs                      loaded at 00E90000h - 00F0C000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_dsp_dolbyhp                  loaded at 00FB0000h - 00FD1000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_dsp_std                      loaded at 00FF0000h - 01031000h
foo_freedb2                      loaded at 01060000h - 010A0000h
foo_input_alac                  loaded at 010C0000h - 010DD000h
foo_input_dts                    loaded at 01100000h - 01165000h
foo_input_monkey                loaded at 01190000h - 011D9000h
foo_input_shorten                loaded at 01200000h - 0122D000h
foo_input_std                    loaded at 01250000h - 01364000h
foo_input_tak                    loaded at 01390000h - 013B9000h
tak_deco_lib                    loaded at 013D0000h - 013FF000h
foo_masstag                      loaded at 01520000h - 01570000h
foo_playcount                    loaded at 01590000h - 015B8000h
foo_rgscan                      loaded at 015E0000h - 01628000h
foo_run                          loaded at 01650000h - 0167B000h
foo_scrobblecharts              loaded at 016A0000h - 016D3000h
WININET                          loaded at 771B0000h - 77256000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_uie_albumart                loaded at 01700000h - 0173C000h
foo_uie_albumlist                loaded at 01760000h - 0179D000h
foo_uie_console                  loaded at 017D0000h - 017EB000h
foo_uie_tabs                    loaded at 01810000h - 01836000h
foo_uie_trackinfo_mod            loaded at 01860000h - 018B6000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_ui_columns                  loaded at 018E0000h - 01977000h
foo_unpack                      loaded at 019A0000h - 019CE000h
foo_utils                        loaded at 019F0000h - 01A29000h
foo_verifier                    loaded at 01A50000h - 01A80000h
DolbyHph                        loaded at 03300000h - 033FC000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
iphlpapi                        loaded at 76D60000h - 76D79000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
DSOUND                          loaded at 73F10000h - 73F6C000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
dciman32                        loaded at 73BC0000h - 73BC6000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
shdocvw                          loaded at 7E290000h - 7E3FF000h
CRYPTUI                          loaded at 754D0000h - 75550000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
Secur32                          loaded at 77FE0000h - 77FF1000h
appHelp                          loaded at 77B40000h - 77B62000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
browseui                        loaded at 75F80000h - 7607D000h
SETUPAPI                        loaded at 77920000h - 77A13000h
USERENV                          loaded at 769C0000h - 76A73000h
LINKINFO                        loaded at 76980000h - 76988000h
ntshrui                          loaded at 76990000h - 769B5000h
ATL                              loaded at 76B20000h - 76B31000h
MPR                              loaded at 71B20000h - 71B32000h
drprov                          loaded at 75F60000h - 75F67000h
ntlanman                        loaded at 71C10000h - 71C1E000h
NETUI0                          loaded at 71CD0000h - 71CE7000h
NETUI1                          loaded at 71C90000h - 71CD0000h
NETRAP                          loaded at 71C80000h - 71C87000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
davclnt                          loaded at 75F70000h - 75F79000h
PortableDeviceApi                loaded at 10930000h - 10979000h
MSGINA                          loaded at 75970000h - 75A67000h
WINSTA                          loaded at 76360000h - 76370000h
ODBC32                          loaded at 74320000h - 7435D000h
odbcint                          loaded at 20000000h - 20017000h
xpsp2res                        loaded at 04DA0000h - 05065000h
sti                              loaded at 73BA0000h - 73BB3000h
CFGMGR32                        loaded at 74AE0000h - 74AE7000h
IMM32                            loaded at 76390000h - 763AD000h
urlmon                          loaded at 7E1E0000h - 7E280000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 013D2700h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 7C812A5Bh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Address: 013D1E0Eh, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D27A0h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D330Dh, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D36CDh, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D3346h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D3353h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013F19FBh, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013F21E4h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013F2BEDh, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013F346Bh, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Symbol: "tak_SSD_Destroy" (+0000000Fh)
Address: 01394BC4h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013A4E58h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 01394B16h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013A4F48h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013947EDh, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013A4F70h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 0043AE70h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7008h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00DB88D5h, location: "foo_cwb_hooks", loaded at 00DA0000h - 00DD5000h
Address: 004BE970h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 018A1120h, location: "foo_uie_trackinfo_mod", loaded at 01860000h - 018B6000h
Address: 004AF987h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045D460h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00486410h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C42A8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004A86ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045D414h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6459h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 0045D3EFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Database Search 1.4  (foo_dbsearch)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Shorten decoder 0.4.2a  (foo_input_shorten)
Album list panel 0.2.1  (foo_uie_albumlist)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
AC3 decoder 0.9  (foo_ac3)
Binary Comparator 1.1  (foo_bitcompare)
Console panel 0.2.1  (foo_uie_console)
Dolby Headphone Wrapper 1.1  (foo_dsp_dolbyhp)
freedb Tagger 0.5.2a  (foo_freedb2)
Discogs Tagger 0.99  (foo_discogs)
FLAC Decoder 1.1.0  (foo_input_std)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
ZIP/GZIP reader 1.0  (foo_unpack)
Masstagger 1.6  (foo_masstag)
ALAC Decoder 1.0  (foo_input_alac)
TAK Decoder 0.2  (foo_input_tak)
Common services 0.1  (foo_common)
CD Audio Decoder 2.1.1  (foo_cdda)
Playlist tools 0.5.7  (foo_utils)
Playback Statistics 1.3.2  (foo_playcount)
DTS decoder 0.1.7  (foo_input_dts)
Standard DSP array 1.0  (foo_dsp_std)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
File Integrity Verifier 1.0.1  (foo_verifier)
RAR reader 1.1  (foo_unpack)
Album Art Panel 0.2.6  (foo_uie_albumart)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
WMA Decoder 1.1  (foo_input_std)
Decoding Speed Test 1.0  (foo_benchmark)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
foobar2000 core 0.9.4.2  (Core)
Converter 1.0.1  (foo_converter)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Audioscrobbler 1.3.5  (foo_audioscrobbler)
Run services 0.3.2  (foo_run)
here's the file that windows wanted to send as "error reporting"
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="foobar2000.exe" FILTER="GRABMI_FILTER_PRIVACY">
    <MATCHING_FILE NAME="DolbyHph.dll" SIZE="671744" CHECKSUM="0x67D7CCBD" BIN_FILE_VERSION="1.10.0.270" BIN_PRODUCT_VERSION="1.10.0.270" PRODUCT_VERSION="1.10.0270" FILE_DESCRIPTION="Dolby Headphone Engine" COMPANY_NAME="Lake Technology Limited, [url=http://www.lake.com.au%22]http://www.lake.com.au"[/url] PRODUCT_NAME="Dolby Headphone" FILE_VERSION="1.10.0270" ORIGINAL_FILENAME="DolbyHph.dll" INTERNAL_NAME="DHW98-x86-01" LEGAL_COPYRIGHT="Copyright © 1998-2000 Lake Technology Ltd" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA94F0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.10.0.270" UPTO_BIN_PRODUCT_VERSION="1.10.0.270" LINK_DATE="07/09/2002 09:44:00" UPTO_LINK_DATE="07/09/2002 09:44:00" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="foobar2000.exe" SIZE="966656" CHECKSUM="0xDB112205" BIN_FILE_VERSION="0.9.4.1" BIN_PRODUCT_VERSION="0.9.4.1" PRODUCT_VERSION="0, 9, 4, 1" FILE_DESCRIPTION="foobar2000 Application" PRODUCT_NAME=" foobar2000 Application" FILE_VERSION="0, 9, 4, 1" ORIGINAL_FILENAME="foobar2000.exe" INTERNAL_NAME="foobar2000" LEGAL_COPYRIGHT="Copyright © 2006 Peter Pawlowski" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF8A7E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.9.4.1" UPTO_BIN_PRODUCT_VERSION="0.9.4.1" LINK_DATE="11/25/2006 13:21:35" UPTO_LINK_DATE="11/25/2006 13:21:35" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="lame.exe" SIZE="520192" CHECKSUM="0xCF69077B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="10/03/2006 13:33:51" UPTO_LINK_DATE="10/03/2006 13:33:51" />
    <MATCHING_FILE NAME="libcurl.dll" SIZE="258048" CHECKSUM="0x251AB62" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="08/12/2006 11:50:29" UPTO_LINK_DATE="08/12/2006 11:50:29" />
    <MATCHING_FILE NAME="libmmd.dll" SIZE="2084956" CHECKSUM="0xE9ED08CA" BIN_FILE_VERSION="8.1.8.2" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="8.1" FILE_DESCRIPTION="Math Library for Intel® Compilers (thread-safe)" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel® C Compiler, Intel® C++ Compiler, Intel® Fortran Compiler" FILE_VERSION="8.1.8.2" ORIGINAL_FILENAME="libmmd.dll" INTERNAL_NAME="libmmd.dll" LEGAL_COPYRIGHT="Copyright © 1985-2004 Intel Corporation" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.1.8.2" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="07/27/2004 05:15:23" UPTO_LINK_DATE="07/27/2004 05:15:23" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="shared.dll" SIZE="141824" CHECKSUM="0xEAEE1B50" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D1AE" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:17:12" UPTO_LINK_DATE="11/25/2006 13:17:12" />
    <MATCHING_FILE NAME="Takc.exe" SIZE="267264" CHECKSUM="0x24DA1AEB" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" />
    <MATCHING_FILE NAME="tak_deco_lib.dll" SIZE="169472" CHECKSUM="0x4FFD29AA" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="TAK Decoder Library" COMPANY_NAME="Thomas Becker, Osnabrueck" PRODUCT_NAME="TAK Lossless Audio Compressor" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="tak_deco_lib.dll" INTERNAL_NAME="" LEGAL_COPYRIGHT="© 2006 by Thomas Becker, Osnabrueck, Germany" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="uninstall.exe" SIZE="61900" CHECKSUM="0xB136A043" BIN_FILE_VERSION="0.9.0.0" BIN_PRODUCT_VERSION="0.9.0.0" FILE_DESCRIPTION="foobar2000" COMPANY_NAME="foobar2000.org" PRODUCT_NAME="foobar2000" FILE_VERSION="0.9.4.2" ORIGINAL_FILENAME="foobar2000_0.9.4.2.exe" LEGAL_COPYRIGHT="© Peter Pawlowski. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.9.0.0" UPTO_BIN_PRODUCT_VERSION="0.9.0.0" LINK_DATE="07/01/2006 18:05:54" UPTO_LINK_DATE="07/01/2006 18:05:54" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="wavpack.exe" SIZE="200704" CHECKSUM="0xAD0D858E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3D110" LINKER_VERSION="0x0" LINK_DATE="02/09/2007 06:29:19" UPTO_LINK_DATE="02/09/2007 06:29:19" />
    <MATCHING_FILE NAME="zlib1.dll" SIZE="75264" CHECKSUM="0x67122D66" BIN_FILE_VERSION="1.2.3.2027" BIN_PRODUCT_VERSION="1.2.3.2027" PRODUCT_VERSION="1.2.3.2027" FILE_DESCRIPTION="Zlib: general purpose data compression / decompression library" COMPANY_NAME="Zlib" PRODUCT_NAME="Zlib" FILE_VERSION="1.2.3.2027" ORIGINAL_FILENAME="zlib1.dll" INTERNAL_NAME="zlib1" LEGAL_COPYRIGHT="© 2005 Jean-loup Gailly &lt;jloup@gzip.org &gt;, Mark Adler &lt;madler@alumni.caltech.edu&gt;" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2129E" LINKER_VERSION="0x10002" UPTO_BIN_FILE_VERSION="1.2.3.2027" UPTO_BIN_PRODUCT_VERSION="1.2.3.2027" LINK_DATE="07/20/2005 16:05:43" UPTO_LINK_DATE="07/20/2005 16:05:43" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Baggage\UberView118.exe" SIZE="31232" CHECKSUM="0xE1548349" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="10/20/2006 09:11:04" UPTO_LINK_DATE="10/20/2006 09:11:04" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\AlbumArt.exe" SIZE="294912" CHECKSUM="0xE3D141A6" BIN_FILE_VERSION="0.5.0.0" BIN_PRODUCT_VERSION="0.5.0.0" PRODUCT_VERSION="0.5.0.0" FILE_DESCRIPTION="Album Art Downloader" COMPANY_NAME="Marc Landis, Alex Vallat" PRODUCT_NAME="Album Art Downloader" FILE_VERSION="0.5.0.0" ORIGINAL_FILENAME="AlbumArt.exe" INTERNAL_NAME="AlbumArt.exe" LEGAL_COPYRIGHT="Copyright © Marc Landis, Alex Vallat 2007 / Damage, Inc. 2005" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.5.0.0" UPTO_BIN_PRODUCT_VERSION="0.5.0.0" LINK_DATE="01/20/2007 21:01:19" UPTO_LINK_DATE="01/20/2007 21:01:19" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\ATL.dll" SIZE="147456" CHECKSUM="0x755B6E77" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="ATL" COMPANY_NAME="eBay, Inc." PRODUCT_NAME="ATL" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="ATL.dll" INTERNAL_NAME="ATL.dll" LEGAL_COPYRIGHT="Copyright © eBay, Inc. 2007" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="01/20/2007 21:01:15" UPTO_LINK_DATE="01/20/2007 21:01:15" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\Boo.Lang.Compiler.dll" SIZE="552960" CHECKSUM="0x22FF572F" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="boo - an extensible programming language for the CLI" PRODUCT_NAME="boo - an extensible programming language for the CLI" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Boo.Lang.Compiler.dll" INTERNAL_NAME="Boo.Lang.Compiler.dll" LEGAL_COPYRIGHT="© 2003-2005 Rodrigo Barreto de Oliveira" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x95D58" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="04/24/2006 16:08:52" UPTO_LINK_DATE="04/24/2006 16:08:52" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\Boo.Lang.dll" SIZE="69632" CHECKSUM="0xE9C8F42C" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="boo - an extensible programming language for the CLI" PRODUCT_NAME="boo - an extensible programming language for the CLI" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Boo.Lang.dll" INTERNAL_NAME="Boo.Lang.dll" LEGAL_COPYRIGHT="© 2003-2005 Rodrigo Barreto de Oliveira" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1B48F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="04/24/2006 16:08:46" UPTO_LINK_DATE="04/24/2006 16:08:46" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\Boo.Lang.Parser.dll" SIZE="405504" CHECKSUM="0x2D6F1A82" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION="boo antlr based parser" PRODUCT_NAME="boo - an extensible programming language for the CLI" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Boo.Lang.Parser.dll" INTERNAL_NAME="Boo.Lang.Parser.dll" LEGAL_COPYRIGHT="© 2003-2005 Rodrigo Barreto de Oliveira" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6D415" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="04/24/2006 16:09:01" UPTO_LINK_DATE="04/24/2006 16:09:01" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\Interop.Foobar2000.dll" SIZE="49152" CHECKSUM="0x65FA11B0" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME="Assembly imported from type library Foobar2000" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Interop.Foobar2000.dll" INTERNAL_NAME="Interop.Foobar2000" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="01/10/2007 12:23:47" UPTO_LINK_DATE="01/10/2007 12:23:47" VER_LANGUAGE="Invariant Language (Invariant Country) [0x7f]" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\Interop.Foobar2000Helper.dll" SIZE="7168" CHECKSUM="0xECB89ABF" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0.0.0" FILE_DESCRIPTION=" " COMPANY_NAME=" " PRODUCT_NAME="Assembly imported from type library Foobar2000Helper" FILE_VERSION="1.0.0.0" ORIGINAL_FILENAME="Interop.Foobar2000Helper.dll" INTERNAL_NAME="Interop.Foobar2000Helper" LEGAL_COPYRIGHT=" " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="01/10/2007 12:23:47" UPTO_LINK_DATE="01/10/2007 12:23:47" VER_LANGUAGE="Invariant Language (Invariant Country) [0x7f]" />
    <MATCHING_FILE NAME="Baggage\AlbumArtDownloader\Scripts\scriptcache.dll" SIZE="28672" CHECKSUM="0x37B4F0E8" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="03/27/2007 19:40:07" UPTO_LINK_DATE="03/27/2007 19:40:07" />
    <MATCHING_FILE NAME="components\foo_ac3.dll" SIZE="165888" CHECKSUM="0x4F9C516C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x30E87" LINKER_VERSION="0x0" LINK_DATE="02/07/2007 03:12:54" UPTO_LINK_DATE="02/07/2007 03:12:54" />
    <MATCHING_FILE NAME="components\foo_audioscrobbler.dll" SIZE="201216" CHECKSUM="0xA6794D29" BIN_FILE_VERSION="1.3.5.0" BIN_PRODUCT_VERSION="1.3.5.0" PRODUCT_VERSION="1, 3, 5, 0" FILE_DESCRIPTION="foo_audioscrobbler" PRODUCT_NAME=" foo_audioscrobbler" FILE_VERSION="1, 3, 5, 0" ORIGINAL_FILENAME="foo_audioscrobbler.dll" INTERNAL_NAME="foo_audioscrobbler" LEGAL_COPYRIGHT="Copyright © 2004 Russ Garrett, © 2006 Florian Heidenreich" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3783B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.3.5.0" UPTO_BIN_PRODUCT_VERSION="1.3.5.0" LINK_DATE="12/20/2006 19:53:37" UPTO_LINK_DATE="12/20/2006 19:53:37" VER_LANGUAGE="English (United Kingdom) [0x809]" />
    <MATCHING_FILE NAME="components\foo_autoplaylist.dll" SIZE="177664" CHECKSUM="0xAF9ACB8B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x37716" LINKER_VERSION="0x0" LINK_DATE="08/04/2006 19:56:55" UPTO_LINK_DATE="08/04/2006 19:56:55" />
    <MATCHING_FILE NAME="components\foo_benchmark.dll" SIZE="142336" CHECKSUM="0x76F3AA00" MODULE_TYPE="WIN32" PE_CHECKSUM="0x30C36" LINKER_VERSION="0x0" LINK_DATE="08/04/2006 19:56:57" UPTO_LINK_DATE="08/04/2006 19:56:57" />
    <MATCHING_FILE NAME="components\foo_bitcompare.dll" SIZE="140288" CHECKSUM="0xE1F84B0A" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D050" LINKER_VERSION="0x0" LINK_DATE="08/04/2006 19:56:50" UPTO_LINK_DATE="08/04/2006 19:56:50" />
    <MATCHING_FILE NAME="components\foo_cdda.dll" SIZE="199168" CHECKSUM="0x9CE658ED" MODULE_TYPE="WIN32" PE_CHECKSUM="0x30E3A" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:19:47" UPTO_LINK_DATE="11/25/2006 13:19:47" />
    <MATCHING_FILE NAME="components\foo_common.dll" SIZE="188928" CHECKSUM="0x41448DD8" BIN_FILE_VERSION="0.2.0.0" BIN_PRODUCT_VERSION="0.2.0.0" PRODUCT_VERSION="0, 2, 0, 0" FILE_DESCRIPTION="foobar2000 Common Services component" PRODUCT_NAME="foobar2000 Common Services" FILE_VERSION="0, 2, 0, 0" ORIGINAL_FILENAME="foo_common.dll" INTERNAL_NAME="foo_common" LEGAL_COPYRIGHT="Copyright © 2005 Holger Stenger" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3BDB3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.2.0.0" UPTO_BIN_PRODUCT_VERSION="0.2.0.0" LINK_DATE="01/22/2007 12:02:19" UPTO_LINK_DATE="01/22/2007 12:02:19" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="components\foo_converter.dll" SIZE="409600" CHECKSUM="0xC6653F97" MODULE_TYPE="WIN32" PE_CHECKSUM="0x72C4F" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:20:01" UPTO_LINK_DATE="11/25/2006 13:20:01" />
    <MATCHING_FILE NAME="components\foo_cwb_hooks.dll" SIZE="208896" CHECKSUM="0xD63E4F18" MODULE_TYPE="WIN32" PE_CHECKSUM="0x41E7F" LINKER_VERSION="0x0" LINK_DATE="12/01/2006 18:47:45" UPTO_LINK_DATE="12/01/2006 18:47:45" />
    <MATCHING_FILE NAME="components\foo_dbsearch.dll" SIZE="440320" CHECKSUM="0x92B30F32" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6FAD5" LINKER_VERSION="0x0" LINK_DATE="01/25/2007 20:58:48" UPTO_LINK_DATE="01/25/2007 20:58:48" />
    <MATCHING_FILE NAME="components\foo_discogs.dll" SIZE="491520" CHECKSUM="0x3C597238" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="04/02/2007 21:01:44" UPTO_LINK_DATE="04/02/2007 21:01:44" />
    <MATCHING_FILE NAME="components\foo_dsp_dolbyhp.dll" SIZE="126976" CHECKSUM="0xC892E870" BIN_FILE_VERSION="1.1.0.0" BIN_PRODUCT_VERSION="1.1.0.0" PRODUCT_VERSION="1.1" FILE_DESCRIPTION="Dolby Headphone Wrapper for foobar2000" COMPANY_NAME="Lake Technology Limited, [url=http://www.lake.com.au%22]http://www.lake.com.au"[/url] PRODUCT_NAME="Dolby Headphone Wrapper" FILE_VERSION="1.1" ORIGINAL_FILENAME="foo_dsp_dolbyhp.dll" INTERNAL_NAME="foo_dsp_dolbyhp.dll" LEGAL_COPYRIGHT="Copyright © 1998-2000 Lake Technology Ltd" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.1.0.0" UPTO_BIN_PRODUCT_VERSION="1.1.0.0" LINK_DATE="04/30/2006 12:59:33" UPTO_LINK_DATE="04/30/2006 12:59:33" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="components\foo_dsp_std.dll" SIZE="246784" CHECKSUM="0xCF127AE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x469CB" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:20:12" UPTO_LINK_DATE="11/25/2006 13:20:12" />
    <MATCHING_FILE NAME="components\foo_freedb2.dll" SIZE="242176" CHECKSUM="0xCC15F1FB" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4A782" LINKER_VERSION="0x0" LINK_DATE="08/29/2006 18:16:02" UPTO_LINK_DATE="08/29/2006 18:16:02" />
    <MATCHING_FILE NAME="components\foo_input_alac.dll" SIZE="110592" CHECKSUM="0x2D815545" MODULE_TYPE="WIN32" PE_CHECKSUM="0x208B9" LINKER_VERSION="0x0" LINK_DATE="08/04/2006 19:57:03" UPTO_LINK_DATE="08/04/2006 19:57:03" />
    <MATCHING_FILE NAME="components\foo_input_dts.dll" SIZE="390144" CHECKSUM="0x9DEA456E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6C227" LINKER_VERSION="0x0" LINK_DATE="07/22/2006 13:35:47" UPTO_LINK_DATE="07/22/2006 13:35:47" />
    <MATCHING_FILE NAME="components\foo_input_monkey.dll" SIZE="278016" CHECKSUM="0x14A3DC3B" MODULE_TYPE="WIN32" PE_CHECKSUM="0x526C7" LINKER_VERSION="0x0" LINK_DATE="08/04/2006 19:57:19" UPTO_LINK_DATE="08/04/2006 19:57:19" />
    <MATCHING_FILE NAME="components\foo_input_shorten.dll" SIZE="165376" CHECKSUM="0x79053C97" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D3C4" LINKER_VERSION="0x0" LINK_DATE="01/22/2007 12:05:40" UPTO_LINK_DATE="01/22/2007 12:05:40" />
    <MATCHING_FILE NAME="components\foo_input_std.dll" SIZE="1109504" CHECKSUM="0xE8F4BC54" MODULE_TYPE="WIN32" PE_CHECKSUM="0x11C489" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:19:14" UPTO_LINK_DATE="11/25/2006 13:19:14" />
    <MATCHING_FILE NAME="components\foo_input_tak.dll" SIZE="159744" CHECKSUM="0x1AB79D09" MODULE_TYPE="WIN32" PE_CHECKSUM="0x32A14" LINKER_VERSION="0x0" LINK_DATE="04/11/2007 20:58:19" UPTO_LINK_DATE="04/11/2007 20:58:19" />
    <MATCHING_FILE NAME="components\foo_masstag.dll" SIZE="311296" CHECKSUM="0x8CE19099" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4E47C" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:18:42" UPTO_LINK_DATE="11/25/2006 13:18:42" />
    <MATCHING_FILE NAME="components\foo_playcount.dll" SIZE="146432" CHECKSUM="0x9D703621" MODULE_TYPE="WIN32" PE_CHECKSUM="0x329EC" LINKER_VERSION="0x0" LINK_DATE="09/16/2006 15:55:54" UPTO_LINK_DATE="09/16/2006 15:55:54" />
    <MATCHING_FILE NAME="components\foo_rgscan.dll" SIZE="276480" CHECKSUM="0xB451AC86" MODULE_TYPE="WIN32" PE_CHECKSUM="0x483FD" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:18:19" UPTO_LINK_DATE="11/25/2006 13:18:19" />
    <MATCHING_FILE NAME="components\foo_run.dll" SIZE="167936" CHECKSUM="0xD10E978C" BIN_FILE_VERSION="0.3.2.0" BIN_PRODUCT_VERSION="0.3.2.0" PRODUCT_VERSION="0, 3, 2, 0" FILE_DESCRIPTION="foo_run foobar2000 component" PRODUCT_NAME="foo_run foobar2000 component" FILE_VERSION="0, 3, 2, 0" ORIGINAL_FILENAME="foo_run.dll" INTERNAL_NAME="foo_run" LEGAL_COPYRIGHT="Copyright © 2006 Florian Heidenreich" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x37C53" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.3.2.0" UPTO_BIN_PRODUCT_VERSION="0.3.2.0" LINK_DATE="06/15/2006 20:08:11" UPTO_LINK_DATE="06/15/2006 20:08:11" VER_LANGUAGE="German (Germany) [0x407]" />
    <MATCHING_FILE NAME="components\foo_scrobblecharts.dll" SIZE="204800" CHECKSUM="0x52344B3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x35C03" LINKER_VERSION="0x0" LINK_DATE="03/31/2007 14:36:48" UPTO_LINK_DATE="03/31/2007 14:36:48" />
    <MATCHING_FILE NAME="components\foo_uie_albumart.dll" SIZE="241664" CHECKSUM="0x274A87D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x481CE" LINKER_VERSION="0x0" LINK_DATE="01/16/2007 01:04:42" UPTO_LINK_DATE="01/16/2007 01:04:42" />
    <MATCHING_FILE NAME="components\foo_uie_albumlist.dll" SIZE="229888" CHECKSUM="0x11A4C451" MODULE_TYPE="WIN32" PE_CHECKSUM="0x41755" LINKER_VERSION="0x0" LINK_DATE="11/22/2006 12:57:39" UPTO_LINK_DATE="11/22/2006 12:57:39" />
    <MATCHING_FILE NAME="components\foo_uie_console.dll" SIZE="87040" CHECKSUM="0x3F531B12" MODULE_TYPE="WIN32" PE_CHECKSUM="0x169FD" LINKER_VERSION="0x0" LINK_DATE="11/22/2006 12:59:04" UPTO_LINK_DATE="11/22/2006 12:59:04" />
    <MATCHING_FILE NAME="components\foo_uie_tabs.dll" SIZE="147456" CHECKSUM="0x80716500" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2EA82" LINKER_VERSION="0x0" LINK_DATE="07/07/2006 19:18:30" UPTO_LINK_DATE="07/07/2006 19:18:30" />
    <MATCHING_FILE NAME="components\foo_uie_trackinfo_mod.dll" SIZE="352256" CHECKSUM="0x6B38CA90" MODULE_TYPE="WIN32" PE_CHECKSUM="0x595D9" LINKER_VERSION="0x0" LINK_DATE="01/05/2007 19:36:21" UPTO_LINK_DATE="01/05/2007 19:36:21" />
    <MATCHING_FILE NAME="components\foo_ui_columns.dll" SIZE="594944" CHECKSUM="0xDF3C348C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9B7E7" LINKER_VERSION="0x0" LINK_DATE="11/22/2006 12:05:23" UPTO_LINK_DATE="11/22/2006 12:05:23" />
    <MATCHING_FILE NAME="components\foo_unpack.dll" SIZE="167424" CHECKSUM="0xA9B86C14" MODULE_TYPE="WIN32" PE_CHECKSUM="0x29B5B" LINKER_VERSION="0x0" LINK_DATE="11/25/2006 13:20:33" UPTO_LINK_DATE="11/25/2006 13:20:33" />
    <MATCHING_FILE NAME="components\foo_utils.dll" SIZE="225280" CHECKSUM="0x39F2C09B" BIN_FILE_VERSION="0.5.0.0" BIN_PRODUCT_VERSION="0.5.0.0" PRODUCT_VERSION="0, 5, 0, 0" FILE_DESCRIPTION="Utilities for foobar2000" COMPANY_NAME=" " PRODUCT_NAME="foo_utils" FILE_VERSION="0, 5, 0, 0" ORIGINAL_FILENAME="foo_utils.dll" INTERNAL_NAME="foo_utils" LEGAL_COPYRIGHT="Copyright © 2005 Holger Stenger" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x44C63" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.5.0.0" UPTO_BIN_PRODUCT_VERSION="0.5.0.0" LINK_DATE="04/27/2006 10:37:31" UPTO_LINK_DATE="04/27/2006 10:37:31" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="components\foo_verifier.dll" SIZE="175104" CHECKSUM="0x70597674" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2EE36" LINKER_VERSION="0x0" LINK_DATE="08/29/2006 20:09:17" UPTO_LINK_DATE="08/29/2006 20:09:17" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="kernel32.dll" SIZE="984064" CHECKSUM="0xF12E1D4A" BIN_FILE_VERSION="5.1.2600.2945" BIN_PRODUCT_VERSION="5.1.2600.2945" PRODUCT_VERSION="5.1.2600.2945" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2945 (xpsp_sp2_gdr.060704-2349)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF724D" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2945" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2945" LINK_DATE="07/05/2006 10:55:00" UPTO_LINK_DATE="07/05/2006 10:55:00" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</EXE>
</DATABASE>
EDIT: Foobar Just crashed while replaygaining a bunch of tak files. here's the crash log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 013D1E95h
Access violation, operation: read, address: 047618F4h
Call path:
ReplayGain thread
Code bytes (013D1E95h):
013D1E55h:  75 10 A1 18 66 3F 01 89 5C 90 F4 89 5B 04 89 1B
013D1E65h:  EB 3A 8B 10 89 43 04 89 13 89 18 89 5A 04 EB 2C
013D1E75h:  81 FE 00 3C 00 00 7C 0D 8B D6 8B C7 E8 EA FE FF
013D1E85h:  FF 84 C0 75 17 A1 0C 66 3F 01 89 1D 0C 66 3F 01
013D1E95h:  8B 10 89 43 04 89 13 89 18 89 5A 04 5F 5E 5B C3
013D1EA5h:  8D 40 00 83 3D 10 66 3F 01 00 7E 40 83 3D 10 66
013D1EB5h:  3F 01 0C 7D 0C C7 05 BC 65 3F 01 07 00 00 00 EB
013D1EC5h:  2B A1 10 66 3F 01 83 C8 02 8B 15 14 66 3F 01 89
Stack (043DFCB4h):
043DFC94h:  01645300 773F65E1 01614734 00000005
043DFCA4h:  333A3735 00120033 7E41885A 00000230
043DFCB4h:  000135E0 04750A20 04753FFC 013D1C67
043DFCC4h:  001703D4 013D1DE9 75400000 01000004
043DFCD4h:  049F1100 043DFD18 04750A20 000135DC
043DFCE4h:  04750A20 013D1E86 047612C4 04750A20
043DFCF4h:  000135DC 013D23F9 043DFD94 013D2422
043DFD04h:  043DFD18 01512478 014EC0B4 014EC0B4
043DFD14h:  013EB608 043DFD78 013D26F3 014EC0B4
043DFD24h:  013EB7C6 0AF40001 013EB8B3 014EBC6C
043DFD34h:  0AF40001 013D3353 013EDC56 014CD3E0
043DFD44h:  0AF40001 013D3353 013EDEE2 01427438
043DFD54h:  01427438 013D3353 013F247E 0AF40001
043DFD64h:  013F2BE6 01514D38 01514FB0 013D3353
043DFD74h:  013F346B 043DFDE8 01394BC4 01427438
043DFD84h:  21D8D79B 00000000 01514FA8 0494BC14
043DFD94h:  043DFDB0 013A4E58 FFFFFFFF 01394B16
043DFDA4h:  01514FB0 21D8D7BF 01514FA8 043DFDDC
043DFDB4h:  013A4F48 00000000 013947ED 01514FA8
043DFDC4h:  21D8D7FB 0494BC04 02A4C5F0 0494BC14
Registers:
EAX: 047618F4, EBX: 04750A20, ECX: 000035DC, EDX: 000035DC
ESI: 000035DC, EDI: 04750A20, EBP: 04754000, ESP: 043DFCB4
EDIT2: another crash while replaygaining.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 013D1444h
Access violation, operation: read, address: 00000000h
Call path:
ReplayGain thread=>input_entry::g_open_for_decoding
Code bytes (013D1444h):
013D1404h:  58 04 89 42 04 89 03 B0 01 5E 5B C3 8B 50 04 8B
013D1414h:  08 89 0A 89 51 04 8B 15 DC 65 3F 01 89 10 A3 DC
013D1424h:  65 3F 01 C3 53 56 57 55 51 8B F1 89 14 24 8B E8
013D1434h:  8B 5D 00 8B 04 24 8B 10 89 16 8B 50 04 89 56 04
013D1444h:  8B 3B 8B 43 08 8B D0 03 53 0C 3B 16 75 14 8B C3
013D1454h:  E8 B7 FF FF FF 8B 43 08 89 06 8B 43 0C 01 46 04
013D1464h:  EB 16 8B 16 03 56 04 3B C2 75 0D 8B C3 E8 9A FF
013D1474h:  FF FF 8B 43 0C 01 46 04 8B DF 3B EB 75 C2 8B D6
Stack (048FE668h):
048FE648h:  A6011535 00000000 00000000 00CC0020
048FE658h:  FFFFFFFF 77F16E2D 77F16F1A A6011535
048FE668h:  048FE6A5 05358000 048FE6A5 05368000
048FE678h:  05358000 013D19CB 00010084 05358000
048FE688h:  00010000 00000000 00000000 00010084
048FE698h:  05358000 00170424 013D1DC3 35800000
048FE6A8h:  01000005 00000000 048FE6F0 05358000
048FE6B8h:  00010084 05358000 013D1E86 05368084
048FE6C8h:  05358000 00010084 013D23F9 048FFAE4
048FE6D8h:  013D2422 048FE6F0 048FFAE4 053A4448
048FE6E8h:  053A4448 013EB608 048FFB08 013D26F3
048FE6F8h:  053A4448 013EB7C6 00000001 013EB8B3
048FE708h:  014A5FF8 014A5FF8 013D3353 013F2486
048FE718h:  00000081 013F2BE6 00000000 013D36A6
048FE728h:  013D36B9 014A5FF8 00000000 013D1444
048FE738h:  05342750 048FE83C 048FE768 048FE774
048FE748h:  00000000 00000000 00000000 7C9037BF
048FE758h:  048FE83C 048FFAE4 048FE858 048FE810
048FE768h:  048FEB90 7C9037D8 048FFAE4 048FE824
048FE778h:  7C90378B 048FE83C 048FFAE4 048FE858
Registers:
EAX: 00000000, EBX: 00000000, ECX: 048FE684, EDX: 05368000
ESI: 048FE684, EDI: 00000000, EBP: 013F65F0, ESP: 048FE668
Crash location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Loaded modules:
LVPrcInj                        loaded at 00AC0000h - 00AD7000h
RocketDock                      loaded at 002C0000h - 002D2000h
foo_ac3                          loaded at 00300000h - 0032F000h
DolbyHph                        loaded at 03EC0000h - 03FBC000h
xpsp2res                        loaded at 20000000h - 202C5000h
netapi32                        loaded at 5B860000h - 5B8B4000h
Apphelp                          loaded at 77B40000h - 77B62000h
faultrep                        loaded at 69450000h - 69466000h
WTSAPI32                        loaded at 76F50000h - 76F58000h
Address: 013D19CBh, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D1DC3h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 01000005h, location: "foo_dsp_std", loaded at 00FF0000h - 01031000h
Address: 013D1E86h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D23F9h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D2422h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013EB608h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D26F3h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013EB7C6h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013EB8B3h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013F2486h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013F2BE6h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D36A6h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D36B9h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 013D1444h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 7C9037BFh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000007Ah)
Address: 7C9037D8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000093h)
Address: 7C90378Bh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000046h)
Address: 013D36A1h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 7C937860h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrAddRefDll" (+00000247h)
Address: 013D3AD4h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 7C903804h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+000000BFh)
Address: 013F65F0h, location: "tak_deco_lib", loaded at 013D0000h - 013FF000h
Address: 7C90EAFAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserExceptionDispatcher" (+0000000Eh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000169h)
Address: 01929EF7h, location: "foo_ui_columns", loaded at 018E0000h - 01977000h
Address: 77404D01h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00018E61h)
Address: 7C912270h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSection" (+00000743h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7E4252C4h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "SendDlgItemMessageW" (+00000032h)
Address: 015E6F58h, location: "foo_rgscan", loaded at 015E0000h - 01628000h
Address: 015E6F99h, location: "foo_rgscan", loaded at 015E0000h - 01628000h
Address: 5AD7278Ch, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeAppProperties" (+00000571h)
foo_input_tak
foo_input_tak 0.2.1
Recompiled against final TAK SDK 1.0.1. Bundled tak_deco_lib.dll from TAK SDK 1.0.1 instead of outdated one. Added call path tracking for calls made into tak_deco_lib.
Sorry, I don't have time to inspect the cause of those crashes at the moment.
foo_input_tak
thanks!
foo_input_tak
This is the only crash i have had after upgrading the component. Again, the crash occured during replaygain; specifically while foobar tried to add the RG tag a file that was being played.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 013D1C09h
Access violation, operation: write, address: 00000001h
Call path:
playback_process entry=>input/on_idle=>input_entry::g_open_for_decoding=>tak_ssd::create_from_stream
Code bytes (013D1C09h):
013D1BC9h:  01 8B 50 04 8B 48 08 81 F9 00 10 00 00 7F 38 3B
013D1BD9h:  C2 75 17 85 C9 79 03 83 C1 03 C1 F9 02 A1 18 86
013D1BE9h:  3F 01 33 D2 89 54 88 F4 EB 24 85 C9 79 03 83 C1
013D1BF9h:  03 C1 F9 02 8B 1D 18 86 3F 01 89 54 8B F4 8B 00
013D1C09h:  89 02 89 50 04 5B C3 8B 00 89 02 89 50 04 5B C3
013D1C19h:  8D 40 00 8B 15 1C 86 3F 01 EB 10 8B 4A 08 3B C1
013D1C29h:  72 07 03 4A 0C 3B C1 72 16 8B 12 81 FA 1C 86 3F
013D1C39h:  01 75 E8 C7 05 BC 85 3F 01 03 00 00 00 33 D2 8B
Stack (0780F1ACh):
0780F18Ch:  0000040B 00001000 01A1D238 773DE50B
0780F19Ch:  DCBAABCD 00000000 0013F770 773DE50B
0780F1ACh:  00000004 013D1D2E 0780F1E8 01410000
0780F1BCh:  013D1F2F 01414000 00028000 01410000
0780F1CCh:  0002C000 013F860C 000266AC 000266AC
0780F1DCh:  013D1F9D 01414000 00028000 01411650
0780F1ECh:  013D2068 0780F224 00026666 00000040
0780F1FCh:  000266AC 013D2258 0780F248 013D3AD8
0780F20Ch:  0780F224 00026666 00000040 01411634
0780F21Ch:  0000001C 015224A0 000266A5 013D26D3
0780F22Ch:  01411634 013EB7B2 0780F268 00026666
0780F23Ch:  00000040 01411634 013EB834 0780F298
0780F24Ch:  013D3B53 0780F268 01411634 015224A0
0780F25Ch:  01410C34 01410C34 01026666 0780F2BC
0780F26Ch:  013F420F 00000000 01410C78 00000040
0780F27Ch:  00000200 015224A0 01410C34 01410C34
0780F28Ch:  013F4BB6 013B1E98 013F4D70 0780F37C
0780F29Ch:  013D3B53 0780F2BC 01410C34 015224A0
0780F2ACh:  0152A918 02B127F8 00000800 011B43B0
0780F2BCh:  0780F2D4 013F568A 00000000 00000000
Registers:
EAX: 00000022, EBX: 0017F240, ECX: 00000004, EDX: 00000001
ESI: 0000282C, EDI: 0780F1C0, EBP: 013F8610, ESP: 0780F1AC
Crash location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Loaded modules:
RocketDock                      loaded at 00A30000h - 00A42000h
foo_ac3                          loaded at 00A60000h - 00A8F000h
tak_deco_lib                    loaded at 013D0000h - 01401000h
foo_lyricsdb                    loaded at 01530000h - 0155F000h
foo_masstag                      loaded at 01580000h - 015D0000h
foo_playcount                    loaded at 015F0000h - 01618000h
foo_rgscan                      loaded at 01650000h - 01698000h
foo_run                          loaded at 016C0000h - 016EB000h
foo_scrobblecharts              loaded at 01710000h - 01743000h
foo_uie_albumart                loaded at 01770000h - 017AC000h
foo_uie_albumlist                loaded at 017D0000h - 0180D000h
foo_uie_console                  loaded at 01830000h - 0184B000h
foo_uie_explorer                loaded at 01870000h - 018AC000h
foo_uie_tabs                    loaded at 018D0000h - 018F6000h
foo_uie_trackinfo_mod            loaded at 01920000h - 01976000h
foo_ui_columns                  loaded at 019A0000h - 01A37000h
foo_unpack                      loaded at 01A60000h - 01A8E000h
foo_utils                        loaded at 01AB0000h - 01AE9000h
foo_verifier                    loaded at 01B10000h - 01B40000h
DolbyHph                        loaded at 043D0000h - 044CC000h
shext                            loaded at 183B0000h - 183B7000h
ShExtRes                        loaded at 192F0000h - 192F3000h
TzShell                          loaded at 04E60000h - 04F09000h
OLEPRO32                        loaded at 5EDD0000h - 5EDE7000h
TzArchive10                      loaded at 05010000h - 051CC000h
cabinet                          loaded at 75150000h - 75164000h
unrar3                          loaded at 052D0000h - 05300000h
TzImage10                        loaded at 04CF0000h - 04D05000h
wpdshext                        loaded at 16210000h - 1648E000h
tishell                          loaded at 05810000h - 05883000h
timounter                        loaded at 05890000h - 058AF000h
diskcopy                        loaded at 6CC70000h - 6CDE1000h
xpsp2res                        loaded at 05D40000h - 06005000h
NETSHELL                        loaded at 76400000h - 765A6000h
rtutils                          loaded at 76E80000h - 76E8E000h
credui                          loaded at 76C00000h - 76C2E000h
msxml3                          loaded at 74980000h - 74A8E000h
wsock32                          loaded at 71AD0000h - 71AD9000h
RASAPI32                        loaded at 76EE0000h - 76F1C000h
rasman                          loaded at 76E90000h - 76EA2000h
TAPI32                          loaded at 76EB0000h - 76EDF000h
msv1_0                          loaded at 77C70000h - 77C93000h
sensapi                          loaded at 722B0000h - 722B5000h
Address: 013D1D2Eh, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013D1F2Fh, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013F860Ch, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013D1F9Dh, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013D2068h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013D2258h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013D3AD8h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013D26D3h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013EB7B2h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013EB834h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013D3B53h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013F420Fh, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013F4BB6h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 013B1E98h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013F4D70h, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Address: 011B43B0h, location: "foo_input_monkey", loaded at 01190000h - 011D9000h
Address: 013F568Ah, location: "tak_deco_lib", loaded at 013D0000h - 01401000h
Symbol: "tak_SSD_Create_FromStream" (+00000022h)
Address: 01395AF0h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013955C7h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 004DE5F8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0100A9B0h, location: "foo_dsp_std", loaded at 00FF0000h - 01031000h
Address: 013933E5h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 01395D2Ch, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 01396180h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013A52CBh, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 01393B4Eh, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013A5353h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 01394C89h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013A53A8h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013947E3h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 01394523h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013A5380h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 0139425Fh, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 013B01F8h, location: "foo_input_tak", loaded at 01390000h - 013B9000h
Address: 0047F351h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E188h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E206h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E223h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01352084h, location: "foo_input_std", loaded at 01250000h - 01364000h
Address: 004C6FC8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A9198h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E79Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 003E146Dh, location: "LVPrcInj", loaded at 003E0000h - 003F7000h
Address: 004C6FD0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 003ECF71h, location: "LVPrcInj", loaded at 003E0000h - 003F7000h
Address: 004A91E8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E272h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A9248h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0048A517h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E2C84h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AA82Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0048A29Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AA860h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00442764h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004430DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00443F7Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C2B38h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 0044658Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 20000000h, location: "odbcint", loaded at 20000000h - 20017000h
Address: 004C2C28h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF2EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00E13C88h, location: "foo_dbsearch", loaded at 00E00000h - 00E70000h
Address: 01000000h, location: "foo_dsp_std", loaded at 00FF0000h - 01031000h
Address: 004456E5h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C2B04h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF308h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00445687h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A67D9h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00445650h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
TAK Decoder 0.2.1  (foo_input_tak)
Explorer Tree 1.04.6b  (foo_uie_explorer)
foo_input_tak
[deleted]
foo_input_tak
kanak, have you tried updating to tak_deco_lib 1.0.2 yet?
A few weird things I've noticed myself... when I initially added TAK files to a playlist, there is no bitrate known/displayed.  It was there for all other files I added after my initial use of the plugin, however.  Might have been something I did...
The only other thing that I could hope for, at this point, would be support for embedded cue files.  I've not been able to reproduce a crash yet, and I've been trying.
i got that latest crash after upgrading the decoder library (that's been my only crash so far).
Also, it seems that tagging was much faster when the plugin used foobar's own mechanism. Anyone else notice this?
foo_input_tak
I noticed the same thing with some files made with foobar's converter (incl. replaygain scan (which didn't crash for me yet)). Changing any tag made the bitrate display appear (whereas reread metadata only worked for every second file).
