IPB
> foobar2000 Tech Support Forum Rules
Please read foobar2000 Tech Support Forum Rules before posting and comply with all the points.
Failure to provide all the information pointed out in the above document in your post is considered wasting other people's time and in extreme cases will lead to your topic getting locked without a reply.
See also: Hydrogenaudio Terms of Service.
Windows 10 (ten)
FriGiN
post Aug 21 2015, 21:22
Post #1
Group: Members
I have installed foobar and loaded my music, when i click play it just stops playing no error or anything.
Go to the top of the page
+Quote Post
shakey_snake
post Aug 21 2015, 23:07
Post #2
Group: FB2K Moderator
QUOTE (FriGiN @ Aug 21 2015, 16:22) *
Did it never play, or does it stop playing?
If it has never played, try Preferences->Playback->Output
and make sure the device is listed as DS: Primary Sound Driver.
Then goto the Windows "Change Sound Card Settings" and make sure you have the correct device set as default.
This post has been edited by shakey_snake: Aug 21 2015, 23:07
elevatorladylevitateme
+Quote Post
FriGiN
post Aug 22 2015, 20:19
Post #3
Group: Members
It has never played. I've installed it as a program and as portable program neither has worked. I tried all the sources in output and they all do the same thing i press play and it say starting playback... then immediately playback stopped... and i get no sound what so ever.
+Quote Post
eahm
post Aug 22 2015, 21:32
Post #4
Group: Members
Do you have this?
+Quote Post
FriGiN
post Aug 22 2015, 21:35
Post #5
Group: Members
QUOTE (eahm @ Aug 22 2015, 14:32) *
Do you have this?
Bloody hell. its just because there was no playlist thats effed up. thanks.
problem fixed
+Quote Post
shakey_snake
post Aug 22 2015, 21:44
Post #6
BTW, fun fact: if you right-click an item in the album list and select "Play" it will play without needing or creating a playlist.
But otherwise, yes, you need a playlist.
[edit]Also, right-clicking things is generally how you expose a lot of foobar2000's functionality, so if you're ever stuck again, check the context menu. It might be a little weird at first, but the more you do it, the easier fb2k will be.
This post has been edited by shakey_snake: Aug 22 2015, 21:49
+Quote Post
kode54
post Aug 24 2015, 07:37
Post #7
Group: Admin
And a further note to using context menus, both context and main menus will reveal more options if you are holding the Shift key when you open the menu.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 3rd September 2015 - 23:00
