Topic: Some layout questions (Read 899 times) previous topic - next topic
When I try to move a window (such as a browser or another program) over Foobar it's always goes behind Foobar program and can't see the window and I can't toggle Foobar to go behind the other program.
I can easily get around it with by minimising Foobar but it doesn't seem like there is a need for to always make Foobar in front of the screen (other programs don't have this issue) as normally I choose a song to play and do something else which makes it a bit of an inconvenience to minimise foobar after let say changing a song played.
Also with playlist. I would normally like to order songs in specific order. However if I accidentally click on let say Artist, Title or # column it will reorganise it in a different order. However I don't know how to reset it back to the original playlist order as there is no column for that and hence have to manually reorder it. For me to get around it I always save playlist anytime I made a change in the playlist order so when I do accidentally click on the columns, I'll just load up the earlier playlist. However is there a way to put a column of playlist order as part of the column. Itunes has it part of the column so whenever that happens there, I can easily reset it back to the original playlist.
Anyway it's a pretty great program otherwise and I basically replace iTunes with this program but those are my two niggling complaints and I hope there is a solution to it.
You probably accidentally enabled View > Always On Top (Alt+A).
There is Ctrl+Z to undo, next time this happens.
I believe there's also a component to lock the columns, but someone else may know more about that.
Thank
I guess that is problem solve
