Topic: making previous columns visible? (Read 1829 times) previous topic - next topic
hi,
i have a slight problem with my foobar.
the thing is my windows 7 suddenly crashed without any reason and i had to format and reinstall everything. however as i reinstalled foobar i realized the previous columns settings i'd customized in the previous install weren't - naturally - available. in particular i am in need of a 'comments' column where i had written detailed descriptions of my audio files.
as i'm a newbie i have no idea how to retrieve this information. the audio files themselves are exactly as they were before formatting as i managed to save a backup of them before reinstalling windows 7. the problem is i don't know how to gain access to the information contained within those files such as the 'comments' column.
do you understand what i'm talking about? can someone please help me?
thanks
Assuming
you are talking about seeing the information in a playlist
you are talking about the Default user interface
you are using the default playlist
Preferences>Display>DUI>Playlist View>Custom columns> ADD
name is whatever you want and pattern = %field name you want to see%
in the playlist view, right click on a column header and insert the new column
Right click/Properties on your files to see which tag contains your comments. As tpijag said, you can show its content via '%tag%'.
I'd recommend adding brackets around it, so it won't show an '?' when your tag is empty/doesn't exist: '[%tag%]'
Assuming
yes.
yes.
yes.
yes, thanks i got it. thanks a bunch.
