Topic: Home stereo display (Read 269426 times) previous topic - next topic
Home stereo display
Reply #75
1.Does it happens to every track?
2.If not,what is the length of the track in the image?
Favourite artist:CD-R
Favourite album:700MB
Home stereo display
Reply #76
damn it, there is another problem
as you can see, the play-symbol isn't correct. could be related to a wrongly installed font. which one is responsible for the symbol?
another really odd thing is the playcount-number. the second parentheses is shown after the second number, not after the third... i have just copied and pasted the code. 5 minutes ago again, but with the same result.
thanks in advance.
edit: font installation under windows makes me mad... did it again and now it works.
Home stereo display
Reply #77
VERSION 1.3 is out (see the first post)
Home stereo display
Reply #78
Thanks for the cool display.
I tweaked mine a bit so that rather than the date of the last play, it displays "today", "yesterday" or the number of days its been since the track was played.
$get(active)
$if(%last_played%, $puts(diff,$cwb_datediff(%last_played%,%cwb_systemdate%))
$ifgreater(1,$get(diff),today,$ifgreater(2,$get(diff),yesterday,$get(diff) days)),..........)
requires my foo_cwb_hooks plugin.
There used to be a link to my website here.
Home stereo display
Reply #79
$get(active)
First of all you welcome,second as you've probably seen i also make an intensive use of your plugin
in the later versions.(Thanks for it)
Home stereo display
Reply #80
hm, i got some drum-n-bass sets in my playlists and they are often >60mins.
so, i tested, and, the mistake is corrected, if the "playing moment" (i got a bad english.. sorry) of the current mp3 is above 10mins
and, it happens with every mp3 file i have in my playlist unless it reaches the 10mins
e: perhaps, it's because some tracks are displayed with eg 1:30:40 length in the playlist, but i'm not sure
Home stereo display
Reply #81
I'll check it.
Home stereo display
Reply #82
hm, also the complete file length works correct if the track is above 10mins long
e:\ as long as the track is not longer as 60mins
Home stereo display
Reply #83
In one thing you're right:there's no support for tracks bigger than 60m,but it's not a bug,but was designed this way.About the files with length<10m,can you tell me please how their %_time_total% displayed
in lets say playlist view?Could it be something like 0:01:23?
Home stereo display
Reply #84
in my coloumns setup, i have %_LENGTH% instead off %_time_total%, as i can see
Home stereo display
Reply #85
Your problem can be reproduced if these line in the code are screwed up:
$if($stricmp($len(%_time_elapsed%),4),$puts(time,$insert(0,%_time_elapsed%,3)),
$puts(time,%_time_elapsed%))
$if(%_time_total%,
$if($stricmp($len(%_time_total%),4),$puts(total,$insert(0,%_time_total%,3)),
$puts(total,%_time_total%)),$puts(total,__:__))
Try to repaste the code
Home stereo display
Reply #86
hm, repasted it, but the problem is the same /:
perhaps i have to activate database or smth? because i dont use this feature...
looks like your last player and rating system needs this, or is it independent from that?
Home stereo display
Reply #87
Does anybody else experience the same f!@k up?
Cos here everything is working fine,and i use the same exact code as you do:
what smth is?
Home stereo display
Reply #88
hm, perhaps the plugin list helps and there is some kind of conflict?
and, i dont use the media library..
(win xp sp2 pro btw)
e:\ used the new v1.3 code
Home stereo display
Reply #89
There was a minor problem with the scrolling
(probably you didn't even noticed) It's been fixed.
I don't have an answer yet,sure this aint no plugin conflict,i'll let you know.
Home stereo display
Reply #90
The symbolic font used for trackinfo can be somewhat harmful (check the album title in the image below,
actually it's "flick of the switch" and not the f!@# of it!)
Home stereo display
Reply #91
Why my Home stereo display look so ugly and wierd, and i don't mean to the width??
I installed the fonts, and i have some of them before.
Home stereo display
Reply #92
[a href="http://img178.imageshack.us/my.php?image=15001500148815131501hk1.jpg" target="_blank"]
Home stereo display
Reply #93
looks great bu got a problem:
can you help me?
Home stereo display
Reply #94
Try repasting the code.
Home stereo display
Reply #95
Version 1.3.1 is out (see the first post)
It looks and acts exactly like V 1.3 but has slightly improved scrolling and auto characte encoding detection.
So if you want to use the LCD font,but have files in your library which tags are written in:
East european lang.,Hebrew,Arabic,or Japaneese and\or all the east asian languages you can use it,
and at the moment unhandled characters are detected the font will auto switch to "Arial unicode ms"
Don't forget to download the new archive.Enjoy
Home stereo display
Reply #96
Wow, thanks for adding ability to change colours.  This keeps getting better and better.
This is how I'm using it:
It doesn't like Monkey's Audio:
It's not important.  I only have like 60 APE songs in my library.  Just a heads up.
Home stereo display
Reply #97
Oh my,finally one post without complaints! Bless you!
Home stereo display
Reply #99
Great job Russell
Ok so now thats two good ones
Now, WHY no WavPack??
Pleeeeeeeeeease
Two in a row?Unbelievable... (Thank you) If you send me a Wav pack file i'll see what i can do (i don't have any).
BTW:what's the problem with it? (russel777@gmail.com)
