Topic: How to put CBR/VBR mp3s together in one album (Read 1657 times) previous topic - next topic
Your custom grouping scheme has a tag for codec information in it. Remove it, and the text of the group headers will be the same and foobar will condense the items into a single group.
Where do i find this?
edit- i found the custom grouping scheme...but its empty...what to do?
Ohhh, wait, it's a builtin scheme "By artist/date/album/codec". You selected that one. If you select the one without /codec (or create your own tag scheme in custom groups), everything should be okay.
If you want to see the codec used, you could create an extra column. I'm not sure which tag you should use, as the builtin group uses something more than just %codec%.
Where do i select this?
Made another screenshot, maybe its now more clear what i mean.
http://i.imgur.com/d7Lbz.png
So, i want to remove the CBR/VBR tags, so the album appears to be 1 again, instead of 4
At the grey header bar, with the 'Artist', 'Title', 'Album', etc. Right click it, select 'Groups' then, 'By artist/date/album'
Thank you!!!
