IPB
> foobar2000 Tech Support Forum Rules
Please read foobar2000 Tech Support Forum Rules before posting and comply with all the points.
Failure to provide all the information pointed out in the above document in your post is considered wasting other people's time and in extreme cases will lead to your topic getting locked without a reply.
See also: Hydrogenaudio Terms of Service.
Wine problem?
fooproblem
post Jun 14 2015, 16:51
Post #1
Group: Members
Somehow just while i try install Upnp plugin it's cause error:
Components loaded in: 0:00.070960
Configuration read in: 0:00.004684
Watching: C:\users\admin\Music
RegisterShellHookWindow failure
User Interface initialized in: 0:00.082166
Failed to load DLL: foo_upnp.dll, reason: Not a valid Win32 application.
Startup time : 0:00.192662
I am on Fedora FC21 64 bit O/S. What is the source of problem?
Go to the top of the page
+Quote Post
fooproblem
post Jun 14 2015, 19:58
Post #2
Group: Members
Problem solved. I uninstalled standard installation (with registration in registry) and install portable version.Then install upnp component as usual and it's work. To tell the trust i also switch Windows from default to Windows XP in Wine Configuration. With all of above i successfully play music from upnp server. Good luck for everyone!
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 1st August 2015 - 16:36
