Topic: Autoplaylist: %skip_count% GREATER 1 (Read 1224 times) previous topic - next topic
Hi!
Is it possible to create an autoplaylist using the skip counts?
Something like %skip_count% GREATER 1
Playcount doesn't have such a field %skip_count%
http://www.foobar2000.org/components/view/foo_playcount
I wonder if is there anyway to do that.
i'm not aware of anything that will detect when you skip a track. i suspect it would be possible make a script using the WSH panel mod component that would increment a tag value if the elapsed time is below a certain threshold compared to the track length - if you could give me some idea of what kind of behaviour you would expect, that would be great.
i could have a go at this later when i've got more time. i'll post back with an update if i manage to make it work.
I'm selecting songs from a large playlist.
I'll use this filter to probably delete songs I don't like (skipped while playing) from that playlist later.
Ill give a try on WSH panel mod component.
foo_playlist_attributes has the ability to move skipped tracks to a specific playlist.
I'll check it out!
Thanks a lot!
