Illegal operation:
Code: C0000096h, flags: 00000000h, address: 01EC67B8h
Call path:
WinMain=>app_mainloop
Code bytes (01EC67B8h):
01EC6778h: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00
01EC6788h: 00 00 00 00 01 01 01 00 19 0C 87 C8 04 0E 74 40
01EC6798h: 34 EA 42 00 08 36 F8 01 00 00 00 00 76 04 A8 A5
01EC67A8h: 05 00 0A 00 03 01 0C 00 C0 C4 E1 01 08 40 00 02
01EC67B8h: F4 16 D8 00 00 00 08 00 03 00 00 00 03 00 00 00
01EC67C8h: 90 23 F7 01 00 54 F7 01 02 00 05 00 03 01 0C 00
01EC67D8h: 60 15 F7 01 60 A7 E1 01 02 01 02 00 03 01 10 00
01EC67E8h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Stack (0012FAACh):
0012FA8Ch: F0 FF FF FF D8 3D 33 00 0C E2 12 00 00 00 00 00
0012FA9Ch: CB 44 F9 77 00 3E 33 00 CD 8B F5 77 02 00 00 00
0012FAACh: 78 50 53 02 80 3E EB 01 D8 47 5C 02 C4 FA 12 00
0012FABCh: 00 00 00 00 A8 97 F2 01 81 00 00 00 00 FB 12 00
0012FACCh: 98 A6 5A 02 FF FF FF FF D7 24 DA 00 80 FB 12 00
0012FADCh: A8 97 F2 01 AB 23 DA 00 EA 22 DA 00 B4 04 73 00
0012FAECh: 30 FB 12 00 F5 C6 D4 77 58 00 10 01 35 01 00 00
0012FAFCh: F4 22 DA 00 94 FB 12 00 1E 4A DA 00 FF FF FF FF
Registers:
EAX: 01EB7C81, EBX: 00000000, ECX: 01E1F398, EDX: 0012FAC4
ESI: 025DCB04, EDI: 00000000, EBP: 0012FB0C, ESP: 0012FAAC
Unable to identifyc rash location
Loaded modules:
foobar2000 loaded at 00400000h - 00445000h
ntdll loaded at 77F50000h - 77FF7000h
kernel32 loaded at 77E60000h - 77F46000h
COMCTL32 loaded at 71950000h - 71A34000h
msvcrt loaded at 77C10000h - 77C63000h
GDI32 loaded at 77C70000h - 77CB0000h
USER32 loaded at 77D40000h - 77DCC000h
ADVAPI32 loaded at 77DD0000h - 77E5D000h
RPCRT4 loaded at 78000000h - 78086000h
SHLWAPI loaded at 70A70000h - 70AD5000h
utf8api loaded at 10000000h - 1000E000h
comdlg32 loaded at 763B0000h - 763F5000h
SHELL32 loaded at 773D0000h - 77BC2000h
foo_abx loaded at 00390000h - 0039D000h
foo_ac3 loaded at 003A0000h - 003B3000h
foo_albumlist loaded at 003C0000h - 003CD000h
foo_ape loaded at 003D0000h - 003F2000h
foo_apl loaded at 00930000h - 0093E000h
foo_bitcompare loaded at 00940000h - 0094B000h
foo_burninate loaded at 00950000h - 0095F000h
VERSION loaded at 77C00000h - 77C07000h
foo_cdda loaded at 00960000h - 00971000h
foo_clienc loaded at 00990000h - 009A9000h
foo_console loaded at 009B0000h - 009BB000h
foo_convolve loaded at 009C0000h - 009F0000h
foo_diskwriter loaded at 009F0000h - 009FF000h
foo_dsp_crossfade loaded at 00A00000h - 00A0A000h
foo_dsp_crossfeed loaded at 00A10000h - 00A19000h
foo_dsp_extra loaded at 00A20000h - 00A38000h
foo_dsp_nogaps loaded at 00A40000h - 00A4A000h
foo_dsp_pause loaded at 00A50000h - 00A5A000h
foo_dsp_skip_silence loaded at 00A60000h - 00A6A000h
foo_dsp_soundtouch loaded at 00A70000h - 00A7E000h
MSVCP60 loaded at 55900000h - 55961000h
foo_dynamics loaded at 00A80000h - 00A8B000h
foo_faac loaded at 00A90000h - 00AC7000h
foo_flac loaded at 00AD0000h - 00AE9000h
foo_flaccer loaded at 00AF0000h - 00B0B000h
foo_freedb loaded at 00B10000h - 00B42000h
WS2_32 loaded at 71AB0000h - 71AC5000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_id3v2 loaded at 00B50000h - 00B7A000h
foo_infobox loaded at 00B80000h - 00B90000h
foo_input_std loaded at 00B90000h - 00BEF000h
MSACM32 loaded at 77BE0000h - 77BF4000h
WINMM loaded at 76B40000h - 76B6C000h
foo_masstag loaded at 00C70000h - 00C81000h
foo_mod loaded at 00C90000h - 00C9C000h
BASS loaded at 00CA0000h - 00CF3000h
ole32 loaded at 771B0000h - 772D1000h
foo_monkey loaded at 00D00000h - 00D22000h
foo_mp4 loaded at 00D30000h - 00D8C000h
foo_mpcenc loaded at 00D90000h - 00D9C000h
foo_neromp4 loaded at 00DA0000h - 00DAE000h
MFC42 loaded at 73DD0000h - 73EC2000h
foo_nez loaded at 00DB0000h - 00DE0000h
foo_null loaded at 00DE0000h - 00DEA000h
foo_ofr loaded at 00DF0000h - 00E22000h
foo_output_asio loaded at 00E40000h - 00E4D000h
foo_output_std loaded at 00E50000h - 00E5C000h
foo_out_dsound_ex loaded at 00E60000h - 00E6C000h
DSOUND loaded at 51080000h - 510D6000h
foo_out_ks loaded at 00E80000h - 00E8E000h
SETUPAPI loaded at 76670000h - 76757000h
foo_psf loaded at 00E90000h - 00F39000h
foo_read_http loaded at 00F40000h - 00F5B000h
foo_rgscan loaded at 00F60000h - 00F6E000h
foo_search_ex loaded at 00F70000h - 00F7B000h
foo_shn loaded at 00F80000h - 00F94000h
foo_shuffle loaded at 00FA0000h - 00FAC000h
foo_spc loaded at 00FB0000h - 00FC3000h
foo_speex loaded at 00FD0000h - 00FEC000h
foo_stfu loaded at 00FF0000h - 00FFA000h
foo_tfmx loaded at 01000000h - 0100C000h
foo_toolame loaded at 01010000h - 01027000h
foo_tunes loaded at 01030000h - 01080000h
uxtheme loaded at 5AD70000h - 5ADA4000h
foo_ui_std loaded at 010E0000h - 010FD000h
foo_ui_std_ex loaded at 01100000h - 01119000h
foo_unpack loaded at 01120000h - 0114F000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_vis_manager loaded at 01150000h - 0115C000h
foo_vis_simple_spectrum loaded at 01160000h - 0116E000h
foo_vis_test loaded at 01170000h - 0117A000h
foo_vis_vu_meter loaded at 01180000h - 0118B000h
foo_vorbisenc loaded at 01190000h - 0128F000h
foo_vorbisenc_gt3 loaded at 01290000h - 0138A000h
foo_wavpack loaded at 01390000h - 0139E000h
foo_wma loaded at 013A0000h - 013AB000h
WMVCore loaded at 08530000h - 0872D000h
WMASF loaded at 07260000h - 07299000h
foo_xa loaded at 013B0000h - 013C8000h
POINT32 loaded at 61210000h - 6121F000h
MSH_ZWF loaded at 61220000h - 61232000h
idlemon loaded at 1C000000h - 1C006000h
ksuser loaded at 5EF80000h - 5EF84000h
NeroIPP loaded at 02740000h - 02818000h
Secur32 loaded at 76F90000h - 76FA0000h
aac loaded at 02530000h - 026CC000h
aacenc32 loaded at 02820000h - 02983000h
WINSPOOL loaded at 73000000h - 73023000h
WININET loaded at 76200000h - 76298000h
CRYPT32 loaded at 762C0000h - 76348000h
MSASN1 loaded at 762A0000h - 762AF000h
imagehlp loaded at 76C90000h - 76CB2000h
DBGHELP loaded at 6D510000h - 6D58D000h
Version info:
foobar2000 v0.7.4 beta 2
UNICODE
I was encoding with Nero's plugin when i got this.
Also would it be possible to adjust the encoder's priority? Normal is a bit high.
