Topic: CD burning initialization failed (Read 118732 times) previous topic - next topic
Reply #50
Well I just downloaded the latest version of Foobar and the identical error arises when attempting to burn a CD.
Reply #51
Good day !
I install foobar2000 v0.9.4.3
In folder "components" put foo_boorninate.dll and after this foobar read " Failed to load DLL : foo_burninate.dll"
what me do ?
OS Windows XP pro SP2
Reply #52
what me do ?
What version of foo_burninate leads to this error message?
The actual version of foo_burninate is v3.0.1 and is compatible with foobar2000 0.9.6 and newer.
It may be useful to update your foobar to v0.9.6.9 or to search an older foo_burninate which works with foobar2000 0.9.4.3
Reply #53
Install foobar2000 v0.9.6.9
Put in folder "Components" foo_burninate.dll,restart foobar ok. without error.
Next insert in drive CD-RW disc. In foobar chosen track and click right buttom "Write Audio CD"
my disc begin erase, after erase foobar me information "Audio proces failed:Unknow error code (0xC0AA0208). if I out CD-RW from drive foobar read "No disk inserted (0xC0AA202)
Reply #54
Next insert in drive CD-RW disc. In foobar chosen track and click right buttom "Write Audio CD" my disc begin erase, after erase foobar me information "Audio proces failed:Unknow error code (0xC0AA0208). if I out CD-RW from drive foobar read "No disk inserted (0xC0AA202)
You are not alone with this error code (0xC0AA0208): please read the two first pages of this thread, at least starting here.
If you don't want to read the complete two pages, you can copy the mentioned error code into the search field of your web browser and then search for it in this two pages, may be this is easier for you.
Robertina.
Reply #55
Thank you Robertina )
Reply #56
WinXP + http://download.microsoft.com/download/4/D...SRV2003_x86.exe - No VirtualDrive
Optiarc DVD RW AD-7170A
   C:\WINDOWS\system32\DRIVERS\cdrom.sys
   Поставщик:   Microsoft Corporation
   Версия файла:   5.1.2600.3126 (xpsp_sp2_qfe.070425-0225)
   C:\WINDOWS\system32\DRIVERS\imapi.sys
   Версия файла:   5.1.2600.2714 (xpsp.050705-1524)
   C:\WINDOWS\System32\Drivers\PxHelp20.sys
   Поставщик:   Sonic Solutions
   Версия файла:   3.00.56a
   C:\WINDOWS\system32\DRIVERS\redbook.sys
   Версия файла:   5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
   C:\WINDOWS\system32\DRIVERS\SiRemFil.sys
   Поставщик:   Silicon Image, Inc.
   Версия файла:   1, 1, 7, 0
   C:\WINDOWS\system32\storprop.dll
CD burning initialization failed: No recording devices found
Reply #57
have you the updated Image Mastering API from MS?
http://www.hydrogenaudio.org/forums/lofive...php/t72934.html
terry
EDIT
Description of foo_burninate as per wiki.
Adds support for burning audio CDs from any of supported audio formats, through context menu commands.
Operating System Support
Windows Vista SP1 and Windows 7: works out-of-the-box
Windows XP and Windows Vista SP0: IMAPIv2 redistributable package must be installed in order to use this component.
I have Windows 7 which should work "out of the box". Even still I tried to download the update but there is not one that works with Windows 7.
hi
to summarize we have error 0xC0AA0208 with this drive :
NEC DVD_RW ND-3540A
NEC DVD+-RW AD-5540A
TSSTcorp CD/DVDW TS-L532M
NEC DVD+-RW ND-3530A
NEC ND-3550A
running : xp vista and window7
According to this site, http://msdn.microsoft.com/en-us/library/cc835244(VS.85).aspx
my error code 0xC0AA0208 means "The drive reported that the combination of parameters provided in the mode page for a MODE SELECT command were not supported."
I guess the NEC hardware doesn't support some parameter combination being used? I guess that is pretty vague so probably hard to troubleshoot if you don't have the drive. Has Peter seen this thread?
Reply #58
Can I add my device to the list above, please? I hope it might change the situation, which seems quite "dead" to me for now.
Optiarc DVD RW AD-7200S
Yes, the same problem - 0xC0AA0208
SP3
Reply #59
I am running WinXP x64 SP2
I had to DL a special version of the libraries here: http://www.microsoft.com/downloads/details...EE-DE18DD30A61C
But I get the error message "Audio CD burning process failed: IMAPIv2 libraries not installed properly (0x80040154)"
Burner is NEC ND-2500A, fb2k is 0.9.6.8
Any help?
Reply #60
Audio CD burning process failed: Unknown error code (0xC0AA0208)
Win 7 RC
Burner is Benq DVD DD DW1640 ATA device
foobar2000 0.9.6.9
foo_burninate 3.01
Reply #61
I've heard that whoever comes to #foobar2000 with this problem might get a custom debug build of foo_burninate from Peter and possibly be the one honored for taking active role in solving the 0xC0AA0208 issue for the rest of their life. Well or just the first to know that this is some driver brokenness and it can't be helped.
Reply #62
several people  are having problems with this plugin ,has anyone been able to burn with this without getting the error message? (burn failed)
Reply #63
*threads merged*
Burns fine here, and for most people, apparently. Every CD burner on the alpha testers' machines work without problems. Hence Yirkha's call for someone who has this problem to volunteer some time.
Please don't start new topics when another covering the same subject already exists.
elevatorladylevitateme
Reply #64
Hello all. I too would like to help in getting this fixed. My specs are:
  XP Pro w/SP3
  IMAPI installed
  Burners: (Lite-On) iHAP322 9 & Memorex DVD16+/-DL4RWnD2 SCSI CdRom Device (both DVD burners)
  Error: Audio CD burning process failed: IMAPIv2 libraries not installed properly (0x80040154)
Interestingly, this error is not the very first thing that "goes wrong".  That would be the fact that only the Lite-On shows up in the device poplist in the Burn Audio CD dialog window.
I know nothing about IRC, but I'd be happy to learn if that's what's required. I really want foobar2000 to be my one-stop jukebox solution. It's almost there. It can play all my formats and load my iPod. All it's gotta do now is burn CDs for me.
Thanks,
Larry
Reply #65
I am also having problems with this. I love this plugin and hope it gets fixed soon. If I can be of any help I have a NEC ND-3500AG dvd drive and would be willing to help test any fixes or anything.
Reply #66
Quote from: Yirkha link=msg=0 date=
Quote from: shakey_snake link=msg=0 date=
NEC/OPTIARC/SONY listed here seems to be OEM drives ...
no hope  I think
Reply #67
i could even live just being able to use the old plugin that required nero. i didn't keep a back up of it though. there a chance someone could post the old plugin that required nero in the interim?
Reply #68
That's an excellent idea. Can we get the old DLL back? Surely somebody must have a copy of it around somewhere.
Reply #71
oups!!
sorry, using firefox+adblock I have forgotten that
Reply #72
And another thanks! Works like a champ!
Reply #73
thanks for the old version. am going to download the new free version of nero and see if the plugin works with it.
edit: doesn't seem to work with nero 9 free. probably because it doesn't have the full nero burning rom part. oh well. guess i will have to install nero 6 again, even though it doesn't work right on windows 7. at least it lets me use the plugin correctly.
Reply #74
In case anyone else is thinking of going to the channel to ask about this custom debug build, I went there and asked and was told that somebody has already tried it and Peter knows the info it reports. So as of now there is nothing else we can do to help.
