66 Pages V  « < 64 65 66
foo_discogs, Tags files with information from Discogs
SmirG3l
post Feb 16 2015, 15:39
Post #1626
So Suddenly after months of working just fine
(skipped) Error: Authorization Failed (401) [Is OAuth working?] - (url: http://api.discogs.com/oauth/request_token)
[ESCAPE to close]
How do I fix this? it won't let me authenticate it anymore?
SmirG3l
post Feb 16 2015, 19:07
Post #1627
foo_discogs: HTTP error status: HTTP/1.1 401 Unauthorized
foo_discogs: Exception handling: http://api.discogs.com/oauth/request_token?
alexinc
post Feb 17 2015, 19:45
Post #1628
i'm quite surprised noone mentiones the series field of discogs yet and after searching the net for further Information on how to tag the Name of a compilation series i didnt find any hint besides "part of an compilation = 1". so there is no "official tag" for storing the Name of an compilation series? if updated, could disogs-plugin write something like %discogs_compilation_series%? smile.gif
Der Internet
post Feb 21 2015, 00:39
Post #1629
anyone got Problems reaching the discogs-api, too?
komhst
post Feb 21 2015, 07:06
Post #1630
QUOTE (Der Internet @ Feb 21 2015, 01:39) *
roscar
post Feb 21 2015, 15:57
Post #1631
I get (wihtout the API)
(FATAL) Error [release 6533212]: Page Deleted or Missing (404) - (url: http://s.pixogs.com/image/R-6533212-1421560153-6357.jpeg.jpg)
The extraneous extension .jpg is the problem, the correct URL is http://s.pixogs.com/image/R-6533212-1421560153-6357.jpeg. Discogs maybe (just guessing here) changed something to allow for different formats, why listing the full filename including extension makes sense. Either Discogs' server or foo_discogs adds .jpg, because it always did. Should be easily fixable for zoomorph either way.
With the API I get
(FATAL) Error [release 6533212]: Page Deleted or Missing (404) - (url: http://api-img.discogs.com/###hash###=/fit-in/150x150/filters:strip_icc():format(jpeg):mode_rgb()/discogs-images/R-6533212-1421560153-6357.jpeg.jpg)
... so the API doesn't make any difference.
If you disable art completely (also in preview dialog) everything else works as normal.
Edit: I wrote an issue on the bugtracker.
This post has been edited by roscar: Feb 21 2015, 16:05
komhst
post Feb 21 2015, 16:21
Post #1632
QUOTE (roscar @ Feb 21 2015, 16:57) *
All the cover images in discogs have filenames such as this: R-3869373-1347520948-2326.jpeg.jpg
This post has been edited by komhst: Feb 21 2015, 16:23
roscar
post Feb 21 2015, 18:29
Post #1633
QUOTE (komhst @ Feb 21 2015, 17:21) *
No, they don't - as I've already shown. But that's the filename you get through their crappy lightbox viewer.
zoomorph
post Feb 21 2015, 19:27
Post #1634
It looks like Discogs changed something with their images API causing existing applications to break. rolleyes.gif
I will look into this tomorrow. In the meantime, I guess users need to wait, or disable downloading images.
zoomorph
post Feb 21 2015, 20:45
Post #1635
OK, I've uploaded a new version (1.52) which should fix download images.
The problem was that foo_discogs was still using OAuth for images, but the new images endpoint doesn't support OAuth. Instead, it now has authentication built directly into the URL. Sadly, this means that it's no longer trivial to bypass the API for images. My fingers are crossed that the new built-in authentication for images is on a per-IP basis rather than a per application.... If not, we'll probably be hitting the 1000-images per day limit again soon. Maybe if every foo_discogs user goes and complains on the Discogs API Forum they'll fix that limit to be per-IP instead of per-application. ;-)
This post has been edited by zoomorph: Feb 21 2015, 20:47
komhst
post Feb 22 2015, 08:48
Post #1636
It's working perfectly now!
alexinc
post Feb 23 2015, 18:51
Post #1637
i noticed one little bug, when having an artist name consisting of more than 2 artists combined with "features" or "presents", foo_discogs always fetches the first one and uses it for the following ones. so "abc pres. def feat. xyz" always becomes "abc feat. def feat. xyz" e.g. smile.gif
This post has been edited by alexinc: Feb 23 2015, 18:54
zoomorph
post Feb 23 2015, 21:58
Post #1638
It sounds like the crappy image rate-limiting has been fixed (it's now done per-IP and allowed 300/min, unofficial). That's good news as it means foo_discogs users shouldn't have any more problems.
zoomorph
post Feb 25 2015, 07:56
Post #1639
QUOTE (alexinc @ Feb 23 2015, 18:51) *
Please provide example release.
alexinc
post Feb 25 2015, 16:12
Post #1640
QUOTE (zoomorph @ Feb 25 2015, 07:56) *
http://www.discogs.com/release/654021 Track 2-10
http://www.discogs.com/release/1229612 Track 1-4
http://www.discogs.com/release/1485101 Track 1.17 smile.gif
was tagging quite some compilations the last days and noticed that behaviour on various releases.
This post has been edited by alexinc: Feb 25 2015, 16:15
zoomorph
post Feb 26 2015, 20:15
Post #1641
Thanks. Fixed that bug for the next version.
alexinc
post Feb 27 2015, 11:42
Post #1642
that was fast, thx! could you plz consider adding fetching the series-field in upcoming version? belonging links posted previously belong to series "trancemaster" e.g. smile.gif
RSS Lo-Fi Version Time is now: 2nd March 2015 - 16:01
