Topic: fb2k converter in 1.3.3 (Read 1246 times) previous topic - next topic
I just realized that in v1.3.3 when I choose converter>[last used] the program does not apply the last used codec but instead the default one, previously I was using v1.3.0 and [last used] it worked fine.
It works well even now, you're doing something wrong. Double check with a new portable copy.
I don't know, I double check with 1.3.3 and also with the last beta version and I get the same behaviour. This is what I did;
1. Converted 2 files (1 flac and 1 wav) to mp3
2. Picked a third lossless file and select [last used], it supposed to offer me to convert to mp3 but no, no matter what format I picked up last time if I select [last used] a windows will popup offering me save the file as wav.
I also double checked with v1.3.0 and this doesn't happen, it works like it supposed to be, really strange
Did you by chance convert these using Quick Convert?
Ehhh, yep, P) Now I get it, so [last used] only grabs the codec used when you press convert=>... , I thought that it also remember the one used with quick convert. I was doing something wrong after all, but the strange thing is that v1.3.0 seems to include the last quick convert preset used in the [last used]
