Topic: Stream from Google Music (Read 12303 times) previous topic - next topic
I would like to know if there's any way to stream my music from Google Music using foobar2000, by using a plugin or other method?
I found this http://foobar2000-google-music.googlecode.com/svn/trunk/ but don't know how to make it work.
Maybe somehow using this DLNA server http://www.universalmediaserver.com/forum/...p?f=6&t=224
I was able to use the DLNA server to successfully stream from google music. I couldn't get seeking to work though
You generally can't seek streaming media without server to client communication. In order to have that you would probably need to research into their mobile app.
First, a little heads-up. This was just a quick estimation over the code I saw. Unless you're a programmer or know how to code in HTML/PHP, this might be a bit complicated.
You'll need to use a web server with PHP support and place the files there. It will be in Chinese, so you may want to translate it.
Maybe also change to google.com/music/ instead of google.cn/music/ as well.
The path to foobar2000 seems to be hardcoded to d:\foobar2000\ so you'll need to change that too.
Latest update was in 2010, not sure if something has changed on Google's side, so it may not work, at all.
Thank you Andreasvb for the explanations
