25 Pages V  « < 23 24 25
Discussion of "Default UI Gallery", Please post questions and comments here.
MuhdNurHidayat
post Oct 8 2014, 18:59
Post #601
Foobar2000 is really awesome! Thanks to the developers!!
I've finally configured out how to make the title bar text shortened...
For example, this Japanese song's title is "鈴懸の木の道で「君の微笑みを夢に見る」と言ってしまったら僕たちの関係はどう変わってしまうのか、僕なりに何日か考えた上でのやや気恥ずかしい結論のようなもの" which completely mess up the title bar, but I managed to make it display only "鈴懸の木の道で「君の[...]しい結論のようなもの"
This song's article in English Wikipedia is http://en.wikipedia.org/wiki/Suzukake_no_K...Y%C5%8D_na_Mono in case anyone want to know... laugh.gif
Proud user of foobar2000, Rainmeter, BatteryBar Pro and IDM.
Hotsoup
post Oct 8 2014, 19:46
Post #602
Welcome! I have a little pink in my default UI too. Pink FTW!
Retract
post Oct 12 2014, 13:02
Post #603
Garbanzox.bean, how would I go about modifying your config so the info bar allows the text to be read as a line underneath, rather than be hidden when the box isn't big enough?
See the ASMZ album, how the release info is covered. It would be nice if it displayed the whole thing, with the rest of the text made into a new line.
marc2003
post Oct 12 2014, 14:13
Post #604
that's not possible. consider using foo_textdisplay if you want to display large chunks of text.
http://marc2003.x10host.com/updates
eahm
post Oct 26 2014, 18:18
Post #605
QUOTE (kareha @ Sep 30 2014, 19:51) *
QUOTE (Strigoy @ Sep 25 2014, 00:33) *
A little update.
Playing around with VU meter component, I kinda like it.
Would love a copy of this.
Here you go: http://www.reddit.com/r/foobar2000/comment...triguilite_dui/
marc2003
post Nov 1 2014, 10:56
Post #606
QUOTE (MachineHead @ Nov 1 2014, 08:41) *
Did some further tweaking. Displays all I want to see and is reasonably clean.
i see you've mangled in the rating script into your toolbar as well.... but there's not really much need for it - falstaff's playlist script lets you rate tracks directly from the playlist itself.
MachineHead
post Nov 1 2014, 12:03
Post #607
Mangled? Whatever.
I don't normally have cursor following so it makes it easy to rate on the fly where it is.
orbtwin
post Nov 14 2014, 21:50
Post #608
QUOTE (garbanzo.bean @ Nov 23 2013, 14:33) *
Some slight adjustments to color and spacing, and some refined Title Formatting in some areas. Forever evolving smile.gif
it's uperb!...it's possible to share?.thx
more or less, minus is best
AndyReach9@gmail...
post Nov 17 2014, 18:20
Post #609
Kudos to devs for Foobar - indeed great. I'm a new convert. Just 3 quick ques...
1. can someone tell me how to create command or menu so that delete button not only deletes song from library but also from computer.
2. to retag my songs (as some are messed up- just say track 1 ...), if I want to do this across multiples folders and tell foobar to rename album name from "folder name" and song name from filename (minus any numbers in there) - how do I do that ?
3. to get volume normalization across my playlist- which can span multiple folders, even on home network- whats the best way.
thanks a lot, in advance
hejiamei
post Dec 3 2014, 13:38
Post #610
QUOTE (djatrac @ Nov 14 2014, 00:29) *
My "grey mouse":
full size pic
hejiamei
post Dec 3 2014, 13:39
Post #611
QUOTE (D.Sync @ Oct 30 2014, 18:18) *
Started to play around with Default UI after using Columns UI for ages now. I noticed a significant performance boost when filter my large libraries using DUI. Used the TABS heavily to customize with my different preference, i.e. when tagging music, browsing and listening, or just listening at full screen and amazed by others rolleyes.gif
hejiamei
post Dec 3 2014, 13:42
Post #612
QUOTE (marc2003 @ Nov 23 2014, 09:06) *
mind share????????
pr0phet
post Dec 12 2014, 20:17
Post #613
CmdRobot
post Dec 19 2014, 20:24
Post #614
Sculptured this one over the past years. Only thing I might want to do is some additional text-colouring. Very lightweight, needs only 25mb RAM. Still clever. I love it! It's a pitty you can't hide the menu-bar in DUI.
elia_is_me
post Dec 25 2014, 14:39
Post #615
QUOTE (CmdRobot @ Dec 20 2014, 03:24) *
you CAN if you try foo_uihacks.dll...
RSS Lo-Fi Version Time is now: 28th January 2015 - 21:49
