Topic: lame 3.98.4, 3.99 alpha (Read 201821 times) previous topic - next topic
LAME 3.98.4
download (mediafire)
LAME 3.99 alpha 3
Win32:
lame.exe - the command line encoder, used from the Windows command shell
lame_enc.dll - LAME encoding library, generally used with CD rippers, etc
lame.acm - windows acm codec.
x64:
lame64.exe
lame_enc64.dll
lame64.acm
Bundle compiled with Intel Compiler 11.1.060.
LAME 3.98.4
LAME 3.99 alpha 3
Win32:
x64:
lame64.exe
lame_enc64.dll
lame64.acm
scam?
(Edit: full quote to protect against possible edits by OP)
Thank you so much  how can I get lame x64 to work with dbpoweramp? sorry for the noob question
At HA the OP is noobier than you. Let's see if the OP provides support for the release.
EDIT
http://www.virustotal.com didn't find anything scary in the exe files. Only "Symantec 20091.2.0.41, 2010.03.23" thinks that the files are suspicous.
I believe that you can't use a 64 bit dll/exe from within a 32 bit program (dbpoweramp is 32-bit) -- at least not easily (in any case you probably wouldn't see advantages from the switching/thunking).  (The 64-bit release of dbpoweramp is supposed to be rel. 15 or so.)
  p.s. this is a pure guess but you might be able to hardcode and call a 64-bit cmd.exe batch using the cli encoder, but I doubt it would work b/c dbpoweramp interfaces with it and probably calls 32-bit cmd there (I haven't tried).
I sent also the acm and dll files to virustotal. The results are the same as earlier. The files appear to be clean, except that Symantec found them suspicious.
I do not know, why are the results from Symantec's.
I'm using Avast Pro 4.8.1368 (vps: 100322-0), Windows XP x64 SP2.
No problem with NOD32.
But I'll wait...
But I'll wait...
Very wise since on sourcefoge.net you can find this:
Latest LAME release: v3.98.3 (February 2010)
Stpuid questions do not exist.
From changelog:
Robert Hegemann
Fix for Bugtracker item [ 2973877 ] A problem regarding the new drain code
But what a problem was??
🇺🇦 Glory to Ukraine!
I'll release LAME 3.98.4 soon, because of a bug in 3.98.3, which may result
in a malformed bitstream sometimes (mostly high bitrate CBR). (Bugs item #2973877)
Has anyone else something that needs to get fixed before a 3.98-branch release?
Ciao Robert
So now the smoke has cleared ... thanks for the heads-up (and the quick compile) tsnr.
A full set of win 32 builds of 3.98.4 is now at Rarewares as is the 3.99a3 bundle.
Btw. I would welcome some feedback on the unicode filename problematic. Prior to 3.99, filenames with unicode characters, that are not represented in 8-bit code pages, didn't work with LAME. I hope that 3.99 solves it. It would be nice, if windows users with non-latin1 character code pages could test it.
Regarding Rarewares, the server may not work correctly at the moment.
The addresses:
http://rarewares.org/
http://www.rarewares.org/
- do not open the home page. No error message is displayed. The browser window stays empty.
The addresses:
http://rarewares.org/index.php
http://www.rarewares.org/index.php
- work normally.
I tested this with Firefox, Opera and I.E. Can anyone else confirm the problem?
I confirm the rarewares problem too!
Same for me but I use this address
So, what compile should I use? Posted by the topic starter or downloaded from rarewares? o.O
The addresses:
The addresses:
- work normally.
This should now be resolved, I think!
Can someone tell me why I'm getting different audiostreams with compiles by tsnr and john33??
Differences found: 4389914 sample(s), starting at 2.1563265 second(s), peak: 0.0983066 at 149.9082993 second(s), 2ch
Also encoding is about 1.5x faster with tsnr's compile
Parameters (foobar2000):
--silent -b 320 -q 0 --noreplaygain - %d
Different compilers produce different code. Different code may perform computations slightly differently, producing slightly different results, and/or be faster.
Edit: After john33's post, I realised that I should have mentioned that any such differences are almost certainly infinitesimal.
