Topic: foo_vis_shpeck (Read 733645 times) previous topic - next topic
mycroft and 1 Guest are viewing this topic.
foo_vis_shpeck
Shpeck is a component which can load and run Winamp visualisation plugins under foobar2000. Plugins capable of running in an "embedded window" can be put into a Columns UI panel too.
ZIPed distribution contains a README file with short installation guide and changelog.
Please read the rest of this topic before asking, or at least use the fast search function - see the bottom left corner of the page. And use the [​codebox] instead of [code​] for crash dumps to keep them short. Thanks!
Current version is [!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]Shpeck 0.3.7[/size] from 2009/09/24.
foo_vis_shpeck.dll [!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--](237 KB)[/size]
foo_vis_shpeck-0.3.7.zip [!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--](121 KB)[/size]
mirror
FAQ:
  • Some plugins like MilkDrop 2 or NSFS are not detected.
    Copy the NSCRT.DLL file from Winamp's root directory somewhere, where the Windows DLL loader can find it (e.g. your directory with foobar2000.exe) - not needed since v0.3.0, they can be left in the Plugins directory too.
  • MilkDrop 1 or AVS randomly crashes.
    They are not compatible with DEP, there is no fix available AFAIK. Edit: Fix for MilkDrop 1.04 [a href=\'index.php?act=findpost&pid=633965\']here[/a].
Original first post:
Hi guys,
I came across a backup of my old foobar 0.8.whatever installation with foo_vis_bacon and Milkdrop yesterday and I thought it would be nice to see some of the carefuly crafted presets again. So I grabbed some other unused stuff from under my desk and hacked together the following thing over night.
While praising the Nullsoft's eternal wisdom about ingenious plug-in design, I gradually realized it actually works somehow (i.e. with more than one particular plug-in and on more than one machine) and it's quite usable too (i.e. not just with a hardcoded path to one plug-in DLL and half-supported API). So I decided to release it for public use.
I'm sure nobody cares about "WHEEE TEH COLORIZZZED PIXELZ!!!11 AND MOOVINK TO MY MUZAXX!! LULZZ!!" any more, but here is the link anyway:
(removed)
Enjoy!
foo_vis_shpeck
I, on the other hand think you just made alot of peoples day  ALthough I havent tested it yet, visualisations are one of the things alot of people want to have. Could you give some more info ? Is it a default user interface plugin, or columns_ui ? Any dependencies ?
foo_vis_shpeck
It's plain external old style visualisation plugin, not using the Foobars columns/panel UI nor the "new"(?) Winamp 5.0+(?) panel UI(?). It's up to the plug-in to create a window or use fullscreen or something completely different.
It has no other dependencies. Just copy it inside components folder, go to "Preferences/Visualisations/Shpeck", choose the path where you have your plug-ins installed, choose the one to use, configure it and crash^H^H^H^H^Hplay!
(obsolete screenshot removed)
Another start/stop switch appears in the "Main menu" under "View/Visualisations", which can be bound to a keyboard command.
I haven't tested it extensively, I only tried a few most downloaded pieces from here and it worked for me, but there are probably many compatibility bugs to fix. Bugreports are welcomed, of course.
foo_vis_shpeck
Can't wait to try this out when i get home!    Thanks for your effort here, the AVS and Milkdrop visualizations are one thing I've missed since i switched to FB2K.
foo_vis_shpeck
Well I'm glad someone found this because this will lock me into using foobar only which is what i do now and only use winamp if i need it for video and then i only use 5.35 because 5.5 is just so bloated anyway i digress.
I tried this with milkdrop2 and it still asks for winamp 5.12 even though i have it installed and pointed to the right place and then if i try running it with milkdrop 1.04e i get the following error. maybe i need to find just milkdrop 1.04 like in your screen shot and see if it works.
edit: okay i just went to http://www.milkdrop.co.uk/downloads.htm and download the old version of milkdrop 1.04 and that will work with this. It's a shame though as milkdrop2 actually supports pc shaders now and what not. still something is better then nothing.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00000000h
Access violation, operation: read, address: 00000000h
Call path:
Stack (0475FEB8h):
0475FE98h:  00000000 00000000 00000020 00000000
0475FEA8h:  0018A118 773F8EA4 DCBAABCD 00000000
0475FEB8h:  0477244F 7E42F383 0475FFB0 01803E18
0475FEC8h:  04817158 04817158 0476AFB2 00000000
0475FED8h:  04817158 04783CF5 04817158 04785233
0475FEE8h:  047BCBD0 04789B45 01803E18 00000000
0475FEF8h:  017C6682 047BCBD0 00000000 0012F7A8
0475FF08h:  0475FFB0 01803E18 BAFE3CB0 84ACE1BC
0475FF18h:  BAFE3C24 804DC2B2 804DC2BA 84ACE18C
0475FF28h:  84ACE020 84ACE054 004DB8F3 8057C8C6
0475FF38h:  85CE9650 84ACE020 7FFD7000 BAFE3C84
0475FF48h:  804F8639 00000000 00000005 00000000
0475FF58h:  00000000 00000000 804EFB50 00000000
0475FF68h:  00000000 804E5358 806EE2E7 84ACE020
0475FF78h:  BAFE3D50 863C8E18 00000000 863C8D01
0475FF88h:  00000000 85CE9650 804F8641 00000000
0475FF98h:  00000000 00000000 804F8621 BAFE3C9C
0475FFA8h:  806EEC35 00000000 0475FFEC 017C6959
0475FFB8h:  7C80B683 01803E18 00000000 0012F7A8
0475FFC8h:  01803E18 7FFD7000 C0000005 0475FFC0
Registers:
EAX: 00000120, EBX: 01803E18, ECX: 00000224, EDX: 049D6688
ESI: 04817158, EDI: 00000001, EBP: 0475FFB0, ESP: 0475FEB8
Crash location: "foobar2000", loaded at 00400000h - 00506000h
Loaded modules:
foobar2000   loaded at 00400000h - 00506000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt   loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 7E410000h - 7E4A0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1D7000h
ole32 loaded at 774E0000h - 7761D000h
shared   loaded at 10000000h - 1002D000h
COMDLG32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
wbsys loaded at 66500000h - 6650A000h
uxtheme   loaded at 5AD70000h - 5ADA8000h
MSCTF loaded at 74720000h - 7476B000h
msctfime loaded at 755C0000h - 755EE000h
foo_abx   loaded at 00B80000h - 00BB3000h
foo_albumlist loaded at 00BD0000h - 00C25000h
foo_cdda loaded at 00C50000h - 00C86000h
foo_converter loaded at 00CB0000h - 00D23000h
foo_cwb_hooks loaded at 00D50000h - 00D86000h
foo_dsp_std   loaded at 00DB0000h - 00DF7000h
foo_freedb2   loaded at 00E20000h - 00E61000h
foo_input_std loaded at 00E90000h - 00FB2000h
foo_lyricsdb loaded at 00FE0000h - 0100F000h
OLEAUT32 loaded at 77120000h - 771AB000h
WININET   loaded at 42C10000h - 42CDF000h
Normaliz loaded at 01020000h - 01029000h
iertutil loaded at 42990000h - 429D5000h
foo_playcount loaded at 01250000h - 01275000h
foo_rgscan   loaded at 012A0000h - 012E7000h
foo_run   loaded at 01310000h - 0133B000h
foo_uie_albumart loaded at 01360000h - 0139D000h
gdiplus   loaded at 4EC50000h - 4EDF3000h
foo_uie_albumlist loaded at 013D0000h - 0140D000h
foo_uie_lyrics   loaded at 01430000h - 01492000h
WINMM loaded at 76B40000h - 76B6D000h
foo_uie_playlists_dropdown   loaded at 01540000h - 01579000h
foo_uie_powerpanels   loaded at 015A0000h - 015C3000h
foo_ui_columns   loaded at 015F0000h - 016B6000h
foo_ui_std   loaded at 016E0000h - 01793000h
MSIMG32   loaded at 76380000h - 76385000h
foo_vis_shpeck   loaded at 017C0000h - 017E1000h
foo_winamp_spam   loaded at 01810000h - 0182F000h
foo_ui_panels loaded at 01840000h - 01906000h
syncagent loaded at 01B70000h - 01BB1000h
events   loaded at 16000000h - 16028000h
MSVCR71   loaded at 7C340000h - 7C396000h
DSOUND   loaded at 73F10000h - 73F6C000h
VERSION   loaded at 77C00000h - 77C08000h
WINTRUST loaded at 76C30000h - 76C5E000h
CRYPT32   loaded at 77A80000h - 77B14000h
MSASN1   loaded at 77B20000h - 77B32000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
wdmaud   loaded at 72D20000h - 72D29000h
msacm32   loaded at 72D10000h - 72D18000h
MSACM32   loaded at 77BE0000h - 77BF5000h
midimap   loaded at 77BD0000h - 77BD7000h
KsUser   loaded at 73EE0000h - 73EE4000h
dciman32 loaded at 73BC0000h - 73BC6000h
WS2_32   loaded at 71AB0000h - 71AC7000h
WS2HELP   loaded at 71AA0000h - 71AA8000h
vis_milk loaded at 04760000h - 0494A000h
d3d8 loaded at 6D9A0000h - 6DAC8000h
d3d8thk   loaded at 6D990000h - 6D996000h
DBGHELP   loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 0477244Fh, location: "vis_milk", loaded at 04760000h - 0494A000h
Address: 7E42F383h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "SendMessageA" (+00000000h)
Address: 04817158h, location: "vis_milk", loaded at 04760000h - 0494A000h
Address: 0476AFB2h, location: "vis_milk", loaded at 04760000h - 0494A000h
Address: 04783CF5h, location: "vis_milk", loaded at 04760000h - 0494A000h
Address: 04785233h, location: "vis_milk", loaded at 04760000h - 0494A000h
Address: 047BCBD0h, location: "vis_milk", loaded at 04760000h - 0494A000h
Address: 04789B45h, location: "vis_milk", loaded at 04760000h - 0494A000h
Address: 017C6682h, location: "foo_vis_shpeck", loaded at 017C0000h - 017E1000h
Address: 017C6959h, location: "foo_vis_shpeck", loaded at 017C0000h - 017E1000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 017C6950h, location: "foo_vis_shpeck", loaded at 017C0000h - 017E1000h
Address: 10000000h, location: "shared", loaded at 10000000h - 1002D000h
Version info:
foobar2000 v0.9.5 beta 5
UNICODE
Windows 5.1
Additional info:
Run services 0.3.2  (foo_run)
cwbowron's title format hooks 1.1.1 [May  4 2007 - 12:39:47]  (foo_cwb_hooks)
foobar2000 core 0.9.5 beta 5  (Core)
Album list panel 0.2.2  (foo_uie_albumlist)
Panels UI 0.14.9 beta [Jul 13 2007 - 14:05:55]  (foo_ui_panels)
Playback Statistics 2.0  (foo_playcount)
Winamp API Emulator 0.90  (foo_winamp_spam)
Shpeck - Winamp vis plug-ins wrapper 0.0.3  (foo_vis_shpeck)
Columns UI 0.2  (foo_ui_columns)
Converter 1.0.2  (foo_converter)
Seek Panel 0.1  (foo_uie_powerpanels)
Default User Interface 0.9.5  (foo_ui_std)
freedb Tagger 0.5.2.1  (foo_freedb2)
Album Art Panel 0.2.7  (foo_uie_albumart)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Volume Panel 0.1  (foo_uie_powerpanels)
Lyric Show Panels 0.3.1.2 Alpha 3 [Nov 29 2007 - 00:19:03]  (foo_uie_lyrics)
Standard DSP Array 1.0  (foo_dsp_std)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
ABX Comparator 1.3.1  (foo_abx)
CD Audio Decoder 2.1.2  (foo_cdda)
Album List 4.1  (foo_albumlist)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Converted code to codebox.[/size]
foo_vis_shpeck
thank you!
i have test it and milkdrop vizual work for me well
foo_vis_shpeck
Well, the first part was easy, I now return I'm a Winamp 5.50 instead of oldish 2.6. After that, I had only reinvent some shiny new "Winamp® Random Generator?" API (at least I hope it was a random generator!) and the MilkDrop2 showed up. Try version 0.0.4: *outdated*
But supporting newer 5.0+(?) plugins will need more effort, there are lot of new functions the wrapper doesn't support and it's kind of strange it doesn't crash (it pukes these things into fb2k console, you can have a look).
From the usability point of view, what is certainly missing is the method of rendering vis plugins embedded inside a window provided by Winamp, which is probably the preffered way how things should be done.
foo_vis_shpeck
thanks for the quick update Yirkha. I don't realize your were actually developing this i thought you had found it. thanks for making this and your work on it  yeah i see now it throws error codes into the console. I really don't use anything else but milkdrop so i'm glad i can use it with this.
That's milkdrop2 running with foobar 0.9.5 beta 5 and prettypop in the lower right. Just a quick test using default settings
Moderation: Removed unnecessary full-quote of the preceding post.
foo_vis_shpeck
doesn't seem to work with AVS. Im getting "error creating window" when I try to start it.
foo_vis_shpeck
Request:
Can you please modify the control for defining the Plug-ins directory so that the user can manually enter the path instead of relying on the Browse For Folder dialog? I am having trouble entering network and wine paths.
foo_vis_shpeck
Thats so awsome!!!  Looks extremely promising so far.  If you could manage to create an panel version you would be my official hero.
Foobar urgently needs some cool Visuals -it's the only thing I miss in foobar.
foo_vis_shpeck
i second a panels version as that would be smooth to included into existing configs
foo_vis_shpeck
nice component, only thing missing is the ability to encapsulate the visualizations into a panel or something...
foo_vis_shpeck
Many thanks for a great add-in!
I'd love a panels version - and/or a version which allowed me to save a visualisation name in a tag so I could always play a particular visualisation with a particular track!
foo_vis_shpeck
Yes, if you can make this a panel for the new Default UI (once the SDK is available), many would be very grateful.
foo_vis_shpeck
Thank you so much.
I kept an old working 0.8.3 just for Milkdrop!
And now, I won't even have to start the new portable winamp 5.5 to enjoy Milkdrop 2.
Maybe it's on my computer only but there's a little glitch (blinking line) at the top of the screen while running Milkdrop in fullscreen. It comes from the underlying foobar2000 display of the spectrum analyzer. The manual workaround is to press escape (Milkdrop goes windowed) minimize foobar2000 and doubleclick on Milkdrop's window to put it in fullscreen again.
Would it be possible to add an option to make this solution (or any other working solution) automatic ?
TIA.
PS: This option exists in Milkdrop and is checked here but I guess it can't work in foobar2000:
"Minimize Winamp when going fullscreen"
foo_vis_shpeck
I'm getting this error when maximising the vis-window on foobar 0.9.5 beta 5:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 07A00471h
Access violation, operation: read, address: 08928CD0h
Call path:
Code bytes (07A00471h):
07A00431h:  C0 04 89 44 24 24 03 D5 0B CA 89 48 FC 8B 44 24
07A00441h:  18 48 89 44 24 18 75 98 89 74 24 18 FF 15 98 8B
07A00451h:  ED 07 8B 54 24 34 33 C2 33 D2 F7 F6 8B EA FF 15
07A00461h:  98 8B ED 07 8B 4C 24 38 33 C1 8B 0C AB 99 F7 FE
07A00471h:  8B 04 93 89 0C 93 89 04 AB 8B 44 24 18 48 89 44
07A00481h:  24 18 75 C8 8B 44 24 1C 8B 54 24 20 48 8D 1C 93
07A00491h:  89 44 24 1C 0F 85 08 FF FF FF 8B 6C 24 2C 83 FF
07A004A1h:  01 0F 8E C3 01 00 00 8B 6C 24 40 33 DB 3B F3 89
Stack (05B32F64h):
05B32F44h:  00000000 05B3CE08 05B3CDE0 00000000
05B32F54h:  B9968E88 00000001 804DA3EE B9968EC0
05B32F64h:  00000001 00000030 00000032 07B5E048
05B32F74h:  000000D8 0000006C 00000100 00000100
05B32F84h:  00000100 08929400 97ACE206 07B5E048
05B32F94h:  04FA2340 C60505B4 00008F34 00000400
05B32FA4h:  08929000 73696F6E 716D5F65 74696C00
05B32FB4h:  3C0B0065 3C220F4D 3C39586D 3C4F9618
05B32FC4h:  3C651CB6 3C7B30A6 3C8912D8 3C94B01F
05B32FD4h:  3C9EB6DB 3CA567B6 3CA7E963 3CA552B5
05B32FE4h:  3C9D2081 3C8F33AD 7C928734 FFFFFFFF
05B32FF4h:  00000040 05B3326C 7C929090 00000000
05B33004h:  05B3332F 05B332D0 7C928726 05B3332F
05B33014h:  05B332E4 7C928726 00000000 00000000
05B33024h:  00000007 00000000 00000000 00000000
05B33034h:  05B33288 00000000 00000000 7C92E56C
05B33044h:  00000000 00000001 00000001 7C928734
05B33054h:  FFFFFFFF 00000040 05B332D0 7C929090
05B33064h:  00000000 05B33393 05B33334 7C928726
05B33074h:  05B33393 05B33348 7C928726 00000000
Registers:
EAX: FFF37000, EBX: 08929000, ECX: CD04ACC4, EDX: FFFFFF34
ESI: 00000100, EDI: 00000008, EBP: 000000B4, ESP: 05B32F64
Crash location: "vis_milk2", loaded at 079F0000h - 07F0F000h
Loaded modules:
USER32                          loaded at 7E410000h - 7E4A1000h
nview                            loaded at 00A40000h - 00BB2000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
NTMARTA                          loaded at 77690000h - 776B1000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
NVWRSDE                          loaded at 00CF0000h - 00D3C000h
foo_albumlist                    loaded at 00D40000h - 00D95000h
foo_audioscrobbler              loaded at 00DB0000h - 00DE2000h
foo_cdda                        loaded at 00E50000h - 00E86000h
foo_comserver2                  loaded at 00EB0000h - 00F06000h
foo_converter                    loaded at 00F30000h - 00FA3000h
foo_cwb_hooks                    loaded at 00FD0000h - 0101D000h
foo_dbsearch                    loaded at 01040000h - 010B0000h
foo_dbsearch_api_demo            loaded at 010D0000h - 010F1000h
foo_discogs                      loaded at 01120000h - 011C1000h
foo_dsp_std                      loaded at 011F0000h - 01237000h
foo_fileops                      loaded at 01260000h - 012A7000h
foo_freedb2                      loaded at 012D0000h - 01311000h
foo_infobox                      loaded at 01340000h - 01380000h
foo_input_alac                  loaded at 013A0000h - 013BD000h
foo_input_monkey                loaded at 013E0000h - 0142A000h
foo_input_shorten                loaded at 01450000h - 0147D000h
foo_input_std                    loaded at 014A0000h - 015C2000h
foo_lnk                          loaded at 015F0000h - 01609000h
foo_mlt                          loaded at 01630000h - 0163A000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_oddcastv3                    loaded at 01660000h - 0172F000h
BASS                            loaded at 01740000h - 01780000h
WINSPOOL                        loaded at 73000000h - 73026000h
Normaliz                        loaded at 01780000h - 01789000h
vorbis                          loaded at 01790000h - 018A1000h
ogg                              loaded at 018B0000h - 018B6000h
libFLAC                          loaded at 018C0000h - 018E3000h
pthreadVSE                      loaded at 018F0000h - 018FD000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
foo_out_ks                      loaded at 01B40000h - 01B6A000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playcount                    loaded at 01B90000h - 01BB5000h
foo_playlist_manager            loaded at 01BE0000h - 01C27000h
foo_playlist_tree                loaded at 01C50000h - 01CC5000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
libmzgc360_000                  loaded at 01CF0000h - 01D94000h
foo_random                      loaded at 01DE0000h - 01E1F000h
foo_rgscan                      loaded at 01E40000h - 01E87000h
foo_run                          loaded at 01EB0000h - 01EDB000h
foo_sendtodevice                loaded at 01F00000h - 01F3D000h
foo_sic                          loaded at 01F60000h - 01FB9000h
foo_tradersfriend                loaded at 020E0000h - 0211A000h
foo_uie_albumart                loaded at 02140000h - 0217D000h
foo_uie_albumlist                loaded at 021A0000h - 021E3000h
foo_uie_playlists_dropdown      loaded at 02210000h - 02249000h
foo_uie_quicksearch              loaded at 02270000h - 022B6000h
foo_uie_wmpvis                  loaded at 022E0000h - 0231D000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_ui_columns                  loaded at 02330000h - 0241E000h
foo_ui_panels                    loaded at 02440000h - 02529000h
foo_ui_std                      loaded at 02550000h - 02604000h
foo_unpack                      loaded at 02630000h - 0265E000h
foo_utils                        loaded at 02680000h - 026F9000h
foo_vis_shpeck                  loaded at 02720000h - 02741000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
WMP                              loaded at 12950000h - 133B4000h
MSVFW32                          loaded at 75A70000h - 75A91000h
dbghelp                          loaded at 59A60000h - 59B01000h
wmploc                          loaded at 13740000h - 13F1B000h
nvwddi                          loaded at 04FC0000h - 04FD5000h
dsound                          loaded at 73F10000h - 73F6C000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
ddraw                            loaded at 73760000h - 737A9000h
d3d9                            loaded at 4FDD0000h - 4FF76000h
vis_milk2                        loaded at 079F0000h - 07F0F000h
usp10                            loaded at 74D90000h - 74DFB000h
Address: 07B5E048h, location: "vis_milk2", loaded at 079F0000h - 07F0F000h
Address: 7C928734h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLookupAtomInAtomTable" (+000002FEh)
Address: 7C929090h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLookupAtomInAtomTable" (+00000C5Ah)
Address: 7C928726h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLookupAtomInAtomTable" (+000002F0h)
Address: 7C92E56Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlSelfRelativeToAbsoluteSD" (+00000358h)
Address: 7C92E3B0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlSelfRelativeToAbsoluteSD" (+0000019Ch)
Address: 7C92B3AEh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlVerifyVersionInfo" (+000000D1h)
Address: 01F0DFA4h, location: "foo_sendtodevice", loaded at 01F00000h - 01F3D000h
Address: 7C92915Fh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "sprintf" (+00000031h)
Address: 7C92E56Ah, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlSelfRelativeToAbsoluteSD" (+00000356h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 77F1F910h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetCharWidthW" (+0000015Ch)
Address: 77F1F87Fh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetCharWidthW" (+000000CBh)
Address: 77F18C86h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetObjectA" (+00000078h)
Address: 7C90D4EAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwAllocateVirtualMemory" (+0000000Ch)
Address: 7C9180FFh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+00000702h)
Address: 7C911BFFh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSection" (+000000D2h)
Address: 7C91825Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+00000860h)
Address: 7C911C8Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSection" (+0000015Fh)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 77F198EBh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+00000084h)
Address: 77F1BDA9h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "EnumFontFamiliesExW" (+00000187h)
Address: 77F1BD94h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "EnumFontFamiliesExW" (+00000172h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 77F1BC52h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "EnumFontFamiliesExW" (+00000030h)
Address: 74DA4D09h, location: "usp10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+00000087h)
Address: 74DA4D78h, location: "usp10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+000000F6h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 74DAE51Dh, location: "usp10", loaded at 74D90000h - 74DFB000h
Address: 74DA5659h, location: "usp10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+000009D7h)
Address: 74DA575Ah, location: "usp10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+00000AD8h)
Address: 4FE12890h, location: "d3d9", loaded at 4FDD0000h - 4FF76000h
Symbol: "DebugSetLevel" (+00017860h)
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 07BC0884h, location: "vis_milk2", loaded at 079F0000h - 07F0F000h
Address: 77F516D4h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetGlyphIndicesW" (+000000C0h)
Address: 77F53020h, location: "GDI32", loaded at 77F10000h - 77F57000h
Address: 74DA5AACh, location: "usp10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+00000E2Ah)
Address: 74DE0214h, location: "usp10", loaded at 74D90000h - 74DFB000h
Address: 74DA5EB3h, location: "usp10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+00001231h)
Address: 74DA3DC0h, location: "usp10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptGetFontProperties" (+00000023h)
Address: 07A34CA1h, location: "vis_milk2", loaded at 079F0000h - 07F0F000h
Address: 77C2C3C9h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000001AEh)
Address: 77C2C3CEh, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000001B3h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 77C35C94h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "except_handler3" (+00000000h)
Address: 77C12088h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "__non_rtti_object::`vftable'" (+00000C90h)
Address: 77C2C3E7h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000001CCh)
Address: 77C29CD4h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "operator new" (+0000000Fh)
Address: 079FFC88h, location: "vis_milk2", loaded at 079F0000h - 07F0F000h
Address: 079FFFDCh, location: "vis_milk2", loaded at 079F0000h - 07F0F000h
Address: 07AEDBE8h, location: "vis_milk2", loaded at 079F0000h - 07F0F000h
Address: 00454D65h, location: "foobar2000", loaded at 00400000h - 00506000h
Version info:
foobar2000 v0.9.5 beta 4
UNICODE
Windows 5.1
Additional info:
ALAC Decoder 1.0  (foo_input_alac)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Audioscrobbler 1.3.12  (foo_audioscrobbler)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
WMP Visualizations 0.1.3 (Intel SSE)  (foo_uie_wmpvis)
Shorten decoder 0.4.2a  (foo_input_shorten)
Columns UI 0.2.1 alpha 7 v2  (foo_ui_columns)
Playlist Manager 1.0.2  (foo_playlist_manager)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
foobar2000 core 0.9.5 beta 4  (Core)
Playlist Tools 0.6.2 beta 3  (foo_utils)
Send to Device 1.1.2 [Nov 28 2007 - 10:13:31]  (foo_sendtodevice)
Special file info box 2.0.4  (foo_infobox)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
foosic music database 1.0 beta 12  (foo_sic)
OddcastV3 3.x  (foo_oddcastv3)
Discogs Tagger 1.12  (foo_discogs)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
Miranda ListeningTo foobar2000 Plugin 1.0  (foo_mlt)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Shpeck - Winamp vis plug-ins wrapper 0.0.4  (foo_vis_shpeck)
ZIP/GZIP reader 1.0  (foo_unpack)
Database Search Toolbar Demo 1.0  (foo_dbsearch_api_demo)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Shell Link Resolver 1.2  (foo_lnk)
RAR reader 1.1  (foo_unpack)
Randomized playlist entry 1.2.3  (foo_random)
COM Automation server 0.7 alpha 6  (foo_comserver2)
File Operations 2.0  (foo_fileops)
Database Search 1.4  (foo_dbsearch)
foo_vis_shpeck
Because AVS was made strictly for use inside "Winamp 5+ Embedded Window", it quite works now, at least as much as I have tested it. (The display seems a bit flickery in fullscreen though, I don't know why.)
Request:
In XP, there is an editbox at the bottom of "Browse For Folder" dialogs which can be used for fast entry and other things, but I suppose it's not there under Wine. So, here you are: click the [...] button with Shift pressed - then just enter your path and click [OK].
That "preset by tag" thingy is a bit difficult, because all vis plugins generall do this in their own way and Shpeck only works as a wrapper around them. Since Winamp 5.something, there is common interface for visualisation running inside an embedded windo (panel), but AFAIK it's only possible to issue commands like next/prev/random preset, not select a particular one.
Unfortunately, I wasn't able to reproduce this behaviour. May be because of the changes I made, may be because of different configuration, may be because of different moon phase. Please try again with the updated version of the plugin and if it won't help, I'll try to investigate a bit more.
@ vis inside a panel:
Sure. Waiting for update Foobar SDK release.
@ the crashes:
Try the updated version, it shouldn't crash any more.
Download version 0.0.5:
<obsolete links removed, see the first post in this thread for information about the latest version>
Edit: I forgot to mention - the path selected in configuration dialog is now to the root directory of Winamp, not the Plugins subdirectory, because some other paths need to be made from that. Don't be surprised there is nothing in the list, just reselect the correct directory.
foo_vis_shpeck
Thanks for the update! AVS in foobar under wine, I can hardly wait for a panel version.
* Page tearing is only apparent on screen capture
* I wish foobar preference window was resizable
foo_vis_shpeck
This is really strange what you are saying.
Panels are part of columns ui, aren't they?  So you have to use this SDK? Sorry If my question is noobish.
For creating a ui element you will have to wait for the new Foobar SDK.
foo_vis_shpeck
Awesome job getting AVS working! Thank you so much! Quick request, though. Could you make the vis window minimize independently of foobar? I like to keep the vis open with foobar minimized.
foo_vis_shpeck
This is really strange what you are saying. :blink:
Ah, panel, UI element, component, so much new words to learn and distinguish... I meant an UI element inside 0.9.5+ default UI, of course.
The point is I have never used any non-standard UI in fb2k, so don't know anything about the columns UI's interface, for example. But if there's demand, I'll look at it.
foo_vis_shpeck
I knew this kind of request will come, I noticed this too, but I was sleepy enough not to figure how to solve it then. So here we go, version 0.0.6: *outdated*
(I hope I haven't broken something else in the Winamp window emulation code though, it's all a bit messy.)
foo_vis_shpeck
Freaking awesome.  AVS and Milkdrop are working perfectly in my setup.  You have already given alot to this community with your short time here and i want to make sure you know that we are very thankful for your time and efforts.
foo_vis_shpeck
This is ******* awesome! Thank you! Finally I can use G-Force with Foobar, and have it actually work(could never get the stand-alone to pick up on the audio).
I'd love to see the ability to launch different visualizations without having to go into the preferences to switch. It'd be awesome to have a button on my build to launch G-Force and another to launch MilkDrop, with the 'stop' function of course stopping whichever visualization you're currently running. Don't know how easy that would be to do or if it's even possible, but I'd love it all the same!
Thanks again, this is great:-D
