Topic: Resampler plugin (Read 490090 times) previous topic - next topic
Re: Resampler plugin
Reply #325
i only get "quick convert" and default as an option.
And also "..."
Reply #326
Oh yes, the small print
thank you
Reply #327
Just wondering if it would be possible to get a mod or mod2 with passband down to 85? Thanks for considering this.
Reply #328
Hope this great work will keep happening!
Reply #329
I just wanted to say a huge HUGE thank you for this. I have some pretty sensitive hearing, and on certain songs this really does bring the sound alive just that much more... I'm currently geeking out to the Panzer Dragoon soundtrack and am in pure aural heaven! I signed up on the HA forums just so I could share my gratitude!
Reply #330
A SoX was updated yesterday. Curious if changes touched resampler routines and if there's ongoing foo_dsp_resampler update...
Reply #332
Why isn't this component listed on http://www.foobar2000.org/components too? Wouldn't it be better too to deliver it in the new foobar-component package format (so that you can doubleclick the downloaded file for install)?
Reply #333
Thank you for publishing the old version as an attachment. Much appreciated. It also works under WinXP SP1.
Reply #334
@lvqcl: Thanks for suggesting how to do an AB comparison between different settings of the resampler.  For other forum readers, lvqcl suggested using the SoX resampler in the configuration of the convert utility within foobar2000 to create WAV files.  Then use the official ABX component of foobar2000 to ABX compare the WAV files.  It even supports comparing (the same original file converted to) two different sample rates.  The ABX component supports pressing the A and B keys on the keyboard to select between the choices, so testing can be performed with the eyes closed.  A pause, but no clicks are heard, when switching sample rates.  Slick!
I found that minimizing the buffer size in foobar2000 and my ASIO driver's controls minimized the pause duration when switching between A and B with different sample rates.
Reply #335
Hi, I have one quick question. My DAC supports only 44.1k, 48k, and 96k sample rate. I have some 32k sample rate music that I need to upsample in order to play. Which sample rate will give me the best quality?
Reply #336
From a mathematical point of view, that would be a samplerate which is an even divider or multiplier of the source samplerate. That would rank it 96,48,44. However, 96 might be overkill, so I'd go with 48. Then again, in the end it's up to your ears.
Reply #337
This means simpler calculations, but not necessarily better quality.
Any.
Reply #338
Hi lvqcl,
Would it be possible to expose the resampler's "Quality" setting (Normal / Best) via its default settings (found in Advanced -> Playback -> SoX Resampler default settings)? It is the only thing that is not exposed there.
Thank you for all the hard work!
Reply #339
Hello, lvqcl,
SoX Resampler v0.8.3 mod and mod2 both don't create messages in foobar2000's console, although I can hear that they are resampling. In the changelog I didn't find a hint that this feature, that I appreciated very much when using v0.5.4.1 mod has been removed.
Do I overlook something?
Reply #340
It was removed in 0.8.0; they were added to help debugging, so I decided to remove them finally.
Reply #341
These messages had been helpful in cases in which the processing didn't meet the ear but was needed for other purposes.
Your resamplers are my favorite ones, so thank you for them, lvqcl.
Reply #343
lvqcl, did you see this:
Hi lvqcl,
I'd really appreciate an answer.
Reply #344
Other components can use resampling routines of this plugin via resampling service. They specify target samplerate and target quality when they create resampler instances; foo_dsp_resampler takes other settings from advanced preferences.
So what this plugin should do if the default quality setting is highest but some component requests low quality resampling (or vice versa)? Somebody will always ask me why my plugin ignores quality setting.
Robertina, Night Rain: try attached plugins.
Reply #345
Cool; thanks for the explanation.
Reply #346
Both versions are working perfectly here. Thanks a lot for having taken into account to re-add output to console, lvqcl.
I wish more DSPs would output their status to the console as your resamplers do.
Reply #347
Great plugin!
Any plan to get it into the official repository?
Reply #348
Does this version exist here? http://src.infinitewave.ca/ If so, which one is it exactly since there are a few versions of sox there.
Reply #349
if i save a dsp chain preset in foobar with some custom resampler(sox) settings, then load some other preset, then reload the preset with resampler(sox) its custom settings are lost (all at defaults again).
if i do the same with resampler (pphs), all custom settings are preserved upon reloading preset.
