For the past 4 weeks i have been working on a wrapper around openal and ogg vorbis(cAudio). everything went great on linux.....i decided it was time to actually test it on windows. so i find out i have to change ov_open to ov_open_callbacks. This is fine till it compiles loads the file yet there is no sound playing no crash program responds fine. I was hoping maybe you guys could help me out im going crazy over here. I just don't understand how something could work flawlessly in linux then with a switch of a function it doesn't. I have a separate function that loads the ogg file into memory and plays it from there and that works fine but i really need the streaming support. I wasnt sure how much of the code you needed to see so i posted a large majority of it. the stream loading is in the openstream method.
#include "../Headers/cAudio.h"
#include "../Headers/cUtils.h"
#include "mikmod.h"
namespace cAudio{
std::vector<cAudio*> cAudio::thevector;
cAudio::cAudio(){
thevector.push_back(this);
oggMemoryFile.dataPtr = NULL;
streaming = false;
modfile = false;
playaudio = false;
pauseaudio = false;
size_t VorbisRead(void *ptr, size_t byteSize,size_t sizeToRead, void *datasource){
size_t spaceToEOF;
size_t actualSizeToRead;
SOggFile* vorbisData;
vorbisData = (SOggFile*)datasource;
spaceToEOF = vorbisData->dataSize - vorbisData->dataRead;
if((sizeToRead*byteSize)<spaceToEOF){
actualSizeToRead = (sizeToRead*byteSize);
}else{
actualSizeToRead = spaceToEOF;
if (actualSizeToRead){
memcpy(ptr,(char*)vorbisData->dataPtr + vorbisData->dataRead, actualSizeToRead);
vorbisData->dataRead += (actualSizeToRead);
return actualSizeToRead;
int VorbisSeek(void *datasource,ogg_int64_t offset,int whence){
size_t spaceToEOF;
ogg_int64_t actualOffset;
switch(whence){
case SEEK_SET:
if(vorbisData->dataSize >= offset){
actualOffset = offset;
}else{
actualOffset = vorbisData->dataSize;
vorbisData->dataRead = (int)actualOffset;
break;
case SEEK_CUR:
if(offset < spaceToEOF){
actualOffset = (offset);
}else{
actualOffset = spaceToEOF;
vorbisData->dataRead += actualOffset;
break;
case SEEK_END:
vorbisData->dataRead = vorbisData->dataSize+1;
break;
default:
std::cout<<"errror cant seek";
return 0;
int VorbisClose(void *datasource){
return 1;
long VorbisTell(void *datasource){
return vorbisData->dataRead;
void cAudio::open(const std::string& path){
FILE* tempOggFile;
int sizeOfFile;
char tempChar;
int tempArray;
if(path.length() == 0){
}else{
if(!(tempOggFile = fopen(path.c_str(),"rb"))){
std::cout<<"cant load file";
}else{
extension = getExt(path);
if(extension == "ogg"){
sizeOfFile = 0;
while(!feof(tempOggFile)){
tempChar = getc(tempOggFile);
sizeOfFile++;
oggMemoryFile.dataPtr = new char[sizeOfFile];
rewind(tempOggFile);
tempArray = 0;
oggMemoryFile.dataPtr[tempArray] = getc(tempOggFile);
tempArray++;
fclose(tempOggFile);
oggMemoryFile.dataRead = 0;
oggMemoryFile.dataSize = sizeOfFile;
vorbisCallbacks.read_func = VorbisRead;
vorbisCallbacks.close_func = VorbisClose;
vorbisCallbacks.seek_func = VorbisSeek;
vorbisCallbacks.tell_func = VorbisTell;
if(ov_open_callbacks(&oggMemoryFile,&oggStream,NULL,0,vorbisCallbacks) != 0)
std::cout<<"cant load ogg to memory";
vorbisInfo = ov_info(&oggStream, -1);
vorbisComment = ov_comment(&oggStream, -1);
if(vorbisInfo->channels == 1)
format = AL_FORMAT_MONO16;
else
format = AL_FORMAT_STEREO16;
alGenBuffers(3, buffers);
alGenSources(1, &source);
}else{
if(extension == "mod" || extension == "xm" || extension == "s3d" || extension == "it"){
if((modStream = Player_LoadFP(modFile, 255, 0)) == NULL)
fclose(modFile);
throw std::string("Could not open Mod stream.The ") + MikMod_strerror(MikMod_errno);
/* Activate the module */
Player_Start(modStream);
alGenBuffers(2, buffers);
check();
check();
void cAudio::openstream(const std::string& path){
int result;
}else{
if(!(oggFile = fopen(path.c_str(), "rb"))){
std::cout<<"Could not open Ogg file.";
streaming = false;
}else{
//This is were all the troubles occur one line.
if((result = ov_open_callbacks(oggFile, &oggStream,NULL,0,OV_CALLBACKS_DEFAULT)) < 0)
// if((result = ov_open(oggFile, &oggStream,NULL,0)) < 0)
std::cout<<"shit";
fclose(oggFile);
streaming = true;
else
}else{
fclose(modFile);
check();
check();
void cAudio::release(){
alSourceStop(source);
empty();
alDeleteSources(1, &source);
alDeleteBuffers(1, buffers);
ov_clear(&oggStream);
delete[] oggMemoryFile.dataPtr;
if(modfile == true){
Player_Free(modStream);
bool cAudio::playback(){
if(playing())
return true;
if(!stream(buffers[0]))
return false;
if(!stream(buffers[1]))
return false;void cAudio::play2d(bool loop){
alSourcei (source, AL_SOURCE_RELATIVE, true);
alSourcei (source,AL_LOOPING,loop);
playaudio = true;
if(!stream(buffers[2]))
return false;
alSourceQueueBuffers(source, 3, buffers);
if(playaudio == true){
alSourcePlay(source);}
if(playaudio == false){
alSourceStop(source);}
if(playaudio == true && pauseaudio == true){
alSourcePause(source);}
return true;
bool cAudio::playing(){
ALenum state;
alGetSourcei(source, AL_SOURCE_STATE, &state);
return (state == AL_PLAYING);
bool cAudio::update(){
int processed;
bool active = true;
alGetSourcei(source, AL_BUFFERS_PROCESSED, &processed);
while(processed--)
ALuint buffer;
alSourceUnqueueBuffers(source, 1, &buffer);
active = stream(buffer);
alSourceQueueBuffers(source, 1, &buffer);
return active;
bool cAudio::stream(ALuint buffer){
SBYTE pcm2[BUFFER_SIZE];
char pcm[BUFFER_SIZE];
int size = 0;
int section;
int result;
if(modfile == false){
while(size < BUFFER_SIZE)
result = ov_read(&oggStream, pcm + size, BUFFER_SIZE - size, 0, 2, 1, §ion);
if(result > 0)
size += result;
else
if(result < 0)
break;
else
break;
if(size == 0)
return false;
alBufferData(buffer, format, pcm, size, vorbisInfo->rate);
return true;
}else{
/* Write bytes en pcm */
VC_WriteBytes(pcm2, BUFFER_SIZE);
/* If there aren't bytes that we could write in pcm, break */
if (!Player_Active())
return false;
alBufferData(buffer, AL_FORMAT_STEREO16,(char*) pcm, BUFFER_SIZE, md_mixfreq);
check();
return true;
void cAudio::empty(){
int queued;
alGetSourcei(source, AL_BUFFERS_QUEUED, &queued);
while(queued--)
ALuint buffer;
void cAudio::check(){
int error = alGetError();
if(error != AL_NO_ERROR){
//throw string("OpenAL error was Raised.");
bool cAudio::isvalid(){
if(oggMemoryFile.dataPtr == NULL){
if(streaming == false){
return false;
}else{
return true;
playaudio = true;
