Topic: Conversion g.726 to wav or mp3 (Read 10853 times) previous topic - next topic
Hi. I'm trying to commandline convert g.726 files from a digital voice recorder to .wav or mp3 (or any other usable) format.
I've tried, with little success, MMconvert and SOX (plus some other freeware GUI-Apps)
Is there any way to install a codec to recognize these files away from the recorder? I cant even listen to them.
the File that comes out of the recorder is named  "VOC__001.726"
anybody got any clues?
cheers
chris
Basically ITU g.726 is just a raw adpcm stream. Perhaps the problem is that the software you tested did not recognize the number of bits per sample, which may vary within this standard. Sample rate is 8 kHz, bits per sample 2, 3 , 4 or 5, that makes an effective bitrate of 16,24,32,40 kbps.
thanks! I guess I have to try the different settings through with SOX.
Cheers
Chris
hey,
just to clear thing up and finalise this thread:
I wasnt able to find anything to do a commandline conversion of such files.
I was able to play back the file with gxtranscoder (http://www.germanixsoft.de/)
Hope this helps someone.
