Here is the error I received:
INFO (CORE) : startup time: 484 ms
ERROR (foo_rgscan) : Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7800FFE7h
Access violation, operation: read, address: 00CBB000h
Additional info: input::run()
Code bytes:
7800FFC7h: C6 3B FE 76 08 3B F8 0F 82 6E 01 00 00 F7 C7 03
7800FFD7h: 00 00 00 75 14 C1 E9 02 83 E2 03 83 F9 08 72 28
7800FFE7h: F3 A5 FF 24 95 F8 00 01 78 8B C7 BA 03 00 00 00
7800FFF7h: 83 E9 04 72 0C 83 E0 03 03 C8 FF 24 85 14 00 01
Crash info dumped to failure_00000017.txt in your program directory.
If you are reading this, you should restart the program as soon as possible to avoid further trouble, and report this exact message to the developer.
ERROR (foo_rgscan) : internal error decoding file:
INFO (foo_rgscan) : location: "file://C:\Documents and Settings\Hyde\Desktop\Slipknot\15 Scissors.ape" (0)
Code: C0000005h, flags: 00000000h, address: 77FCCA36h
Access violation, operation: write, address: 00000000h
Module: "ntdll", loaded at 77F80000h - 77FFB000h
Additional info: input::close()
This is your 2-nd crash. When reporting the problem to a developer, please try to post info about the first crash instead.
Code bytes:
77FCCA16h: 85 FB 21 00 00 8A 47 05 24 10 A8 10 88 46 05 75
77FCCA26h: 4B 57 53 E8 0C CB FB FF 8B 4F 0C 8B 47 08 3B C1
77FCCA36h: 89 01 89 48 04 0F 84 12 E9 FF FF 8A 47 05 A8 04
77FCCA46h: 0F 85 CB E6 FF FF 0F B7 0F 8B 45 10 01 08 0F B7
Crash info dumped to failure_00000018.txt in your program directory.
ERROR (foo_rgscan) : internal error closing decoded file:
I selected "Replaygain" => "Scan selection as album" and got these errors a little after half-way through the last song. The album is Slipknot by the band Slipknot and was ripped using EAC and then encoded using Monkey's Audio 3.97 in APE format on Extra High. I even tried re-ripping the CD and re-encoding, but I got the same error at the same point. I'm running foobar2000 v0.7 on Windows2000 Professional with all the service packs and updates. The second error appeared immediately after the first error.
