Topic: Degree for component design (Read 1983 times) previous topic - next topic
Hello,
I'm wondering what University degree is required in order to work in the audio component domain?  I presume an electrical engineer would work on amplifier circuitry for example, but what about loudspeakers and other components?  If someone has any knowledge about this I'd appreciate very much!
I'd say either Electrical Engineering, Mechanical Engineering, Physics, Math or Computer Science.  Since you don't have a very specific question, I don't have a very specific answer.
The audio component domain is huge.  In most cases, a complex waveform gets carried through the air until it affects a mechanical/electrical transducer, at which point the waveform is converted to electricity and amplified.  From that point, it either gets amplified, processed, transformed and sent to another transducer which replicates that wave form (in the case of a live concert).  Or it undergoes complex processing to be sent to a storage medium.  At which point, it will stick around until someone wants to listen to it, and then more complex processing occurs until ultimately it goes through that amplification process out to the transducer (i.e. loudspeaker).
Most of this occurs in the electrical domain, but the end points are all mechanical.  The concept of audio itself is basically physics.  The newest technologies are largely being done by computers/processors, but the algorithms and heuristics used by the overall system is at its core, math.
Thanks for your quick reply sthayashi!
Sorry for a not quite specific question, I wasn't sure how to ask it as my question(s) was pretty broad in my head as well
Although your answer was still spot on and enlightened a few bulbs in my head, I'll look further into it!
