Topic: Why does my drive rip so slow? (Read 7068 times) previous topic - next topic
Hello!
First off I should say...I ripped most of my collection (many thousands of CD's) close to ten years ago...so to say I'm a 'newbie' wouldn't be so accurate, but to say my knowledge of what works best is outdated would be fairly true
With that in mind, I'm trying to figure out why it is that my rips these days are going SO slow. I know a few years ago they started adding this RipLock stuff into most of our drives, but isn't that only meant to affect drive speed in the case of DVD's?
I don't remember the last drive I was using (which was also slow), but I can tell you the drive I'm using today is an HL-DT-ST BH20N. While the drive is rated to read CDs at 40x, the disc is only ripping at about 1.5x in EAC. Now, although the quality of the rip is far more important to me than the speed, I can distinctly remember ripping my discs using EAC/high quality settings back in the day at a MUCH faster speed than this.
So, what am I missing or doing wrong?
Any help would be greatly appreciated!
Please tell us your settings. In particular, are you ripping in burst mode, which is fastest.
EAC Secure Mode with 'Drive has accurate stream feature' and 'drive caches audio data' checked. Although the drive can retrieve C2 info, I leave this unchecked (this was always considered best back in the day...not sure about now).
You might want to take a look here.
The quickest way to rip is to turn off secure mode and rip in burst mode, using AccurateRip to verify the rip. Only in cases where AccurateRip is unable to verify do you then repeat with either secure or, better, test and copy.
AccurateRip is arguably much more reliable than secure mode anyway.
There's really no need for test and copy after an initial copy since just a second copy (or test) operation will generate a second independently derived checksum.  The rest is about bookkeeping.
OK...so I clicked the link above (thanks, zfox!) and did a ton of reading. For those that wanna follow without reading everything in the link, it's a 5-page thread of people with Blu-Ray drives (various models) reporting that EAC (but not other programs) was slowing their rip speeds down to like 0.5-1.5x (exactly what I was experiencing)...and by the end of the thread, someone was reporting a quickie workaround that several people had success with.
Anyways, I've now upgraded to the latest EAC (something that was needed for the workaround) and without even using their quickie fix, a test rip I just did got up to around 8.5x by the last track of the CD.
So...two questions:
1. Considering the settings/software I'm using, is 8.5x poor considering the drive is capable of 40x, or is that about what I can reasonably expect given my setup?
2. If I wanted to try the suggestion of ripping in burst first, is there a way I can tell whether or not my CD is in the AccurateRip database before ripping the CD in burst mode?
1. That's what you can reasonably expect.  I know this is the opposite of what is written in the wiki (and maybe I should change it) but, I would use C2 pointers unless they are keeping you from getting accurate rips.
2. There should be an icon in the lower corner of EAC's main window.  It won't tell you if your specific pressing is actually in the database, however.  For that you'll need to rip at least one track.
FWIW I typically inspect the disc for visible damage and if it looks good I use burst mode, unless the drive can safely be run as non-caching and able to provide C2 pointers, in which case I use secure mode configured that way (and regardless of the condition of the disc).
Well I greatly appreciate all the help, guys. I'm pulling boxes of CD's out of storage to rip, so it was worth taking the time to investigate.....and a 4x speed increase is fine by me!
Thanks again!
I might also suggest to look into dBpoweramp's CD ripper.
While EAC is the best free ripper, dBpoweramp, in my opinion, surpasses it. It has better error recovery, is easier to configure and use, has cover art download, has multiple sources for album tags (AMG, GD3, MusicBrainz, and freedb)....
I appreciate your desire to recommend alternative software (and dBpoweramp is good software), but I suggest you do a little homework before leveling claims about the software being discussed as EAC does offer cover art as well as alternate album tagging.
Regarding better error recovery, improvements offered by dBpoweramp are dependent on drive capabilities as well as what is available in the AR database.  A blanket statement about error recovery such as what you made is ill-advised.
This is one issue where I have called for a wiki update. (I have been singing praises to dBpoweramp's metadata, but it is clear that the competition is fiercer these days.)
Agree, but whenever there is an AR match, it sort of improves on the OP's original issue: dBpoweramp does (like it or not) not invoke the slow secure mode until checked that there is no AR match.
There's nothing stopping you from contributing to the wiki.  Simply ask Jan S. for access.
Why would anyone not like such an improvement?  The thing is that I'm not sure such a mode exists in dBpoweramp as you've described it.
I don't feel like changing anything without anyone else's input on what should actually be there, especially not when I propose changes in the structure. FAQs should be discussed first.
Look at http://i.imgur.com/hv4fS.gif , The Great Gig In The Sky; might not a curious user want to verify if the suspicious result prevails with 'secure' ripping invoked?
http://dbpoweramp.com/images/misc/secure-method-db.png  (taken from http://dbpoweramp.com/secure-ripper.htm ). And if you actually insert a CD and keep an eye on the progress bar, that is what it says it does: one pass at full speed(possibly two on a drive without C2), then if no match: re-read the entire track for as many times as you have specified (varying speed if this is in accord with your settings) and only then start to re-rip individual frames if (dBpoweramp finds it) necessary.
I'm actually quite comfortable with how secure ripping in dBpoweramp works, especially with respect to how it differs from EAC, thanks.  I simply would not have used the description that you used.  In any event, the link you provided is quite helpful.
