IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
FLAC - change replaygain target in FOOBAR
AndyMcGowan
post Oct 13 2010, 15:16
Post #1
Group: Members
Hi everybody,
I'm using replaygain in FOOBAR to "normalize" (by adding TAGS) my FLAC album.
It seems that FOOBAR only normalize FLAC files to a target of 89 db, while a need a litte higher volume (let's say 92 db or 90.5 db).
How can I change this setting???
another issue: it seems that normalilzing only works when reducing volume (eg. from 98 db to 89 db) but doesn't when FLAC files' volume is lower (from 80 db to 89 db)
any suggestions?
thanks a lot!
Andy
Go to the top of the page
+Quote Post
mjb2006
post Oct 13 2010, 19:14
Post #2
Group: Members
I haven't tried it to make sure it's not just for MP3s, but I'm guessing Preferences > Advanced > Tools > ReplayGain Scanner > Target MP3 alteration level (dB) is the setting you want to adjust.
I don't know the answer to your other question, but if under Preferences > Playback you have chosen one of the 'prevent clipping' options, that would limit the amount of ReplayGain adjustment to whatever headroom is in the file. So if avg. volume is 80dB but it still has a 100% peak somewhere, you won't get any boost.
This post has been edited by mjb2006: Oct 13 2010, 19:17
+Quote Post
Zarggg
post Oct 13 2010, 20:18
Post #3
Group: Members
That setting is for the "apply ReplayGain data to MP3" (or whatever the exact wording is) function, i.e., not-reversable-losslessly modification of audio data.
To my knowledge, there is no way to change the reference loudness in foobar2000, as the RG implementation is based on the official specs/standard, which state 89dB reference loudness.
As an aside, what ReplayGain does is actually something separate from normalization, but that goes beyond my personal technical understanding.
This post has been edited by Zarggg: Oct 13 2010, 20:21
+Quote Post
db1989
post Oct 14 2010, 13:14
Post #4
Group: Super Moderator
Could the preamp be used for this purpose, at least as a workaround?
+Quote Post
shakey_snake
post Oct 14 2010, 15:22
Post #5
Group: FB2K Moderator
ReplayGain values are only meaningful when the reference value is consistent. Therefore it makes little sense to allow it to be changed.
elevatorladylevitateme
+Quote Post
UNHchabo
post Oct 30 2010, 07:33
Post #6
Group: Members
QUOTE (dv1989 @ Oct 14 2010, 05:14) *
http://sourceforge.net/projects/flacsquisher/
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 4th March 2015 - 17:42
